Old Feb 13, 2015, 08:30 AM
AJ_Aircraft's Avatar
Joined Dec 2014
AJ Aircraft 56" AJ Laser 230z
Official thread for the 56" AJ Laser 230z.
Purchase here.
Build manual here.
The 411:
Wing Span - 56"
Length - 54"
AOW - 4-4.5 lb
Power - Hacker A40-10S, 90amp ESC, 4s 3300mah lipo
Radio - 5 channel with 4 high torque mini servos
What's in the box:
Carbon reinforced landing gear mount
Pre-hinged and sealed control surfaces
Carbon main gear
G-10 control horns
Dual ball links for all connections
Carbon wing tube
Optional SFGs included
Genuine Oracover covering in 2 color scheme choices including the AJ Competition Scheme
AJ flies this airframe with the following equipment:
Hacker A40-10S
Xoar 15x6 or 14x7 prop
Castle Talon 90 ESC
Thunder Power 4s 3300mah G8 Pro-Lite+ 25C Lipo
4 Hitec 85MG, Hitec 5085, or Hitec 5087 servos
Also needed to complete:
2x 6" extensions for the ailerons
1x 12" extension for the ESC
1x 18" extensions to the elevator
2" or 50mm spinner
AJ_Aircraft is offline Find More Posts by AJ_Aircraft
Site Sponsor
Old Feb 13, 2015, 08:31 AM
Joined Dec 2014
reserved
Site Sponsor
Joined Dec 2014
WIKI - Want to add a loadout, tips or something else to this post? Send us a PM and we'll get it added!
Site Sponsor
Old Feb 13, 2015, 12:12 PM
I want just one more plane!
timwj1's Avatar
United States, ID, Idaho Falls
Joined Feb 2013
subscribed
timwj1 is offline Find More Posts by timwj1
Old Feb 13, 2015, 12:14 PM
Lopflyers's Avatar
United States, FL, Orlando
Joined Jun 2012
A picture of mine, flies excellent. Beautiful, everybody at the field has comments about her.
Good job Jeskys
Lopflyers is offline Find More Posts by Lopflyers
Old Feb 13, 2015, 12:56 PM
Time to Fly AJ's Best!
heritageflyer's Avatar
Hills of Eastern Ohio
Joined Nov 2008
Power System all wired up, Firmware Updated and BEC set to 7.4v for the 5087MH Servos.
heritageflyer is offline Find More Posts by heritageflyer
Old Feb 13, 2015, 12:57 PM
United States, CA, Chico
Joined Mar 2014
Specs on Mine:
56" AJ Laser 230z Competition Scheme
Motrolfly 3615-470 on 6s (15mm standoffs)
Zippy 40c 6s 2200 & 1800
Castle Talon 90 @ 8v
(4) HS-5087's
Spektrum AR6200 & Sat
Vox 15x7 Prop
PA 2" Carbon Spinner
PA Extra MX Wing Bags
this setup yields 1164 watts @ 48.1A in a 4.25lb plane (6s 2200)
My build is going well. Only exception I have had is on the Elevator. The Stab Slot had a huge hump In the front 1/3 of the slot. I got that sorted and then the Elevator halves seem twisted on the right. I aligned the tail tips when epoxying the halves together and let the leading edges float as necessary. The right side leading edge is about 3/32" low compared to the stab. Hopefully it flies ok. If not Ill order another stab and Elevator halves and give it another go. Oh and on my elevator halves the left side had the cross brace installed, not the right as in the manual. Is this a manual error or a manuf issue?
Cant wait to maiden tomorrow or sunday!
mxracer33x is offline Find More Posts by mxracer33x
Old Feb 13, 2015, 01:13 PM
Joined Nov 2008
All you should have to do is Heat Gun the Elevator Half a little on the side you need to level and Twist just past center a tad and hold, remove heat, hold while cooling. Doesn't take much and can try again if too much or not yet enough.
(Blue Tape the opposite Elevator Counter Balance to the Stab before doing this.)
Old Feb 13, 2015, 01:35 PM
Grand Rapids, MI
Joined Jun 2005
I had the same problem with my ele halves. Heat gun tip from heritage worked great on mine.
Hornetnz is offline Find More Posts by Hornetnz
Old Feb 13, 2015, 02:52 PM
Joined Mar 2014
Thanks Guys! I think this model specific thread will pay off on little issues like this. Less wading and more flying!
Old Feb 13, 2015, 03:48 PM
Hay Pilot
United States, TX, Fayetteville
Joined Mar 2013
Maidened mine today with a Motrofly 3615-750, Talon 90, and HS-5087's, with a 4S-3300 on a 14x7 prop. Must say this was a real pleasure to build, and it flew great, other than it was a little quick for my skills. After a couple of minutes I was able to be smooth, but it looked pretty ugly there at first. For my next flight I will be moving the battery forward some more, which should get the CG all the way to 95mm from the leading edge. I can imagine what this plane would fly like with a good pilot. Great job Jesky's, and thanks.
Chascall is online now Find More Posts by Chascall
Old Feb 13, 2015, 07:58 PM
Huckin around the Shire
Enterprise7's Avatar
USA, NH, Manchester
Joined Jun 2010
Mine is setup for the 4315-480 on 6s 2200. My dad has it and I will get it back at SEFF. With the winter we are having, that might be my first chance to fly airplanes this year.
Enterprise7 is online now Find More Posts by Enterprise7
Old Feb 14, 2015, 08:07 AM
I like the violent stuff!
Costa Mesa, CA
Still on the fence about a motor for my 56". Curious about the 2 Motrolfly 6S options. Guy at the field has the 3615 on 4S, flys great but could use a little more power. I'm leaning toward the 3615 6S so I can keep the rudder servo in the middle. Thanks.
Wingin' Wayne is offline Find More Posts by Wingin' Wayne
Old Feb 14, 2015, 02:15 PM
Wingman II
diggity2424's Avatar
United States, KY, Louisville
Joined Sep 2011
sub'd
diggity2424 is online now Find More Posts by diggity2424
Old Feb 14, 2015, 02:51 PM
Rouge Field
tuck's Avatar
United States, CA, Citrus Heights
Joined Feb 2009
I Love mine on 4s, MF 3620 750 though. 14x7 with anywhere between 2150-3600 mah. Monster power, super light. Only thing I would say is a must, would be the hs5087 at 7.4v-8.v everything else is interchangeable.
tuck is online now Find More Posts by tuck
Discussion 93" Aj-aircraft lazer 230 Alkaline 3D Flying 8 Feb 12, 2015 07:18 PM
Discussion *New AJ 93" Laser 230z * olezippi Giant Scale Airplanes 3 Jan 20, 2015 06:13 AM
Discussion AJ-Aircraft Laser 230z 56" with Pilot odejay 3D Flying 1 Sep 05, 2014 11:18 PM
News Andrew Jesky - AJ Aircraft L73" Laser 230z Jim T. Graham 3D Flying 16 Jul 25, 2014 06:25 PM
Discussion AJ's new Laser bsbauman Atlanta Area RC 2 Jan 27, 2014 03:40 PM
