Old Feb 26, 2015, 08:15 PM
Fly hard with a vengeance.
RPM314's Avatar
United States, NY, Brooklyn
Joined Apr 2012
Question
Giant foamies
Hi, all. I'm tossing around the idea of building a giant foamie (3m span, 120") for a school project, but I only have experience in the 1-1.5m range. What I usually do is score the inside of the LE and fold the foam over a former, and the former has dowels or CF tubes embedded in the top and bottom for strength. The wing forms an airfoil on its own.
How would the construction techniques differ at this big scale? I assume I will need ribs to hold an airfoil and to make hard points out of ply for when things intersect, but I don't know too much beyond that. The wings will probably break in half for transport, does anything special need to be done at the joint? How do you make torsionally stiff control surfaces that don't flap around? How do the right angle mountings of the tail feathers usually work? What is the best way to brace against wing flutter?
Thanks in advance for the help, and please fill me in on any other categories I should know about.
Oh, and what ballpark of wattage should be needed if this will be a slow flyer type? I'm thinking 750-1000 watts.
RPM314 is offline Find More Posts by RPM314
Old Yesterday, 02:13 PM
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
What type of foam ?
What sort of plane ?
There are already a few 'biggies' in the Foamies (Scratchbuilt) forum, but they may be a little difficult to search for.
There was/is a model called Pink Floyd that was made very large 24ft span
Here's some pictures of it and other large foam models --
Google Image search on Pink Floyd RC foam plane
eflightray is offline Find More Posts by eflightray
Old Yesterday, 03:01 PM
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Found one that may be of interest, bit over 3m span --
Giant Parkflyer Foamy
Old Today, 02:06 PM
RPM314's Avatar
Joined Apr 2012
Originally Posted by eflightray View Post
What type of foam ?
Foam is 6mm MPF. I cannot tell you what type of plane it will be yet since we will decide that democratically as a class. It will likely be a high wing conventional plane, though.
Old Today, 02:18 PM
RPM314's Avatar
Joined Apr 2012
That blue foam parkflyer was cool, but of a way lower weight class than what we're thinking of.
Old Today, 03:30 PM
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Slow flying is mostly about light weight, (low wing loading), the power is basically immaterial at this stage, even a glider can fly slowly.
Old Today, 08:08 PM
RPM314's Avatar
Joined Apr 2012
Hrmmm....
Maybe I should have said parkflyer, I want it to handle analogous to the standard 1100mm Trojan trainer since most of my classmates have never flown before. (~200 watts at that scale)
For Sale Visual Guide to Building a Giant Bird Dog Foamie haibardolaza Aircraft - General - Miscellaneous (FS/W) 0 Jan 26, 2015 11:43 AM
For Sale Giant DC3 Foamie haibardolaza Aircraft - General - Miscellaneous (FS/W) 6 Jan 10, 2015 09:09 PM
Sold 1600mm Giant foamie Cessna with scale details edwen303 Aircraft - Electric - Airplanes (FS/W) 4 Dec 19, 2013 06:52 PM
Sold DW Foamies 55" Juka RX-R GIANT FOAMY! stickybeatz Aircraft - Electric - Airplanes (FS/W) 10 Jan 07, 2011 08:46 PM
