Old Dec 16, 2002, 12:20 PM
wanda is offline
Find More Posts by wanda
Slope or Slime Pilot
wanda's Avatar
Joined Nov 2002
OS LA Engines, any good?
Has anyone had any experience with any of the engines in the OS LA line?
wanda is offline Find More Posts by wanda
Old Dec 16, 2002, 02:21 PM
gregg f is offline
Find More Posts by gregg f
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
they are a good value for the price.....
gregg f is offline Find More Posts by gregg f
Old Dec 16, 2002, 02:52 PM
wanda is offline
wanda's Avatar
Joined Nov 2002
Looking for a little more info than that. I have other OS engines from the FX series, and I love them. Can I expect the same from the LA series? And if not, what problems might I encounter that I wouldn't with my FX engines?
Old Dec 16, 2002, 03:45 PM
gregg f is offline
Purple power
gregg f's Avatar
shadow hills,ca
Joined Apr 2000
they have less power than the fx. it's a bushing engine, so it will likely have a shorter life span than the ball bearing equipped fx......gregg
Old Dec 18, 2002, 05:31 PM
Ladyflyer is offline
Find More Posts by Ladyflyer
Still at it
Joined Nov 2002
If you want the same performance as your other OS engines at a lower price ,pick up a Thunder Tiger.
The LA is OK for the money but there are better values to be had.
Ladyflyer is offline Find More Posts by Ladyflyer
Old Dec 19, 2002, 06:27 PM
Star-Rider is offline
Find More Posts by Star-Rider
Los Angeles
Joined Feb 2002
Stonger than FX and Cheaper that LA
You should try GMS 47, its stronger than OS 45 FX by 200rpm and $70.00 shipped. Go to www.spadtothebone.com for free plans of cheap planes(>$5.00) made out of coropplast, also go to the forum for thousands of helpful friends. Ask about GMS engines and their opinions.
Check it out www.gmsengines.com
Star-Rider
Star-Rider is offline Find More Posts by Star-Rider
Old Dec 24, 2002, 02:02 PM
Tiggerinva is offline
Find More Posts by Tiggerinva
Richmond, VA
Joined Dec 2002
Good News and Bad News....
I've got 2 LA's, a .65 and a .25
First the bad news.....
I got the .65LA about a year ago and put it in a Superstar 60 trainer.
That thing did not want to go, it ran like a pig. When the engine was running it caused a lot of vibration which foamed the fuel which of course made the vibration worse.
The problem was probably not helped by the fuel tank installation on the Superstar. The tank is just slotted through a plywood bulkhead, so all the engine vibration is transmitted straight to the fuel tank. I was also using Cool Power which is a fully synthetic fuel.
I've now cut out the former, padded the tank with foam rubber and switched to SIG semi-synthetic fuel. The engine now runs a lot better, but I still think it needs more running in......
Now the good news......
I've also got a .25LA. That engine ran as sweet as a nut straight out of the box. I couldn't believe how smooth it was especially after my last experience. It also looks pretty cool with the matching blue muffler...Its a shame though that O.S. feel the need to charge an extra $25 for it.....
So there you go, 2 engines, 2 totally conflicting experiences. So what do I think? I might need a .15 soon, judging by the .25 I might still consider another LA. For a bigger engine though, as I've already got 2 LA's I'd look somewhere else...
Tiggerinva is offline Find More Posts by Tiggerinva
Old Dec 24, 2002, 07:03 PM
Los Angeles
Joined Feb 2002
OS L.A. are only good as paper weight!
Old Dec 24, 2002, 11:58 PM
chlee is offline
Find More Posts by chlee
chlee's Avatar
Atlanta, GA
Joined May 2000
Speaking of weight, you might try looking at the weights listed in the Tower Hobbies catalog, www.towerhobbies.com .
The LA series are quite light compared to other engines. If you are thinking of getting a .40, for example, I'd definitely consider getting a .46 so you can spare the nose-weight and have some extra horse-power.
