Old Apr 03, 2014, 11:34 AM
United States, MA, Lowell
Joined May 2004
I follow a great thread called Power Systems for Extreme Flight Fanatics here on RCG. There was some discussion about the very latest firmware for the Edge ESC and the consensus is that it is still restricting power on the 28 pole motors like the A60-6XS. You'd be better off buying a used ICE or ICE 2 controller. I actually found a new CC ICE2 HV80 controller on eBay.
Neil_SC is offline Find More Posts by Neil_SC
Old Apr 04, 2014, 10:19 AM
United States, AZ, Tempe
Joined May 2009
This is an unfortunate situation for Castle - the good news is that the Hacker ESC's have always worked!
aeromodel is offline Find More Posts by aeromodel
Site Sponsor
Old Apr 06, 2014, 10:29 AM
That sure does get small quick
United States, NE, Kearney
Joined Jun 2004
hacker a60 6xs v2 question
I was thinking this motor was designed for 6 cell packs and was reading on another forum where a guy was using 8 s packs and am trying to figure out which way to set up. I was going to go with the 3dhs 71" slick and have the a60 6xs v2 with a castle ice 100 and CC Bec pro and was going to use single 6s 5000 mah packs and 35c discharge with a 20x10 prop. But when I ran the calcs on the castles motor diagram it is saying I need to go with a smaller prop. Anyone have some set up recommendations?
outofsight is offline Find More Posts by outofsight
Old Apr 06, 2014, 04:08 PM
Mrloseth's Avatar
Joined Jan 2013
Mejzlik 20x11we the best prop
I have tested. 120a max 6500 rpm 157kmt toppspeed (gps) perfect on my gens ace 5000mah
5 min flight 28% left using master mezon 120a
Mrloseth is offline Find More Posts by Mrloseth
Old Apr 06, 2014, 05:30 PM
jason360's Avatar
Joined Oct 2007
Get a CC Ice 100 esc. The edge 100 has lots of problems with the 28 pole motor.
jason360 is offline Find More Posts by jason360
Old Apr 07, 2014, 03:19 AM
Mrloseth's Avatar
Joined Jan 2013
Hacker A60-6XS‏
Why not use hacker master mezon that work 100% :-)
Old Apr 07, 2014, 10:23 AM
jason360's Avatar
Joined Oct 2007
Mrloseth,
Do you know a good place to buy them? They look to be pretty expensive.
Old Apr 07, 2014, 10:47 AM
Joined May 2009
Jason,
You can of course buy them from us at Aero-Model, or any of our dealers.
The Mezon ESC's are comparable in price to Castle, but as mentioned - they work as they are supposed to
Site Sponsor
Old Apr 12, 2014, 05:23 PM
Quando Omni Flunkus Moritati
mm2icbm's Avatar
United States, OK, Oklahoma City
Joined Feb 2013
My Edge 160HV is as worthless today as when I bought it a year ago. Waited 6+ months for Castle to put out an updated firmware which proved to be a worthless as the Edge HV. Castle even had the nerve to say the problem is my Hacker Q80. Shows just how little CC knows about Hacker motors.
So late last year I bought a Jeti Spin PRO 200 (I think Jeti & Hacker/Mezon must collaborate closely together because their ESC's look strikingly similar.) Anyway, my Spin Pro works flawlessly and in all honesty, with all of the problems Castle has had over the past three years, I will probably never buy another CC ESC. The only thing I miss is the extensive logging feature of Castle ESC. But that isn't enough to draw me back to buy their ESC's.
The bottom line is buy a Mezon or Jeti ESC and stop throwing your money away.
mm2icbm is offline Find More Posts by mm2icbm
Old Apr 12, 2014, 09:40 PM
jason360's Avatar
Joined Oct 2007
I am swapping out the Edge 100A too! CC should have had this 28 pole issue fixed by now!!
Going to try out this Hobbywing 100A HV ESC. A guy at my club seems to like the Hobbywing ESCs. It may prove to be a inexpensive option compared to the Hacker/Mezon ESC's.
http://www.hobbywing.com/product_show.asp?id=195
I ordered through this US distributor:
http://www.falconsekido.com/
Old Apr 13, 2014, 09:06 AM
mm2icbm's Avatar
Joined Feb 2013
Once you have received the HW ESC and have had a chance to try it out, please post and tell us what you like/dislike about it. What motor will you be using with this ESC?
Old Apr 13, 2014, 10:52 AM
jason360's Avatar
Joined Oct 2007
Sounds good. Will report my results with the HW 100A ESC. I will be using it with my hacker A60-6XS. 3DHS 71" Slick airframe.
Old Jun 05, 2014, 10:48 PM
Joined Sep 2011
I ran mine today with a soar 20-10 and a xoar 20-8 and an APC 19-10 and I felt like the APC was the best choice for a 10 lb 3dhs extra 330 72" ws. What is an acceptable temp for this motor? I can fly 5 min and have 37-40% of battery life left on a 5300mah align 40c discharge battery.
Dunkel is offline Find More Posts by Dunkel
Old Jun 06, 2014, 03:34 AM
Joined May 2004
Hacker A60-6XS‏
I had an A60-6XS on a 3DHS 74 Edge. Even with a 21x10 it felt weak. I never even tried a 20X10. But the Edge is probably a pound heavier than the 330 SC. I would recommend a Xoar 21x10 for the 330 SC as long as you have the ground clearance. Will pull about 90A which is still ok for an ICE 100. I had to put an APC 20.5X12 on it to get anything close to the power I wanted but that was pulling 105A max. It got to about 178F on an 85F day. I opened up the canister tunnel and max temps dropped to about 150F so I recommend that.
Old Jun 26, 2014, 09:01 PM
United States, AL, Clanton
Joined Apr 2013
Neil was this the 4.19 firmware?
Darrellmims is offline Find More Posts by Darrellmims
Wanted Hacker A60-6xs JoeR Aircraft - Electric - Power Systems (FS/W) 1 Jul 29, 2013 10:29 PM
Found Hacker A60-6XS XtremeWingRC Aircraft - Electric - Power Systems (FS/W) 2 Jul 02, 2013 05:59 PM
Sold Hacker A60-6XS and Castle ICE 100 rgandee Aircraft - Electric - Power Systems (FS/W) 1 Jan 15, 2013 06:22 AM
Discussion Hacker A60 6XS 28 V2......ESC choice? JEFFRO503 Power Systems 2 Jun 21, 2012 12:22 AM
Discussion Hacker A60-6XS V2, is a 12s lipo okay? benaresenferno Power Systems 0 Jun 25, 2011 09:33 PM
