Old Dec 25, 2014, 04:48 PM
On the Edge of Space
dLdV's Avatar
Exit 4, South Jersey, USA
Joined Dec 2007
Help!
Quick Motor/Radio Compatability Question
Does anyone know if the ESC on the radio from a Hobby Zone Champ can run the motor from a UMX Extra 300 3D with no problems?
I mostly want to do it just because the Extra motor has longer leads than the Champ motor. That will make for an easier install on my current scratch build. Just want to make sure the Champ ESC won't be overloaded or anything. Don't want anything damaged because of the derp factor.
dLdV is offline Find More Posts by dLdV
Old Dec 25, 2014, 06:08 PM
yank and bank!!
Joined May 2013
If I remember correctly, there is a whole champ modification thread...and it specifically has posts about other motors in the champ. Do a search...
failboat is offline Find More Posts by failboat
Old Dec 25, 2014, 08:34 PM
dLdV's Avatar
Joined Dec 2007
I'm not finding anything like that. Can you please search it out for me?
Old Dec 25, 2014, 09:00 PM
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
Will requires some digging(1352 pages):
http://www.rcgroups.com/forums/showt...bby+Zone+Champ
coriolan is online now Find More Posts by coriolan
Old Dec 25, 2014, 09:18 PM
dLdV's Avatar
Joined Dec 2007
didn't find the answer. Are you sure it's in there?
Old Dec 26, 2014, 08:26 AM
yank and bank!!
Joined May 2013
http://www.rcgroups.com/forums/showthread.php?t=1256836
Should be all over this one...
Old Dec 26, 2014, 09:33 AM
dLdV's Avatar
Joined Dec 2007
Thanks for the help guys! I got an answer here.
Trying to get this finished over the holiday, so limited time for extensive research.
Old Dec 26, 2014, 09:50 AM
yank and bank!!
Joined May 2013
BTW nice build....
Old Dec 26, 2014, 10:28 AM
dLdV's Avatar
Joined Dec 2007
Thank you sir! Should be a cracker, the size is very Champ like. Thanks again for the help, too!
Old Dec 26, 2014, 10:57 AM
yank and bank!!
Joined May 2013
Hope it flies like.... wait for it.... a champ
Old Dec 26, 2014, 12:41 PM
dLdV's Avatar
Joined Dec 2007
Me too!
Old Dec 30, 2014, 09:31 AM
dLdV's Avatar
Joined Dec 2007
In the end, once I had a solid lead on a good substitute for the motor, I soldered in an extension on the existing Champ motor. It is pretty fine work, and I was lucky to get away with it. The wire is very fine steel strands. They tear much more easily than the surrounding insulation, so stripping the ends is pretty touch and go. I used some copper stranded I took out of an old ethernet CAT5 cable. Thankfully, the copper/steel wire splice took solder easily. I sealed the splices with Liquid Tape, since I don't have any shrink tube near that small.
Don't think your help wasn't useful... I wouldn't have gone ahead with that if I didn't have a back up plan for if I ruint it! Also, If I wear out or break this motor, I know what to get now. Thanks again.
Help! Motor and ESC compatibility question... Vlku272 Off-road Cars 6 Oct 03, 2014 04:38 AM
Discussion Motor/ESC/Battery Compatibility Question natesec22 Power Systems 3 Feb 27, 2014 07:06 AM
Discussion quick quad / radio question rhoffart Multirotor Talk 3 Feb 12, 2014 08:55 AM
Discussion Quick feedback request on JR radio compatibility DMala Micro Helis 2 Sep 16, 2011 06:14 PM
Discussion Radio compatibility question MikeSSS Radios 0 Apr 15, 2007 08:00 PM
