Old Feb 23, 2011, 03:02 AM
brian1029hk is offline
Find More Posts by brian1029hk
Joined Feb 2011
Question
Sudden raise of rotor rpm...
Hi all,
Recently, I am trying to make my JR GSR 260 Voyager gasser back into condition.
I has not been flown for a year and I have spent almost 2 weeks to start the gasoline engine again...
However, the engine speed behaved so strange as I increase the throttle. As I increase the throttle to 30%, is maintain a rpm of 700-800. But the rpm does not raise as I keep increase the throttle until 60%. The rpm suddenly raise to 1500 as the throttle go over 60%... Same problem occurs even after warm up... Any clues to the problem?
The throttle curve is linear.
http://www.rcuniverse.com/product_gu...fm?kit_id=3802
it use a Zenoah G260PUH gasoline engine:
http://www.zenoah.net/node4103.aspx?nid=256881
brian1029hk is offline Find More Posts by brian1029hk
Old Jun 23, 2011, 10:04 PM
charlieoneseven is offline
Find More Posts by charlieoneseven
Aircrafting is noisey...what?!
charlieoneseven's Avatar
United States, CA, Long Beach
Joined Dec 2005
since you checked your throttle curve settings the next thing to check is the throttle linkage and arms.
On the zenoah carbs I reduced the spring tension on mine before hooking up a servo by moving the spring a couple of holes. You might be fighting that if the torque of your servo isn't above 30 in oz. Also check the set screw on the carb arm, since there isn't a flat spot it might be slipping, (don't ask me how I know about that) and re-locktite it.
charlieoneseven is offline Find More Posts by charlieoneseven
Video F-16, a sudden dip, and the light pole MyDigitalParadis Electric Plane Talk 6 Jan 03, 2011 03:24 PM
Discussion sudden burst of rpm corley45 Coaxial Helicopters 6 Jun 22, 2008 06:01 PM
Weird - sudden RPM drop bkammerer Electric Heli Talk 5 Dec 19, 2004 03:20 PM
RPM of Aerohawk tail rotor and tail rotor motor? Lynxman Micro Helis 0 Feb 01, 2004 08:01 AM
