Old Mar 23, 2014, 05:40 PM
United States, AZ, Surprise
Joined Jul 2002
Originally Posted by JimDrew View Post
DO NOT make the antenna wires 90 degrees from each other. Those are NOT two antenna wires, those wires are a single antenna. So, making the wires 90 degrees apart will greatly reduce the range. If the range test passes (at least 125 feet with the PROG button held down), then it will work but it won't be ideal for sure.
Are we talking RFU or NANO here????
jcyr1 is offline Find More Posts by jcyr1
Old Mar 23, 2014, 05:51 PM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
the Nano.
- Nano has one antenna. The wires are two sides of the same antenna and they need to stay straight.
- RFU has two antenna with diversity switching, and ideally should sit 90 degrees to each other.
theKM is offline Find More Posts by theKM
Old Mar 23, 2014, 05:59 PM
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
Correct... I was referring to the Nano, which has a single antenna made up of the circuit board, coils, and two wires. The RFU has two completely separate antennas.
JimDrew is online now Find More Posts by JimDrew
Old Mar 24, 2014, 05:54 PM
west suburb of cleveland oh
Joined Nov 2004
jim
so you should just leave the sticking out straight in the wind or should they be supported?
don
dvk44039 is offline Find More Posts by dvk44039
Old Mar 24, 2014, 10:27 PM
Lake Havasu, AZ
Joined Jun 2005
If they are in the wind for some reason, you need the wires supported.
Old Mar 25, 2014, 12:45 PM
USA, WA, Spokane
Joined Mar 2005
Here is how I have made glass canopies for a Supra and a Pulsar and installed the RFU inside them. The aerials are inside some old sullivan tube and the wires are held in place with some gorilla duck tape. So far this has worked fine.
Steve
Steve Adams is offline Find More Posts by Steve Adams
Old Mar 25, 2014, 12:48 PM
USA, WA, Spokane
Joined Mar 2005
Steve
Old Mar 25, 2014, 01:09 PM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
yup, that looks pretty nice
Old Mar 25, 2014, 01:22 PM
Lake Havasu, AZ
Joined Jun 2005
Yep, for a severe carbon installation that looks good.
Old Mar 25, 2014, 06:55 PM
Tennessee
Joined Sep 2003
I use both the sailplane and nano receivers in my sailplane and dread having to do anything to the nano receivers because it is so difficult to remove and reinstall the nano. I mold my own fuselages and the nose cone requires that the nano be installed so far back in the fuselage to allow the antenna to exit aft of the nosecone. The fuselage was designed around the Hitec superslim receiver and the sailplane receiver slips right in with the sailplane receiver antenna sliding in the old antenna tube. The best solution would be to redesign the fuselage. Fortunately the nano is so reliable that I don't have to remove the receiver very often since I installed a servo extension cable for the bind plug.
ChuckA is online now Find More Posts by ChuckA
Old Apr 16, 2014, 02:47 PM
Addicted To Glass !!!
TriTipTim's Avatar
Glamis,ca
Joined May 2008
My Builder sent me this video of his proposed install of RFU & X 10 in my willow .
What do you guys think ?
Thanks Tim
XPS RFU Install Willow (0 min 23 sec)
Attached is the X 10 install
TriTipTim is offline Find More Posts by TriTipTim
Old Apr 16, 2014, 03:01 PM
Lake Havasu, AZ
Joined Jun 2005
Yep, that's just about ideal.
Old Apr 18, 2014, 06:06 PM
E_ferret's Avatar
Launceston Arpt, Tasmania, Australia
Joined Jan 2004
cool! metal grommets.
E_ferret is offline Find More Posts by E_ferret
Old Apr 21, 2014, 06:02 PM
On the banana boat
San Diego,Montgomery
Don't sweat it.....
The grommets are between the X10 board and the "stand-offs'
Be aware that this was a XPS conversion from 72.xxx, if started as a new install things would be different.
Throne is offline Find More Posts by Throne
Old Apr 22, 2014, 02:02 PM
TriTipTim's Avatar
Glamis,ca
Joined May 2008
Originally Posted by Throne View Post
Don't sweat it.....
The RFU and 10X work flawless !!
Sold X-21 F3B UHM carbon sailplane AGENTWON Aircraft - Sailplanes (FS/W) 2 Nov 18, 2013 08:37 PM
Digital Camo G10 24"x24"x.062 for sailplanes? vic20owner Non R/C Items (FS/W) 2 Oct 11, 2013 07:51 AM
Sold Rubbermaid Big Max Ultra 10 ft. 6 in. x 7 ft. Storage Shed RcCrawler82 Non R/C Items (FS/W) 0 Sep 24, 2013 03:28 PM
For Sale Relist, Vintage Sailplane Glider Plans $10 Each gva1956 Aircraft - Sailplanes (FS/W) 0 Sep 22, 2013 01:05 PM
Sold APC 24 x 12 22 x 12 18 x 10 18 x 12 Props boatdoc Aircraft - Electric - Power Systems (FS/W) 2 Mar 02, 2011 12:04 AM
