Old May 25, 2015, 08:28 PM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
then....check all your solder joints. between the motor and ESC. And...what motor is it? Maybe it just isn't up to the task???
SteveT.
SteveT. is online now Find More Posts by SteveT.
Latest blog entry: My hangar...
Old May 25, 2015, 08:34 PM
6L6Amp is offline
Find More Posts by 6L6Amp
6L6Amp's Avatar
Northern Indiana
Joined Jan 2009
I can pretty much guarantee that it's the Gecko. I was having the same issues with my EF Torque 4016. The firmware update from Altitude Hobbies fixed the issue and now it works absolutely flawlessly.
6L6Amp is offline Find More Posts by 6L6Amp
Old May 26, 2015, 10:40 AM
Adam Stang is offline
Find More Posts by Adam Stang
Adam Stang's Avatar
United States, GA, Peachtree City
Joined Feb 2013
Originally Posted by M.Putnam View Post
Maiden flights done! I really like the way this plane flies. Power is strong with the Motrolfly 4315-714, but not overkill. Super stable in high alpha. Plane lands itself, no "ballooning" on approach. Might need a tad of mix for knifedge, hard to tell in breezy conditions. Again very impressed.
Nice job! What is your RTF weight?
Adam Stang is offline Find More Posts by Adam Stang
Old May 26, 2015, 10:55 AM
M.Putnam is offline
Find More Posts by M.Putnam
Shade Tree Aviation #2
M.Putnam's Avatar
United States, NC, Rutherfordton
Joined Jan 2002
Not sure... I will put it on the old fish scale tonight. It feels floaty in the air!
Update:
5 lbs 4 oz with 4s 4000mAh battery ready to fly.
5 lbs 2 oz with 4s 3300mAh battery ready to fly.
M.Putnam is offline Find More Posts by M.Putnam
Old May 26, 2015, 09:05 PM
Rich215 is offline
Find More Posts by Rich215
Rich215's Avatar
United States, CT, South Coventry
Joined Jun 2011
I still haven't heard back from Altitude Hobbies yet. I guess I'll have to call them tomorrow.
Does anyone have the file they can email?
BTW. I weighed mine and it's 5lbs 6oz with a 6S 3000 mah battery.
Rich215 is offline Find More Posts by Rich215
Old May 28, 2015, 06:41 PM
Rich215 is offline
Rich215's Avatar
Joined Jun 2011
You were correct. After flashing the firmware file, and reducing the start up current value, I reinstalled the ESC and no more knocking at quick acceleration.
Thanks everyone for the help, especially 6L6Amp for providing the file and instructions.
Old May 28, 2015, 06:54 PM
SteveT.'s Avatar
San Jose, CA
I'm very happy to hear that the info 6L6Amp gave you fixed your problem. And now I know what to tell people with this problem, so I learned something also...
SteveT.
Old May 30, 2015, 08:16 PM
M.Putnam is offline
M.Putnam's Avatar
Joined Jan 2002
Absolutely loving the 58" Edge! Got 4 flights on it today in low wind conditions. It is so stable that it makes you comfortable doing stupid stuff really low! Not even the slightest hint of wing rock in either upright or inverted harriers!
Old Jun 09, 2015, 09:13 AM
STANG KILLA SS is offline
Find More Posts by STANG KILLA SS
STANG KILLA SS's Avatar
Killeen TX
Joined Dec 2006
will this plane balance with 4s 3300 and a 42x50?(215ish gram)
anyone run this setup?
STANG KILLA SS is offline Find More Posts by STANG KILLA SS
Old Jun 09, 2015, 11:09 AM
6L6Amp is offline
6L6Amp's Avatar
Northern Indiana
Joined Jan 2009
Glad it worked out!
Old Jun 09, 2015, 01:29 PM
SteveT.'s Avatar
San Jose, CA
42X50 what?? But, I sincerely doubt that it will balance with a battery that small...
SteveT.
Old Jun 09, 2015, 01:54 PM
M.Putnam is offline
M.Putnam's Avatar
Joined Jan 2002
I am running the Motrolfly 4315 which weighs 280 grams. It required that my 4s 4000 be pushed all the way to the firewall and an ounce of ballast up front to balance. Great power and floats great. A motor that is 65 grams lighter will need weight added to balance.
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 02:45 PM
Sold 3DHS Omega 130g NIB 58.00 Shipped boatdoc Aircraft - Electric - Power Systems (FS/W) 9 Aug 28, 2011 09:16 AM
Discussion 3dhs edge 41" edge as second ish) plane? Mr Bloppy 3D Flying 19 Aug 25, 2010 09:43 AM
Wanted Wanted - 47" - 58" 3DHS, EF or Sebart plane paintball_kidz Aircraft - Electric - Airplanes (FS/W) 0 Jan 02, 2010 11:12 PM
Wanted 47"-58" size 3DHS, Sebart or Extreme Flight paintball_kidz Aircraft - Electric - Airplanes (FS/W) 13 Jan 02, 2010 12:52 AM
