Old Sep 14, 2013, 02:47 PM
Mrtarango32's Avatar
United States, CA, Glendora
Joined Oct 2012
hdmi convertor
im having issues with this hdmi conv with my sony nex5r. i have all my video tx and rx working fine but not getting any video on my monitor from the nex5r.
really appreciate any help. thanks
http://www.cnchelicopter.com/servlet...HDMI-to/Detail
Mrtarango32 is offline Find More Posts by Mrtarango32
Old Sep 15, 2013, 12:42 PM
Richard in Bangkok
Thailand, Bangkok
Joined Jul 2012
I have the same converter and it works great. Have you hooked it directly to a monitor (skipping out the TX and RX) ?
I found that mine gives a better and more stable picture when it has a separate 5v supply, rather than getting its power from the NEX5 via the HDMI cable.
richardt1808 is offline Find More Posts by richardt1808
Old Sep 15, 2013, 03:16 PM
Joined Oct 2012
Hmm mine doesn't show a port to have 5v input to it
Old Sep 16, 2013, 03:07 AM
Richard in Bangkok
Thailand, Bangkok
Joined Jul 2012
Okay, so yours takes power from the NEX5 cable. Connect the unit to your camera and eliminate...
Connect the video out from the convertor to a monitor. If there is no picture, then there are 3 causes
a) your convertor
b) the cable between convertor and your camera
c) camera does not output HDMI
To eliminate any issue with your camera and HDMI cable, try plugging your camera directly to the HDMI input of another monitor (no convertor in the equation). If you get picture, then you know thatbyour convertor is toast. If you don't get picture then you have a problem with cable / camera settings etc.
Old Sep 16, 2013, 04:45 AM
New Zealand, Hawke's Bay, Napier
Joined Jun 2011
Are you supplying 5V via the mini USB port? I read that you could take power from the camera battery on 1080i but the HDMI converter just kept rebooting and video would keep cutting out. 5V via a BEC solved that problem for me and camera battery went for a lot longer also.
helidex is offline Find More Posts by helidex
Old Sep 19, 2013, 12:39 AM
Joined Oct 2012
I don't have a mini USB port just the hdmi and video and ground.
So I need to open it up and power it with 5v off a bec
Discussion Looking for 12V Composite to HDMI convertor Canada Goose Aerial Photography 7 Jul 21, 2013 10:17 PM
Discussion Pearstone Braided Mini HDMI to HDMI Cable kcobello Aerial Photography 9 May 23, 2013 01:11 AM
Cool HDMI converter + VTX = HDMI VTX [hack] crashtested Multirotor Talk 8 Feb 06, 2013 08:04 AM
Discussion S800 HDMI cable question Gibbons Multirotor Talk 0 Jan 28, 2013 05:03 AM
Question Lightweight Short HDMI to Mini HDMI Cable? Jason Cole Aerial Photography 13 Aug 17, 2012 05:44 PM
