Old Apr 02, 2010, 12:50 AM
parambir's Avatar
United States, WI, Evansville
Joined Aug 2008
Help!
Ticking !!!
Has anyone experienced this. I was flying my slowstick with BL motor 2410-12. Had a decent flight for 15 mins and landed well. Wanted to go for a second flight but the motor would not start. It only gave ticking sound (not beep but tick) one per second. I disconnected the battery and ESC and tried everything. But the ticking would not go away.
There is no damage to motor and the coils are ok. The ESC also seems ok. Earlier when I connected the ESC to LiPo, it would give me a single beep saying all okay ... go fly. But that beeo has also gone ?????
Help... I hardly get peaceful days to fly...
parambir is offline Find More Posts by parambir
Old Apr 02, 2010, 08:19 AM
Frequent Flyer
whitecrest's Avatar
Orleans, MA
Joined Feb 2007
When it first started ticking, I would have suspected a bad connection to one of the motor wires or an obstruction in the motor preventing proper rotation. It is very easy for a motor to ingest a bit of magnetic grit that lodges in the small gap between the stator and rotor (happened to me). If the motor can't turn properly, it is possible for damaging currents to flow. That might account for the absence of an arming tone in the ESC later.
whitecrest is offline Find More Posts by whitecrest
Old Apr 02, 2010, 11:15 AM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Agreed. It's probably a bad connection. Check your connectors between the ESC and motor. They should be very snug.
IBCrazy is offline Find More Posts by IBCrazy
Old Apr 04, 2010, 03:34 PM
Registered Aircraft Offender
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
Bad bearing, magnets striking the stator... from my experience those are the prime suspects when it comes to a "ticking" noise. If fixing the connection doesn't work, pull the motor apart and inspect the stator heads for scrape marks. Even a small bit of shine indicates a problem, which is often fixed by cleaning the magnets with tape and blowing out the stator with compressed air. Also spin the bearings while it's apart. Listen carefully; a "gritty/grinding" sound indicates a bad bearing.
Kev
Truglodite is offline Find More Posts by Truglodite
Old Apr 04, 2010, 03:50 PM
parambir's Avatar
Joined Aug 2008
Thanks guys but I have changed the ESC and it works fine now. the same ESC is causing ticking in other motor too so I guess ESC has konked off but then there are no indications of burn, heating, physical damage nothing... strange
Old Apr 07, 2010, 05:45 PM
Yep I got another one.
mohillbilly's Avatar
Springfield, Mo.
Joined Jan 2005
Check the servo plug on the ESC, I bet the signal wire came off the ESC.
mohillbilly is offline Find More Posts by mohillbilly
Old Apr 09, 2010, 04:56 AM
7000mw of raw power!
rich smith's Avatar
New Hampshire (not the old one)
Joined Dec 2006
Finally... proof positive a free energy device exists!
Either that or Parambir is not telling the truth.
rich smith is offline Find More Posts by rich smith
Old Apr 09, 2010, 06:30 AM
parambir's Avatar
Joined Aug 2008
There is no reason why I should be lying... or maybe you think because I seem to have done my homework before posting the thread...
Old Apr 09, 2010, 07:46 AM
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
whoosh!
Old Apr 09, 2010, 08:32 AM
rich smith's Avatar
Joined Dec 2006
Mankind has been searching for free-energy/perpetual-motion for centuries.
If you can really get the motor to continue ticking (or any sound at all) w/o power then get in touch. We will be trillionaires before end of year.
Bill Gates will be our chauffeur and Warren Buffett will do the laundry.
Old Apr 09, 2010, 08:45 AM
Frequent Flyer
whitecrest's Avatar
Orleans, MA
Joined Feb 2007
... We will be trillionaires before end of year.
Just ask Pons and Fleischmann.
Discussion Got my Mini SuperCub tonight! Ticking sound from engine? JelloStorB Beginner Training Area (Aircraft-Electric) 3 Feb 20, 2010 02:25 AM
Discussion Clock is ticking for Incompentano MtnGoat Life, The Universe, and Politics 3 Jan 02, 2010 08:28 AM
Discussion 4#3b single brushless - tail "ticking" mortato Micro Helis 5 Sep 09, 2009 06:57 AM
Help My Pack is ticking!? mrebman Parkflyers 4 Feb 25, 2003 04:10 PM
I hear a ticking.. GForceStress Parkflyers 7 Oct 23, 2002 06:55 PM