-Chung
chlee is offline Find More Posts by chlee
Old Dec 26, 2002, 11:29 AM
PROACE is offline
Find More Posts by PROACE
Rocky Mountain High and Higher
PROACE's Avatar
Joined Jan 2002
2 LA 15's
I have two OS LA .15 and they both run excellent. Power is just a bit short of the FX series but it is reflected in the pricing. Both engines have had at least two gals of fuel through them and are still strong. I have noticed that a 15% nitro mix minimum is needed for good throttle response. The physical downfall is the plastic backplate for the needle valve. I went with remote needles and replaced the backplate with another plastic one from an OS car engine and eliminated the needle bracket.
PROACE is offline Find More Posts by PROACE
Old Dec 27, 2002, 01:07 PM
wyflyer_55 is offline
Find More Posts by wyflyer_55
Edmore, Michigan
Joined Apr 2002
I have a .40 and a .46 LA. They both run very well. I had the .46 LA in a Hobbico Air Vista. It has the fuel tank just pushed through a hole in two formers.(no padding) It ran very well.
I also have a Tower Hobbies .46 BB ABC. It has alot of power for the price. I think it might be a little hotter than my friend's OS .46 FX. I really like it and probably will buy another at that price.
wyflyer_55 is offline Find More Posts by wyflyer_55
Old Jan 05, 2003, 04:09 PM
Ed_Moorman is offline
Find More Posts by Ed_Moorman
Shalimar, FL
Joined Nov 2002
OS LA engines
A lot of people will tell you that the LA series isn't any good, but they are light weight and reliable engines. It is really unfair to copmpare them to a premium, ball bearing engine.
They don't have as much power as the FX engines. Well, of course. Just as car companies have low-pried and premium priced versions, so do engine manufacturers. They are plenty adequate for trainers and some fun fly planes.
They are light weight. Check the weights. Maybe you don't care about a few ounces, but a .46LA hardly weighs more than some high priced .32-.36 engines. That makes them good for powering a small fun fly plane like a PBF.
They are reliable. They have plain bearings so there is nothing to rust, forget the after engine run oil. Many that I see are abused by new fliers in their first plane and they still keep on running.
They are easy to run. The carbs are of the air-bleed type that is easy for new fliers to adjust. There are some guys that just can't seem to set an engine correctly, but they do OK on the OS LAs.
I have a .65 in a scale Douglas Skyraider that only gets flown 4 or 5 times a year. It cranks every time and pulls the Skyraider through lots of maneuvers.
That being said, in the .40 size, I prefer the Thunder Tigre .42GP. They, too, are a plain bearing, air-bleed type engine. I feel they have a little more power than the OS.
Ed_Moorman is offline Find More Posts by Ed_Moorman
Old Jan 05, 2003, 05:36 PM
rcav8r2 is offline
Find More Posts by rcav8r2
rcav8r2's Avatar
United States, PA, Beaver
Joined Sep 2001
THe LAs are basically the FP series with a new name, and of course new parts. They are good beginner engines. There is nothign wrong with them persay. Light, run rather well, easy to start, BUT.
They are low on power, ( which isn't a bad thing if you are aware of this up front) and my biggest pet peeve about them is parts.... I lost the teflon washer for the con rod from my .40 FP.... $25 Yikes !! That was quite a few years ago, and I'm not even sure I can get FP parts anymore. Same thing will probably happen to the LA when the marketing genious at great pains decides taht we need a new and improved version.
True they are bushed engines, and OS is a quality engine, so I'm sure other things will wear out before the bushigns do. My K&B .65 (bushings) is well over 10 years old, and I used to keep a log for 4 or 5 years, and in that time frame the Kadet had over 600 20-60 minute flights. That plain bushing engine is still going strong today. Personally I don't consider plain bushings a liablilty.
Bottom line... for the price I would probably consider something else, but if you are OS faithful you will be happy with this engine knowning it's down on power.
rcav8r2 is offline Find More Posts by rcav8r2
