Old May 23, 2013, 07:17 AM
Sturbridge, MA
Joined Apr 2010
Engine Quits on Landing
Hello
My OS33 keeps quitting upon landing, even if its the rare greaser! Its mounted on an aerobeez yakk55m. I tried enlarging the cowl opening to allow for more hot air to exit. Idles at1800rpm and get a I max rpm of 8100rpm with an 18x8 prop. I'm running a 30:1 mixture with VP 94 octane.
The engine seems to run very strong; plug appears just slightly rich, but quits on every landing. Also noticed that lifting off the ground and dropping maybe six inches also induces a drop in rpm and the engine to sometimes quit.
Please help, I'm at a total loss here!!!!
Also, just called OS and they didnt know for sure. Said possible fuel tank plumbing and clunk not moving. I checked all that and I'm landing each time with a half tank. I'm using a dankal design 16oz tank
timbee is offline Find More Posts by timbee
Old May 23, 2013, 08:42 AM
WCB
NC
Joined Aug 2005
May be idled down too low.
WCB is offline Find More Posts by WCB
Old May 23, 2013, 10:14 AM
LesUyeda's Avatar
San Diego, California
Joined Dec 2004
Where is the carburetor intake. Are you perhaps getting into ground effect, where air is packed under the airplane, and starving the carb???
Les
LesUyeda is offline Find More Posts by LesUyeda
Old May 23, 2013, 02:08 PM
Sturbridge, MA
Joined Apr 2010
I guess it's possible that the idle is too low and/or the air is "packing" around the carb. It's a rear mounted carb near the firewall
Old May 23, 2013, 08:50 PM
Jacksonville Fla.
Joined Mar 2007
I had the same issue with a 3MM 50 cc turned out my tuning was off
jetmech05 is offline Find More Posts by jetmech05
Old May 24, 2013, 03:38 PM
Sturbridge, MA
Joined Apr 2010
Thanks for the help. I'm beginning to think i have it tuned improperly. I think I'm going to reset the factory settings and retune from there
Old May 25, 2013, 01:01 AM
Joined Jun 2008
Les
Please explain how the air that "is packed under the airplane" is "starving the carb?"
Kurt
kbozarth is offline Find More Posts by kbozarth
Old May 25, 2013, 10:16 AM
LesUyeda's Avatar
Joined Dec 2004
If you force enough air into a cavity, it just presurizes, and there is no flow.
Les
Old May 25, 2013, 11:36 AM
Zor
Ontario,Canada
Joined Feb 2007
Where is the "ground effect" ?
Les
The ground effect is due to the main wings deflecting the air mass downward under the wings.
Does anyone think it is under the engine ?
Is the prop wash causing ground effect ?
Is the engine quitting when going full idle at altitude ? Some fellow never go full idle while flying.
I believe checking the engine mixtures is the better approach to solve this problem.
Zor
Zor is offline Find More Posts by Zor
Reply With Quote  (Disabled)
Old May 28, 2013, 04:54 PM
mosquitowings's Avatar
USA, OK, Warr Acres
Joined Feb 2004
just a stab
I'm only making a guess here...is it possible that the slight shock from landing is making an "iffy" electrical connection fail momentarily? I guess you could test for that by mildly bouncing the plane on the ground at idle, with restraints in place of course!
Jim
mosquitowings is offline Find More Posts by mosquitowings
Old May 28, 2013, 10:30 PM
kerwin50's Avatar
winston mo
Joined Oct 2006
Jim
Plus one on that
kerwin50 is offline Find More Posts by kerwin50
Old May 29, 2013, 12:39 PM
United States, TX, Weatherford
Joined Dec 2006
Check your tank clunk. Sounds like classic fuel starvation. The clunk becomes uncovered by fuel, and the engine quits. Or nose up attitude and engines starts to stall out or quit. Not getting gas is my opinion.
Chip01 is offline Find More Posts by Chip01
Help! OS 33GT Quits on landing timbee Engines 9 Mar 12, 2014 10:13 PM
Discussion Please Help! Video Transmission dies on take off back on landing and so on pseudopod FPV Talk 16 Apr 02, 2013 02:34 AM
Discussion Not quite a UAV, not quite FPV... need advice on a system MadMonkey572 FPV Talk 12 Feb 20, 2009 09:11 PM
Question Engine quitting on final 7snakes Beginner Training Area (Fuel) 6 Aug 10, 2005 09:21 AM
