Old Yesterday, 02:32 PM
flipflap is online now
Find More Posts by flipflap
Joined Mar 2009
Not sure this can help, but I once had a similar issue with an APM board, and finally the reason was that the jumper (to connect output and input power rails) was a bit oxydized. It then had a certain resistance, and caused a voltage drop.
Finally everything went fine with a servo cable between and output channel and an input channel (just the VCC and GND connected of course).
flipflap is online now Find More Posts by flipflap
Old Yesterday, 02:34 PM
TheQuestor is online now
Find More Posts by TheQuestor
Official Stupid Question Asker
TheQuestor's Avatar
United States, TX, San Juan
Joined Mar 2013
Originally Posted by geofrancis View Post
thats not right... how are you powering it when your measuring? if its a problem with the 5v being low then of course the 3.3v will be low
The thing about the reg is it's wonky. It can read 5 v if blown, it can read 0 v and it can read off if something else is not right.
That said plugging in anything to a powered APM is just begging to blow something. Kind of a poor design to be honest.
TheQuestor is online now Find More Posts by TheQuestor
Latest blog entry: QTipToo.8 Part 5
Old Yesterday, 04:23 PM
hydrasports is online now
Find More Posts by hydrasports
United States, FL, Hollywood
Joined Jan 2015
Please help, I tried everything, I setup my apm 2.6 on my quad and when I arm it the motors spin weird and very slow, they basically twitch no matter how much throttle I give it I could post s video or something but I'm at a loss!!! Please help
hydrasports is online now Find More Posts by hydrasports
Old Yesterday, 04:50 PM
magic_marty is offline
Find More Posts by magic_marty
<Marty>
United States, KY, Springfield
Joined Jul 2011
did u calibrate the esc's?
magic_marty is offline Find More Posts by magic_marty
Old Yesterday, 04:52 PM
thermanmerman is online now
Find More Posts by thermanmerman
Joined Mar 2015
The motors are supposed to automatically spin. This is a new setting with the new firmware. It Is set to very slow by default. This can be changed in mission planner to spin faster or turn the feature off completely. I wouldn't turn it off. It let's you know if there are any problems with motors or escs before you take off. As for the throttle problem have you calibrated your radio. In mission planner under radio calibration what are your ranges when throttling
thermanmerman is online now Find More Posts by thermanmerman
Old Yesterday, 05:02 PM
Joined Jan 2015
Yes I calibrated the escs and the radio, the motors don't even spin they just twitch, I wouldn't even consider it spinning, they make a weird noise and everything was working fine because it's all parts that I used on other quads
Old Yesterday, 05:29 PM
Madhampster is online now
Find More Posts by Madhampster
Madhampster's Avatar
Canada, ON, London
Joined Mar 2013
Make sure the screws that hold the motors on the arms arm not to long and cutting into the windings. Also remove the esc lead and connect it to the throttle channel on the esc and test one esc at a time.
Madhampster is online now Find More Posts by Madhampster
Old Yesterday, 06:18 PM
TheQuestor's Avatar
Joined Mar 2013
That is called Cogging.
There are basically 3 things that can cause this
1: one of the 3 wires going to the motors from the esc are not working so only 2 are making contact.
2: damaged motor
3: damaged ESC
There are other reasons but these are the main 3.
To test
Connect the signal/+/neg lead directly to port 3 on your receiver and power up your TX/RX then power the ESC, wait for the beeps to finish and raise the throttle. If the motor spins proper then you are ok. Do that for each motor/esc
At this point I would also do a throttle end point calibration. IE Throttle to max, plug in the ESC and wait for it to cause the motor to beep then throttle down and it should beep more then test by throttle up/down.
Old Yesterday, 06:36 PM
alcurtis93 is online now
Find More Posts by alcurtis93
United Kingdom, Dalton-in-Furness
Joined Mar 2015
A 5v bec into the output. It's giving out exactly 5.1v but I'm still reading the voltage I wrote above
alcurtis93 is online now Find More Posts by alcurtis93
Old Today, 02:19 AM
geofrancis is online now
Find More Posts by geofrancis
nothing is unfixable
United Kingdom, Scotland, North Ayrshire
Joined Feb 2010
Do you get same reading with the bec connected to input, output and analogue pins?
geofrancis is online now Find More Posts by geofrancis
For Sale ArduPilot Mega 2.0 + Accessiories (PRICE REDUCED!) tresani Aircraft - General - Radio Equipment (FS/W) 1 May 18, 2014 10:19 PM
For Sale ArduPilot OSD MinimOSD and other items for ArduPilot Mega Ecibob Aircraft - Electric - Multirotor (FS/W) 5 Jan 17, 2013 10:59 AM
Sold Ardupilot Mega APM 2.0, SONAR, MinimOSD, Telemetry, Quad PDB kingiggy262 Aircraft - Electric - Multirotor (FS/W) 3 Sep 18, 2012 02:13 PM
For Sale Ardupilot Mega APM V1/900 MHz Xbee/Bixler Chassis - $300 shipped justjason Aircraft - Electric - Multirotor (FS/W) 2 Jul 13, 2012 01:22 PM
Wanted Trade: My Ardupilot Mega (APM) for a Hover Fly Pro Adidas4275 Aircraft - Electric - Multirotor (FS/W) 2 Nov 21, 2011 08:26 PM
