Old Jul 19, 2012, 02:28 PM
4stroker is offline
Find More Posts by 4stroker
Closed Account
Joined Dec 2004
Shrinking tissue that's already been doped ?
Used the biege tissue that came with my Dare Wright Flyer . On the bottom of the wing it has two coats of very thin clear butyrate . It was shrunk with rubbing alcohol. Now , after a couple days drying , some of it is tight and some sags.
Anyway to tighten it now ? thanks , Walt
4stroker is offline Find More Posts by 4stroker
Old Jul 19, 2012, 02:41 PM
Wolpertinger is offline
Find More Posts by Wolpertinger
Formerly "vonJaerschky"
Wolpertinger's Avatar
Canada, BC, Comox
Joined Nov 2003
Apply another coat of clear dope. You didn't say what kind of clear dope was applied initially. Sig makes a low shrink clear called "Lite Coat". Did you use that or regular clear?
Wolpertinger is offline Find More Posts by Wolpertinger
Old Jul 19, 2012, 05:30 PM
4stroker is offline
Closed Account
Joined Dec 2004
It was regular fuel proof clear , not sure of brand , probably Sig . This problem is hanging me up on the project . .
Thanks for the help !
Old Jul 19, 2012, 06:03 PM
Canada, BC, Comox
Joined Nov 2003
Well, I'd try another coat of the same dope, but not thinned quite as much. If that doesn't work, then you can try some heat from a hair dryer or heat gun. Sometimes that helps, sometimes it doesn't. Good Luck!
Old Jul 19, 2012, 06:13 PM
PETERRAKE is offline
Find More Posts by PETERRAKE
Norfolk, England
Joined Sep 2001
Do they actually make fuel proof shrinking dope these days? It's a long while since I used dope, but shrinking dope was not fuel proof back then.
Pete
PETERRAKE is offline Find More Posts by PETERRAKE
Old Jul 19, 2012, 06:28 PM
Canada, BC, Comox
Joined Nov 2003
Pete
Don't know about Sig. Their product line seems to have shrunk or disappeared these days. I always preferred Brodak dopes. I found they always gave me a better finish. There products can be hard to find. Then I found out that Brodak's dopes are made for them by Randolph, who make full scale aircraft dopes and finishes. Turns out many of the colours are event he same. I stopped buying "Model" dopes quite a while ago, and now get mine from Randolph through Aircraft Spruce. A few months ago I needed some more clear nitrate and thinner, so I got a gallon of each. Much cheaper that way, too.
Old Jul 19, 2012, 06:54 PM
4stroker is offline
Closed Account
Joined Dec 2004
Pete
I can never remember whether it's nitrate or butyrate that shrinks . I remember I had some silk one time tha nitrate wouldn't shrink , but butyrate did .
Old Jul 19, 2012, 07:21 PM
Skycruiser is offline
Find More Posts by Skycruiser
I eat only vegetarian beef
Skycruiser's Avatar
Fairlie, New Zealand
Joined Nov 2006
Pretty sure it's nitrate that shrinks. And butyrate can go over nitrate, but nitrate can't go over butyrate.
Skycruiser is offline Find More Posts by Skycruiser
Old Jul 19, 2012, 08:20 PM
Deuce is offline
Find More Posts by Deuce
▄bung macht den Meister..
Deuce's Avatar
United States, OR, Fairview
Joined Jul 2006
I believe both shrink, but butyrate more so. In fact, it never really stops shrinking. It is the butyrate that is the fuel proof dope.
In my much younger, more na´ve years, I covered a Sterling Aeronca C-3 using straight butyrate dope. Wow! The wing had curved dihedral!
I still enjoy covering with tissue/silkspan and dope!
James
Deuce is offline Find More Posts by Deuce
Old Jul 19, 2012, 09:02 PM
olmod is offline
Find More Posts by olmod
Good Better Best quest.
olmod's Avatar
Australia, VIC, Cranbourne East
Joined Apr 2004
I have had some success by brushing some extra dope across the wrinkles at a right angle instead of recoating the whole surface.
olmod is offline Find More Posts by olmod
Old Jul 20, 2012, 08:50 AM
catrancher is online now
Find More Posts by catrancher
Veni, Vidi, Napi
catrancher's Avatar
Cumming, GA
Joined Sep 2004
Did you try Brodak's web site?
Tom
catrancher is online now Find More Posts by catrancher
Old Jul 20, 2012, 08:54 AM
Canada, BC, Comox
Joined Nov 2003
Shipping hazardous liquids like that to Canada would cost a fortune, if it was possible at all. There's actually an on-line hobby shop in Canada (Great Hobbies) that stocks it, so it's not that big a problem. If I need large quantities, I go through Aircraft Spruce. They have a Canadian warehouse, too.
Old Jul 20, 2012, 09:16 AM
Veni, Vidi, Napi
catrancher's Avatar
Cumming, GA
Joined Sep 2004
Ahhh.... forgot about the cross border issues. Naturally. It's an age thing.
Tom
Old Jul 20, 2012, 11:03 AM
killickb is online now
Find More Posts by killickb
killickb
killickb's Avatar
The Villages. Florida
Joined Jan 2005
Just covered my D-Rock Hurricane with Polyspan and dope -- for old times sake!
Got clear nitrate dope from both Sig and Brodak, shipped in mail, think I used both just to see difference, Brodak has more depth/shine to it. As stated here Nitrate shrinks, Butyrate shrinks and fuel proofs.
As to re shrinking, I never found a way to add shrink after the initial dope coats were dry even rubbing thinner over the surface and re coating. If you use at full strength might do it but might add warps also. Never found heating retained the tightness for long.
Re-cover job?
killickb is online now Find More Posts by killickb
Old Jul 20, 2012, 12:08 PM
4stroker is offline
Closed Account
Joined Dec 2004
Re-cover job?
thanks killckb , might have to bite the bullet !
Discussion What is the best way to free up a used engine that's been stored for years? tigreflyer Control Line 7 Jul 19, 2012 07:36 PM
Discussion The future's already here, it's just not evenly distributed dll932 Life, The Universe, and Politics 0 Jun 30, 2012 03:32 PM
Wanted anyone wth a Frsky RX that has the RSSI out to OSD mod/s already installed for sale? TheSelf FPV Equipment (FS/W) 2 Mar 11, 2012 09:11 PM
dope tissue/ heat shrink Pablo_s Scale Kit/Scratch Built 7 Aug 28, 2004 05:43 PM
Tissue Paper and Dope Covering Drewmotion Electric Plane Talk 3 Jul 24, 2001 08:05 AM
