Old Feb 05, 2009, 07:29 AM
ShadesOfGray is offline
Find More Posts by ShadesOfGray
Atlanta, GA
Joined Dec 2007
Vibration and cameras...
Hey guys,
I know most of you don't seem to get into vibration damping or anything like that, but a lot of you are flying easystars, which are both styrofoam and also pushers, which distances the camera from the motor.
I'm building a tractor (puller) airplane, made out of composites, and I'm mounting a KX-191 on the front of the plane, just behind the propeller (yeah, I know, the prop will make the video feed .... p.s. any suggestions on that?).
Will vibration be a problem for me?
Is there anything special I should do? (e.g. rubber mounting grommets or something?)
-Will
ShadesOfGray is offline Find More Posts by ShadesOfGray
Old Feb 05, 2009, 08:50 AM
typicalaimster is offline
Find More Posts by typicalaimster
typicalaimster's Avatar
United States, CA, San Diego
Joined Jan 2005
Just balance your prop. I put together a Nitro Planes cub and shot through the prop. That plane was a Balsa / Ply constructed plane.
typicalaimster is offline Find More Posts by typicalaimster
Old Feb 05, 2009, 10:15 AM
Blaze.45 is offline
Find More Posts by Blaze.45
Seeing the Farside.
Blaze.45's Avatar
Seattle WA, USA
Joined Aug 2005
Yep, balance de prop.
Blaze.45 is offline Find More Posts by Blaze.45
Old Feb 05, 2009, 12:22 PM
JettPilot is offline
Find More Posts by JettPilot
JettPilot's Avatar
Miami
Joined Apr 2005
Put the camera in the leading edge of the wing just far enough out that you are not looking through the prop. Its a bit of extra work but its worth it, you will be much happier flying with a clear view.
JettPilot
JettPilot is offline Find More Posts by JettPilot
Site Sponsor
Old Feb 05, 2009, 01:40 PM
Atlanta, GA
Joined Dec 2007
That's an interesting idea.... Is it still sufficiently easy to fly solely by reference to the video if the camera is mounted in the wing?
Old Feb 05, 2009, 01:55 PM
Terry S is offline
Find More Posts by Terry S
Terry S's Avatar
Bridgwater, UK
Joined May 2003
You don't notice the difference.
Terry
Terry S is offline Find More Posts by Terry S
Old Feb 05, 2009, 02:50 PM
JettPilot's Avatar
Miami
Joined Apr 2005
As terry says, you dont know the difference, except that you have a very clear, unobstructed view of everything The horizon is still in the middle which is level flight, all my planes have the camera in the wings.
Think about it like this, if you put the camera on the nose of your plane, you have the nose of the plane in the same place in the monitor all the time. It never changes. It would be the same as cutting out a pieice of cardboard, taping it to the bottom of the monitor and calling it the nose of the plane. It just sits there, never moving, blocking much of your precious downward view. Now immagine taking this peice of cardboard off the monitor, now you have a very clear view of everything, and the flying is exactly the same.
JettPilot
Site Sponsor
Old Feb 05, 2009, 03:12 PM
Blaze.45 is offline
Seeing the Farside.
Blaze.45's Avatar
Seattle WA, USA
Joined Aug 2005
I'd still balance the prop though
Old Feb 05, 2009, 04:47 PM
Atlanta, GA
Joined Dec 2007
Hmmm, I'm liking this wing mount idea. My only concerns are
1. Balance
2. Weird drag when I'm tilting/panning around.....
thoughts?
And yeah, I'll definitely have to learn how to balance a prop.
Old Feb 05, 2009, 04:52 PM
Atlanta, GA
Joined Dec 2007
Actually, come to think of it, I don't think a wing-mounted camera will work for my application, unfortunately. Our wing is a little undersized for our weight already, and anyway, since our UAV has to fit in a rocket, the bottom of the wing rotates over the top of the fuselage, and the top of the wing will be very close to be inner diameter of the rocket tube.... Might work, but it'd be hard...
Old Feb 05, 2009, 05:42 PM
billyd60 is offline
Find More Posts by billyd60
Gravity is patient............
Joined Mar 2006
I fly FPV helis and I use Zeal absorption tape at some point between the camera and the frame.
Here is one place that sells it:
http://www.readyheli.com/ZEAL_Vibrat...et_p/z8006.htm
The stuff is really sticky, but thick and soft. What I do is typically put the mounting screws right through it, but only tighten them enough to maintain the cameras position.
It's on the expensive side, but very good stuff.
billyd60 is offline Find More Posts by billyd60
