This thread is privately moderated by TemeculaRC73, who may elect to delete unwanted replies.
Old Jun 27, 2013, 07:41 PM
United States, CA, Murrieta
Joined Jun 2013
Trader Rating: 0
For Sale
Carbon Fiber Ribbon/Tow
I have 24k strand (approximately 1/4") CF ribbon/tow for sale.
$.75 per foot or 100' for $50.00. Make offers for larger amounts. Payment via PalPal. Msg me for orders.
USES:
It is easy to use Carbon Tow. The simplest application is for wing spars and fuselages. Apply the Tow into place, then wet it out with Fast CA. Rub the carbon into place while the glue sets with a piece of plastic wrapped over your finger.
Another method is to lay the Carbon Tow down, and wet it out with Epoxy. Then squeegee the excess epoxy away and let it cure.
Keep the Carbon Tow stored in the Plastic bag, and don’t let your cats or dogs play with the stuff. Be careful when sanding around the Carbon Tow. You do not want to inhale the carbon dust.
Carbon Tow gives its strength so well because the glue fixes the soft fibers from flexing. The material is very good at not stretching, so when glue fixes the fibers into place on you airframe, the whole unit will resist bending.
TemeculaRC73 is offline Find More Posts by TemeculaRC73
Sold 50k Carbon Fiber Tow punkindrublik Aircraft - General - Miscellaneous (FS/W) 1 Jun 28, 2013 06:46 AM
Sold 5.28 lbs (2,058') of 50 K Carbon Fiber Tow punkindrublik Aircraft - General - Miscellaneous (FS/W) 1 Jun 16, 2013 01:24 AM
Sold 12K Carbon fiber tow (approx 4 lbs) rkovvur Aircraft - General - Miscellaneous (FS/W) 5 Mar 14, 2013 11:42 PM
Discussion how to spread a carbon fiber tow into a carbon fiber band ROSS OS Composites Fabrication 11 Jan 10, 2013 05:28 PM
For Sale CARBON FIBER TOW (aka RIBBON) $5 SAMPLE PACKS steelhead Aircraft - Electric - Airplanes (FS/W) 0 Dec 13, 2008 03:22 AM
