Old Dec 31, 2012, 11:57 AM
Freedom Isn't Free
Warningshot's Avatar
SE Okla
Joined Mar 2006
Question
I want to use a LiPo for power to the motor and a NiCad to operate the servos. How do I wire this to the receiver?
Warningshot is offline Find More Posts by Warningshot
Old Dec 31, 2012, 11:58 AM
I hate waiting for parts
Mike_Then's Avatar
United States, NC, Garner
Joined Apr 2001
Easy... connect the LiPo to the ESC and disable the BEC that's most likely built into the ESC. Connect the NiCd pack to the receiver, and you're done.
Mike_Then is offline Find More Posts by Mike_Then
Latest blog entry: Thank you, veterans
Old Dec 31, 2012, 12:04 PM
Freedom Isn't Free
SE Okla
Joined Mar 2006
What do I do for throttle control?
Old Dec 31, 2012, 12:11 PM
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
By removing or cutting the red (+) wire in the servo lead from the ESC to the receiver, you disable the BEC, but still have throttle control.
Pete
pilotpete2 is offline Find More Posts by pilotpete2
Old Dec 31, 2012, 12:25 PM
Mike_Then's Avatar
Joined Apr 2001
Pete
Correct, unless the ESC has programmable functions that allows you to disable the BEC (most don't), you have to pull the red wire from the servo plug like pilotpete2 said. Pull the red wire out of the plug, or better yet, pull the red wire out of a servo extension and plug the ESC into the extension. Try not to cut the wire if you can possibly help it as if you ever move that ESC into another plane and need the BEC, you only have to slide the red wire back into the plug.
Old Dec 31, 2012, 02:11 PM
Freedom Isn't Free
SE Okla
Joined Mar 2006
Thanks for the answers. I will give it a shot.
Discussion rssi question/eagle tree and frsky question 18t Radios 3 Jun 28, 2012 09:32 AM
Question Parkzone Stryker q Question. May be a general question Soar Neck Flying Wings 2 May 24, 2012 07:28 PM
Discussion KK board questions and other questions about quads bobepine Multirotor Talk 25 May 13, 2012 05:23 AM
Discussion Bird of Time Question Covering Question Jordonr Sailplane Talk 3 Mar 30, 2012 10:30 AM
