Old Oct 20, 2013, 01:40 PM
Joined Apr 2010
new hor. stabilisator- same performance?
Hi
Does changing horizontal stabilistor (to find new but not orginal) can change DLG performance.
I guess surface will not be the same but very similar on new hor. stab..
Any experience with new non original hor. stab and possible changing in performance?
thx
boris
vigli is offline Find More Posts by vigli
Old Oct 20, 2013, 01:51 PM
United States, MD, Baltimore
Joined Feb 2007
Tail groups have a massive effect on airframe performance. There is a reason people will pay for and wait for swindell tails. There are plenty of high performance tail groups available. Depending on what you are flying with now you may see huge improvements to launch height/range/pitch damping. I changed out the balsa tails on my old taboo and it was a whole new machine.
austinhlg is offline Find More Posts by austinhlg
Old Oct 20, 2013, 02:32 PM
Joined Apr 2010
My hor. stab. is very light.
Question would be does small difference in surface on new hor. stab. can change performance. Weight ....let say is the same...
Old Oct 20, 2013, 02:46 PM
Joined Feb 2007
Surface area is one thing. Airfoil is another. Quality of construction for the sharpest TE and smoothest LE is yet another. I am not an aero guy but if you want the best answer tell us what you are flying and what you are looking at. Tail weight is bad but I would rather have a slightly heavier high performance set than a lighter flat/draggy set.
Old Oct 20, 2013, 03:02 PM
Joined Apr 2010
I fly Turbo07.
I was just wondering about changing tail.
It is warp little bit but I will turn back on the hot- I do that before.
Model has very long tail and relative small h.stab
Old Oct 20, 2013, 06:18 PM
Will fly for food
davidjensen's Avatar
Bellevue WA,
Joined Dec 2003
davidjensen is offline Find More Posts by davidjensen
Old Oct 20, 2013, 06:39 PM
boris:
I have campaigned two Blaster 3s for several years, now. I traded out the original tail sets for Swindells, and since then have replaced one Swindell horizontal tail for a foam/kevlar tail of different planform and section. The Swindell tails contributed (I believe, through considerable experience in more than two years of competition) to significantly improved performance. They were thinner, although not smoother, than the originals.
Part of the perceived improvement came from (I believe) to the fact that I removed the large V-mount of the all-moving tail, and replaced it with a shorter, lighter, thinner mount for a fixed tail with elevator.
At the Reynolds numbers our airplanes fly at, I'm not sure surface finish makes all that much difference, but I don't really know.
Yours, Greg
glidermang is offline Find More Posts by glidermang
Old Oct 21, 2013, 10:07 AM
Joined Apr 2010
David
I was thiking about pitch respon.
Greg, does Your new and old hor. stab.has same surface?
Old Oct 21, 2013, 12:07 PM
G_T
Joined Apr 2009
Shape and size matter more than airfoil for the horizontal stabilizer, within reason. This is not counting flat plate tails or poor airfoil choices which suffer from deadband - tails such as that should just be replaced IMHO. The size and shape is going to set the stability characteristics. The airfoil choice and % movable surface sets the efficiency (greater % moving -> higher efficiency when moved. In this case, higher efficiency means less drag).
Additionally, smaller tails have less drag (obviously) but also have additional drag reduction benefit due to the resulting vertical loading of the horizontal tail being reduced or going negative. The horizontal tail sits in the wing's downwash. So if the tail is lifting, it tries to lift upwards and backwards, increasing the drag. A small tail tries to press down a little. Because of the tilt of the freestream it sees due to the downwash of the wing, some of its negative lift converts to forwards thrust cancelling some of its drag. The minus of small tails of course is greater sensitivity to CG and reduced pitch damping. Since CG setting is often best optimized for the conditions, that gets more critical with small tails.
Gerald
G_T is offline Find More Posts by G_T
Old Oct 21, 2013, 11:08 PM
United States, VA, Ashburn
Joined Apr 2013
Could you recommend replacement tails for a topsky 3?
thanks,
Hugh
Planeur is offline Find More Posts by Planeur
Old Oct 23, 2013, 08:19 AM
Joined Apr 2009
thanks,
Hugh
I would also like to know if Swindell tails would be a noticeable improvement on the T.Sky 3 (or any other, for that matter).
Triggerhappy is offline Find More Posts by Triggerhappy
Discussion Kyosho HOR Frame andyman_sf Motorcycles 6 Nov 29, 2013 03:39 PM
For Sale 2 kyosho HOR's Ready2Fight Cars - Motorcycles (FS/W) 4 Jul 17, 2013 08:12 PM
Discussion kyosho hor - leaning bikefan Motorcycles 4 Mar 27, 2013 12:02 PM
Discussion kyosho hor bikefan Motorcycles 11 Mar 05, 2013 01:09 AM
Sold Kyosho HOR Parts gellyphish Cars - Motorcycles (FS/W) 11 Feb 22, 2013 05:09 PM
