Old Dec 08, 2012, 06:14 AM
Per Ardua Ad Astra
Berkie's Avatar
Australia, VIC, Rosebud
Joined Feb 2007
Foamy elevator problem
Hi All
It has happened again! No recovery from a steep dive.
I have had this happen once in an EZ* and 3 times now in EZ glider Pro
This time I wanted to see how she would stabilise fro a nose down attitude so I let go of the sticks, but the dive steepened quickly, I applied full up, but no result.
She went in vertical
After the crash I found the ESC & motor to be very hot which was probably due to a full throttle climb. Even though the ESC may have failed control should have been OK because it has a separate Rx battery, although I did try throttle just before she hit and I am not sure, but I don't think there was a response. All 4 servos were still working after the crash (didn't test motor)
A thing I thought strange though, was as I got close to the wreck (say 10 metres) the FrSky Tx beeped telling me there is loss of signal. Funny, because with the aircraft on the ground it should have beeped 50 metres away then stopped when I got to 10 metres.
Is this crash due to the higher load in a dive that the control system in these foamies just won't cut it? E.g. the control wire is too long and cannot exert enough force?
I have not heard of EZGPs needing the elevator servo mounted in the tail, but it looks like that's what I will have to do
Kev
Berkie is offline Find More Posts by Berkie
Help! Problem building Of the SkyWalker V5 (Elevator) RanDavari FPV Talk 8 Mar 21, 2013 12:50 AM
Help! mSR forward elevator problem Rabidmonkey234 Micro Helis 6 Jul 15, 2012 02:20 PM
Discussion The Old Elevator Halves Connector Rod Problem Chophop Electric Plane Talk 0 Jun 12, 2012 08:48 PM
Question A problem with the elevator (hawk 120mm) yfrach Scratchbuilt EDFs 4 May 15, 2012 11:15 PM
Discussion problems with elevators on tucano foamy jetGSR Foamies (Kits) 2 Oct 04, 2008 01:36 AM
