Old Mar 21, 2012, 01:08 PM
unitoo1 is offline
Find More Posts by unitoo1
United States, IN, Merrillville
Joined Jan 2006
Question
Battery drained overnight?
I have a new 6v 2200mah ni-mh "hi-energy" receiver battery.
Last night Charged it at .25 amp for 2hrs. (i thought it would take longer)
reading was 7.6v charged.
I left my charger unplugged... but accidentally left the battery connected to the charger.
In the morning.. battery read 6.4v.. and charger said battery was <30% charged.
Question... Does leaving your battery connected to a unplugged charger drain the battery? Or is this a bad battery that drained itself overnight?
edit: charger is "vision peak ultra"
unitoo1 is offline Find More Posts by unitoo1
Old Mar 21, 2012, 01:12 PM
Mr. foambuilder is offline
Find More Posts by Mr. foambuilder
I fly 3-C Crash,Crunch,Crumble
Mr. foambuilder's Avatar
USA, NM, Clovis
Joined Feb 2010
Most chargers will drain a battery if left connected to a charger with no power input. You have a lot of circuitry in there, and it takes power to run it. Just plug it in, and be sure to remove the battery before removing power Roy BTDT
Mr. foambuilder is offline Find More Posts by Mr. foambuilder
Old Mar 21, 2012, 01:17 PM
unitoo1 is offline
Joined Jan 2006
Ty for your response. It makes sense what you are saying. Although, with the battery connected, the charger did not light up. And my charger has no cycle feature. So maybe I could use this technique to cycle my batteries also?
Old Mar 21, 2012, 02:14 PM
tacx is offline
Find More Posts by tacx
tacx's Avatar
United States, MI, Romeo
Joined Apr 2009
Your battery is still connected to electronics in the charger which will discharge the battery over time. You should never leave batteries connected to anyhting for extended periods of time. Even batteries in your flashlights will not last as long when left in the flashlight as they will if you remove them.
Some will say there is no way a flashlight thats turned off will discharge a battery, but they will. Ever wonder why every time you go for a flashlight it doesn't shine like it should. It's because you left the batteries in it and they slowly discharge. Try keeping your batteries out of your flashlights and see how long they last.
tacx is offline Find More Posts by tacx
Old Mar 21, 2012, 02:35 PM
pilotpete2 is offline
Find More Posts by pilotpete2
pilotpete2's Avatar
The Northeast Kingdom, Vermont
Joined Jun 2004
Another problem was that the battery almost certainly was nowhere near fully charged after only 2 hours at that rate.
A 250mAh charge rate is just a tad over 1/10C, so you'd need to leave it on at that rate for better than 14 hours to be fully charged. That 7.6V reading was most likely just a surface charge, especially if you weren't using a voltmeter that provided a load. Try a good formation charge over-nite and see how the capacity increases.
Pete
pilotpete2 is offline Find More Posts by pilotpete2
Old Mar 21, 2012, 02:43 PM
unitoo1 is offline
Joined Jan 2006
Pete
Wow Pete. this really is informative. TY.
I am in the market for a better charger. But currently this one does not measure with a load.
After 2 hours my charger beeped and showed 4 bars (like a cellphone) fully charged. After it beeps, all it does is trickle charge. So im a bit confused why my charger said it was fully charged
also, what do you mean "good formation charge"
Does that mean try to charge it at 1c? or something?
Or should I just leave it to trickle all night?
Old Mar 21, 2012, 03:02 PM
solentlife is offline
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
For original poster ..... it is worth knowing that a NiCD or NiMH battery will show good voltage right up until just before its flat.
The discharge curve of a rechargeable battery is near flat and is why they are much better than dry-cells. Initially a dry-cell shows 1.5V but under load it is significantly less often below 1.2V and falls of at a steady rate as it discharges. A rechargeable cell, even though it initially shows 1.25 - 1.3V is far more able to sustain its voltage under load and has a flat discharge ...
