Old Feb 28, 2015, 10:46 AM
The Man BEHIND the frog, ugh
Chophop's Avatar
Pleasant Valley Modelport
Joined Sep 2006
Look at this New Escapade MX, a Real Gasser
I just bought a nice sturdy Escapade 61, now look what came up for $100 more, Escapade MX.
http://towerhobbies.com/products/gre.../gpma1210.html
Chophop is offline Find More Posts by Chophop
Old Mar 02, 2015, 01:54 PM
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
It is a nice looking plane. Not quite a mid wing design though. But over time I am starting to lean more towards planes that make it easy to set them up for electric power. Thus it is easy to swap out the battery packs in them. Of course, in my opinion, it doesn't look like a Escapade, so I think they should have named it something else.
earlwb is offline Find More Posts by earlwb
Latest blog entry: My new Gaui X5 Rc Helicopter
Old Mar 02, 2015, 02:24 PM
Chophop's Avatar
Joined Sep 2006
It looks like a big Escapade 61 with the wing raised, less chance of snagging one.
Old Mar 02, 2015, 06:58 PM
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
I think that they were trying more for a 3D aerobatic plane with it myself.
Old Mar 02, 2015, 07:03 PM
Chophop's Avatar
Joined Sep 2006
naaaaa, look at the ailerons. And here's the description :
Designed for 30-35 cc gasoline and electric power, the Escapade MX is a sport pilot’s dream come true. Not only does it handle low-speed maneuvers and high-speed aerobatics with equal authority, its low parts count and self-aligning tail surfaces help keep assembly time to a minimum. Compatible with 63-62-250kV brushless motors like the RimFire 1.60, the Escapade MX executes snap rolls, stall turns, inverted flight and every move in between. A high-visibility MonoKote trim scheme, painted fiberglass parts and prehinged control surfaces maximize convenience – while minimizing work!
I feel a lot more at ease with sport aerobatics. Too scared to risk the plane on 3D.
Old Mar 02, 2015, 07:47 PM
United States, FL, Citrus Springs
Joined Aug 2008
That why they invented the electric foamies. Very addictive on their own, with the bonus you can beat the tar out of them while learning 3D moves that will translate directly into your bigger planes (sport or 3D!)
ahicks is offline Find More Posts by ahicks
Old Mar 02, 2015, 11:24 PM
Chophop's Avatar
Joined Sep 2006
I had forgotten to make one.
Old Mar 03, 2015, 01:30 PM
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Well they are saying it can handle low speed maneuvers. So it may have enough control surface area to do some stuff with. Granted you probably don't want to try it down low until you figure out what it can do and can't do though.
Old Mar 03, 2015, 01:49 PM
Chophop's Avatar
Joined Sep 2006
Big and easy to see. That's what I need.
Old Mar 05, 2015, 06:31 PM
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Yes that is a nice big one for sure. I like the size too. I am sort of looking for something like a giant Kaos style of plane myself.
Old Mar 05, 2015, 08:30 PM
Chophop's Avatar
Joined Sep 2006
I definitely like this ARF thing. I didn't gain any style by doing a stick type scratch build. But I have a beater that costs as much as an ARF. I started whittling that thing out last May.
A good builder really can have that Escapade 61 in the air in a few hours, nothing to it. All major components that screw together. The 30cc Escapade MX will probably be the same.
Old Mar 26, 2015, 08:53 AM
nh4clo4
USA, MN, Marble
Joined May 2010
These are now in stock and shipping. Mine will be here this week.
nh4clo4 is online now Find More Posts by nh4clo4
Old Mar 26, 2015, 12:12 PM
vicrider's Avatar
United States, OK, Claremore
Joined Jun 2012
I just ordered one from tower yesterday. $300 but coupon code took $30 off and also free shipping. I don't think I can go wrong for $270.
vicrider is offline Find More Posts by vicrider
Old Mar 26, 2015, 12:22 PM
Chophop's Avatar
Joined Sep 2006
They just got Revolvers in also. I just started assembling my Escapade 61. So far, just a small problem with slop in the bolt-on tail and the motor mount that is for 1.20 engines max is not easily accepting the DLE 20 without some mount slot extending . On another plane I used the 1.20-1.80 mount and it was out of the package and motor bolted on.
The receiver battery is intended for under the cockpit, needing to remove the wing to change it. So I removed the pilot figure from duty and assigned a CDI + battery under the canopy now.
And I need to hinge the canopy instead of screwing it in.
Some minor details to work on ARF's but better than the May to December long way up with a total scratch build I finally have flying.
Old Mar 26, 2015, 01:04 PM
nh4clo4
USA, MN, Marble
Joined May 2010
As a tower member I got 10.00 off and 45.00 off a 289 order for a total of 245.99
I don't think you can go wrong, unless it is a piece of crap, But GP is usually pretty good.
Sold Escapade MX shaobri8 Aircraft - Electric - Airplanes (FS/W) 3 Jan 22, 2015 04:18 PM
Help! Escapade MX Motor Mount Progjazz Electric Plane Talk 2 Jan 09, 2015 08:31 AM
Question GP Escapade MX Wing Spar / Dihedral N410DC Fuel Plane Talk 0 Dec 01, 2014 09:31 PM
Cool WOW look at this for real holtneil Electric Plane Talk 4 Jan 14, 2014 09:55 PM
Sold Helimax mx 400 pro owners look at this rudyhal Aircraft - Electric - Helis (FS/W) 2 Mar 23, 2009 08:13 PM
