Old Sep 24, 2013, 05:52 AM
Joined Sep 2013
Help!
[newbie] how to control a model with my PC via TX9 ?
Hello,
I would like to know if the following idea is possible.
I want to connect my PC to a turnigy TX9, configured as "trainee", via a jack/jack cable to control a model.
If it is possible, where can I find infos to encode the signals for the TX ?
Thanks in advance,
Fabien
Fabien R is offline Find More Posts by Fabien R
Old Sep 24, 2013, 10:43 AM
ttabbal's Avatar
United States, UT, Herriman
Joined Jan 2012
I've never seen it done, but that shouldn't be too hard to do. The signal format is PPM. There is plenty of info out there for how to create the proper pulses for it. You could probably use the audio output of your computer for it. At least, you can read them with the mic port, I've done that to use a simulator program on the computer with my TX as the controller.
ttabbal is offline Find More Posts by ttabbal
Old Sep 25, 2013, 01:02 AM
Romania, Dolj, Craiova
Joined Sep 2007
Check for Flytron USB PPM cable.
Cost more than your 9X though
renatoa is offline Find More Posts by renatoa
Old Sep 25, 2013, 11:43 AM
Joined Sep 2013
Thanks ttabbal,
I will experiment what this guy showed here
Question Newbie Question... How do I get my Fat Sharks to work with 1.3 UHF? Doostur FPV Talk 2 Jul 14, 2013 07:01 PM
Mini-HowTo DIY 2.4ghz RC Control Via PC rich smith DIY Electronics 67 May 22, 2009 06:34 AM
Help! Control your RC Via your PC dasc Electric Motor Design and Construction 3 Mar 03, 2009 08:40 PM
Discussion Controllers that can connect to PC via USB? Amoroso Simulators 12 Dec 04, 2007 11:53 AM
Discussion Easist way to control a motor via a PC? Rufe0 DIY Electronics 10 Jul 14, 2007 04:05 PM
