Old Aug 02, 2009, 07:25 PM
2nude is offline
Find More Posts by 2nude
2nude's Avatar
Belgium
Joined Aug 2006
Scratchbuild something
I'm making something ...
I don't like working with plans so I make everything like I think it should be.
I bought a 90 mm edf from haoye models.
I took the motor out (4300Kv brushless inrunner) and mounted a 4,5 x 4,5 prop onto it!
Gave it a test while holding the motor and it gives ALOT of thrust.
I was too scared to go on at half throttle
So I want a plane for that motor.
This is what I have so far
LOOK AT MY MOTOR MOUNT:
It just clicks onto the plane. I can take it off and use it on other planes...
I think it's more then strong enough!
And a 60A esc:
I will use 3s 3300Mah 20C lipo's
Gonna give it huge skids so I can taxi/glide it over the grass.
I don't like to handlaunch it with a prop spinning at 50.000 rpm
2nude is offline Find More Posts by 2nude
Old Aug 02, 2009, 07:40 PM
Sky-walker is offline
Find More Posts by Sky-walker
Sky-walker's Avatar
Joined Jun 2005
I feel you need some canards ahead
Sky-walker is offline Find More Posts by Sky-walker
Old Aug 02, 2009, 07:57 PM
paulo810 is offline
Find More Posts by paulo810
"On the Wing"
paulo810's Avatar
Ohio
Joined Jul 2006
Let me know when your Lego unclicks itself in the air
Very clever but you might want to bolt or screw it before you turn it loose. I had a motor suddenly shoot out in front of the plane by itself once. Fortunately, the plane fluttered down like a leaf. It took a passerby who witnessed it and I about 5 minutes to find the motor and prop in the tall grass. It was a stick mount and I forgot to screw the gearbox down.
It would have made an amusing video.
paulo810 is offline Find More Posts by paulo810
Old Aug 02, 2009, 08:01 PM
2nude is offline
2nude's Avatar
Belgium
Joined Aug 2006
It'll not come loose, you'll see (I hope )
I try to film maiden flight.
And what do I have to loose ?
I still have lots of depron
Old Aug 03, 2009, 06:03 AM
2nude is offline
2nude's Avatar
Belgium
Joined Aug 2006
Old Aug 03, 2009, 08:56 AM
2nude is offline
2nude's Avatar
Belgium
Joined Aug 2006
Old Aug 03, 2009, 12:24 PM
enduro_man996 is offline
Find More Posts by enduro_man996
Yummy cheese
enduro_man996's Avatar
Earth
Joined Mar 2009
interestingly cool,
a 3300mah 3s battery may be a bit heavy for that amount of wing... from my experience. But with enough speed and the right cg it will propably fly.
I hand toss... and I still have 2 fingers left to control it with
http://www.rcgroups.com/forums/showthread.php?t=1025932
check out those vids
enduro_man996 is offline Find More Posts by enduro_man996
Old Aug 03, 2009, 03:28 PM
2nude is offline
2nude's Avatar
Belgium
Joined Aug 2006
Hey, very nice vids
Thanks !
I just tried mine, it was going like a rocket over the grass
but no lift, the nose too much down, can't get in the air.
So I added 2 small pieces of depron on the front of the 2 skids to get it a bit higher.
Tried again
It took off ! fast ! and then did some crazy ass stunts before I could get it on the ground again.
I think it was WAYYY to much tailheavy.
Will have to glue some parts again now ...
This was my funniest flight ever
2nd test soon ...
Old Aug 03, 2009, 04:50 PM
Yummy cheese
Earth
Joined Mar 2009
sounds like fun! haha...
honey hide the kids! here comes that infernal uncontrolable rocket again!