When charging a NiMH or NiCD ... with only a small amount of charge - you will see a voltage that without sophisticated good measuring meter will appear full charge. You must charge for full period to be sure it's actually charged.
solentlife is offline Find More Posts by solentlife
Old Mar 21, 2012, 04:09 PM
flydiver is online now
Find More Posts by flydiver
flydiver's Avatar
United States, WA, Seattle
Joined Jan 2007
To put it bluntly, unloaded voltage (pure voltage reading) is almost completely worthless for determining the capacity stage of an NiXX battery.
The only reliable way to do that is a 1/5C monitored discharge from a battery known to be charged at 1/10C for 15 hours and rested for a bit.
You will lose up to 10% of an initial charge in the first 24 hours just sitting. That is completely normal.
flydiver is online now Find More Posts by flydiver
Old Mar 21, 2012, 05:21 PM
solentlife's Avatar
Joined Jan 2010
Bluntly ................ isn''t that what I said .............. but of course you are wrong in one sense .............. IF battery is completly fully charged - then voltage reading is correct.
Old Mar 21, 2012, 11:07 PM
unitoo1 is offline
Joined Jan 2006
I guess this is my problem. My charger shuts off after it auto detects that the battery if fully charged. then it initiates a trickle charge. I could go into boost mode which fast charges the battery every minute. but I have not used that feature.
The only thing I can do is leave everything connected and let it trickle charge. Take battery to the field tomorrow. and have someone load test it.
or maybe I should try and charge at 2.2 amps and just see what it does...
and yes both of you are really correct in that.... I need a load tester
Old Mar 22, 2012, 08:08 AM
solentlife's Avatar
Joined Jan 2010
Forget all about load testers and that kerfuffle .... here's the KISS way to do it.
Charge up on your auto detect charger. Let it charge and kick out to trickle charge. Disconnect and let battery rest for 15 mins or so.
Get a suitable voltage flashlight bulb ... one of those screwdriver test lamp thingees in tool-box is good. Now check time ... connect lamp ... keep checking back to see if light is fading .. when it starts to fade - disconnect noting time.
You can then work out the mA capacity ......... or just accept that if the lamp runs for a good time ... battery is fine ! A bad battery will run for very short time only and is usually very obvious.
This is best DIY way to check a battery / cycle one.
Old Mar 22, 2012, 10:42 PM
unitoo1 is offline
Joined Jan 2006
welp that is a pretty cool DIY! I have one of those testers around here someplace I will do it as an experiment. (because its fun) Although I do love gadgets. and a load tester is pretty cheap. I will do both
Update: I plugged up my discharged battery onto my charger again. .25 amp charge. and it took 2 hrs again. the same as before. But.... This time the battery was actually warm (a good thing) where last time it was not. (very weird) so I took it to the field and a buddy load tested. it tested good. 7.4v with load if i remember correct. So I guess all is good.
1) I now know that my charger (if unplugged) will discharge a connected battery pack. I will assume it might discharge battery to dangerous levels if left connected accidentally.
2) I now know a cool DIY tester. and that a load tester is valuable also.
either way, you need to test battery with something other than a cheaper charger. due to the chemistry of certain batteries.
Thanks guys !!
Old Mar 23, 2012, 03:45 AM View Post
eileen
A moderator felt this post violated the following rule: Off Topic Advertisement. Show it to me anyway.
Question Trying not to drain the battery on Honey Bee V2... mihax209 Micro Helis 14 Apr 10, 2012 05:06 PM
Question 450 has more lift as battery drains GooberSB Electric Heli Talk 36 Mar 16, 2012 03:48 PM
Alert Fun rc helicopters with low overnight shipping! RCTO Hot Online Deals 0 Dec 21, 2011 08:38 PM
Discussion Vintage thermal snifflers (varios): high battery drain or low drain? arukum17 Batteries and Chargers 0 Nov 05, 2007 05:19 AM
