Old Jun 17, 2013, 02:34 AM
Cookey12345 is offline
Find More Posts by Cookey12345
Joined Jun 2013
Return to home feature or GPS point to point for boats
l am wondering if it is possible to pre set a return to home point which would then engage when the transmitter is turned off or looses signal. l would imagine that the boat would then take a direct route to the pre set GPS point. Or is it possible to install a point to point or waypoint setup on a boat like l see they have for planes and pre set waypoints for the boat to pass. This would be great if the transmitter does not need to be in signal at all times???
Cookey12345 is offline Find More Posts by Cookey12345
Old Jun 17, 2013, 04:13 AM
tweety777 is offline
Find More Posts by tweety777
tweety777's Avatar
Vlaardingen, The Netherlands
Joined Nov 2008
This certainly is possible though it would require quite some experience in programming.
It might be better to use gyroscopes and a map which the onboard system can read and make the dock the home position after which the boat needs to keep track of her movement determining the location by adding the movement to the home location.
Greetings Josse
tweety777 is offline Find More Posts by tweety777
Old Jun 18, 2013, 02:02 AM
Dutchraptor is offline
Find More Posts by Dutchraptor
Dutchraptor's Avatar
The Netherlands, ZH, Hoogvliet
Joined Jul 2008
Use the Ardupilot/ArduRover software and board (or a clone version). Here you can make waypoints. It's a start. I use them on my quadcopters.
link: http://ardupilot.com/
Danny
Dutchraptor is offline Find More Posts by Dutchraptor
Discussion Is Magnetic Declination needed for DJI GPS to use Return To Home Fail Safe feature ? jasper7821 Multirotor Talk 4 Jul 28, 2012 03:25 AM
Discussion Whats a good quad controller with return home feature? superek4 Multirotor Talk 14 Jul 17, 2011 08:32 PM
Discussion Quadrocopter with GPS hold and return home when failsafe ??? TTcuatro Coaxial Helicopters 2 Sep 11, 2009 05:31 AM
Question GPS Return to home circuits? AXI Motor Models UAV - Unmanned Aerial Vehicles 20 Jan 06, 2009 06:58 PM
