Old Jun 23, 2015, 04:42 AM
SoloProFan is online now
Find More Posts by SoloProFan
Did you check the FAQ already?
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Question
Transfer model settings between Devo transmitters?
I have a question, is it possible to transfer model settings from one Devo TX to another? And then not being the same version, but like one being a 6s and the other a 7E for instance? Or transfer to deviation equipped transmitters? Maybe with some conversion tool? Thing is, I have a very smooth setup on my 6S, but want to use a 7E as well, probably deviated, as one TX for most "birds". I could just copy settings one at a time, but since both transmitters have different interface, this can be prone to mistakes.
So maybe there is a better way>
SoloProFan is online now Find More Posts by SoloProFan
Old Jun 23, 2015, 06:54 AM
IM back! is offline
Find More Posts by IM back!
Joined Dec 2009
no, i fear devo -> deviation is not possible
IM back! is offline Find More Posts by IM back!
Old Jun 23, 2015, 07:30 AM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
So no way to convert settings from models stored in your Devo to model.ini files? So when you have quite a few helis in the memory of, say your Devo 10, you all need to input these all over again manually?
Old Yesterday, 06:46 AM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Ok, I have that 7E now, and want to set it up with the same settings as currently on my 6S. I tried to copy the settings manually, but it flies very differently with the 7E, lower headspeed, and tail doesn't stay locked on a throttle punch. I must be overlooking something. Really want the Mini to fly the same with the 7E as with the Devo 6, smooth and precise.
Help! Trying to transfer Futaba 8J models to SG 14 PWJClub78 Radios 9 Jun 15, 2015 09:18 AM
Discussion OSD system to transfer between 2 machines dirtz FPV Equipment 0 Mar 18, 2014 04:51 AM
Discussion Transferring model settings from Spektrum DX7 to JR X9503? racin06 Radios 8 Dec 08, 2011 11:11 PM
Discussion Transfer model data between Evo 9 and 12 scarab Radios 1 Feb 10, 2010 08:00 AM
Discussion Transmitter settings.. Transferable?? SKY KING Electric Plane Talk 0 May 19, 2006 08:20 PM
