Old Aug 30, 2013, 07:17 AM
71% of the world is runway . .
Bart83's Avatar
Nederland, ZH, Oostvoorne
Joined Jun 2009
Build Log
Dornier Wal , free download plan balsa build
Dornier Wal 2nd flight (5 min 22 sec)
Hello fellow waterflyers ,
Last weekend i made a design for a small balsa Dornier Wal. Its a fun scale seaplane. The setup i plan to use for this comes from my G44 widgeon.
2x Rimfire 400 motors
2x 30A esc's
3300mAh 3cell Lipo
The plane has a wingspan of 1400mm , lenght is 992mm. Costruction is in 5mm balsa for the boxframe , 4mm balsa for the tailframe , 2mm balsa for ribs and formers , 1mm balsa for sheeting and 3mm ply for some parts.
I made a simple plan showing the basic construction and the parts. Most builders will be able to build the model from this. Construction for the struts , radio gear mounting etc have to be figured out by the builder. These things take lots of time to design in cad so i chose to leave it for the builder.
I attached some screens of the design in various phases and the plan as PDF. This can be print on a 36x72inch paper at the local print shop.
on the link below the pictures the pdf can be downloaded.
Dornier Wal
Hope you all like this . . .
Bart
Bart83 is offline Find More Posts by Bart83
Old Aug 30, 2013, 07:33 AM
Bart83's Avatar
Joined Jun 2009
Got the plan printed , costs were 6 euro's. Test fitted some of the electronics , there is room enough for the setup i plan to use.
Cheers,
Bart
Old Aug 30, 2013, 07:39 AM
Madison, WI
Joined Feb 2004
Subscribed!
Fast Freddy is offline Find More Posts by Fast Freddy
Old Aug 30, 2013, 09:31 AM
GLM
AMA 209854
GLM's Avatar
Check Six!
Joined Oct 2003
Bart this is fantastic!
Does the Netherlands somehow have more time than the rest of the world?
How do you get all this done in such short order?
I love this plane!
I'm going to try one on the laser after my Empire wing is done.
Great work
Cheers!
Gary
GLM is offline Find More Posts by GLM
Old Aug 30, 2013, 12:40 PM
Always Ready!
warhead_71's Avatar
Chicago, IL
Joined Dec 2006
Looks great Bart! Subscribed.
warhead_71 is offline Find More Posts by warhead_71
Old Aug 30, 2013, 03:10 PM
cracksmeup's Avatar
United States, IL, Joliet
Joined Jun 2009
You know me Bart i will watch any sea plane build but yours are great.
cracksmeup is offline Find More Posts by cracksmeup
Old Aug 30, 2013, 04:17 PM
Slip the surly bonds...
Sopwith Mike's Avatar
Christchurch,England
Joined Aug 2004
Looks great Bart, Nick Chud will like this plan!
Sopwith Mike is offline Find More Posts by Sopwith Mike
Old Aug 30, 2013, 05:11 PM
Parkcityflier
parkcityskier's Avatar
Park City, UT, USA
Joined Aug 2001
Great idea, Bart. It should be a quick build and look good in the air. Unfortunately, I don't have any more room on my plate for another build so I'll have to be content to just read the posts on this one.
Jim
parkcityskier is online now Find More Posts by parkcityskier
Old Aug 30, 2013, 08:13 PM
skumgummi dave
Gresham, OR.
Joined Mar 2004
Lurking...
foamdave is online now Find More Posts by foamdave
Old Aug 31, 2013, 03:53 AM
What could possibly go wrong?
nickchud's Avatar
Market Harborough
Joined Apr 2006
That's a super plane and practical too. I built one a few years ago by copying the full-size 3-views. It flew well but would not ROW because, as soon as I tried to get the tail out of the water, the sponsons would go under. What was in my mind for the next attempt was to leave the sponsons off till I could put it in the water and find the waterline. Then to post-fix them in the appropriate place.
Has someone already solved that problem Bart? I know Laddie built a successful one, but ... no surprise there!
Cheers
Nick
nickchud is offline Find More Posts by nickchud
Old Aug 31, 2013, 05:15 AM
Bart83's Avatar
Joined Jun 2009
Cheers
Nick
Thats seem like a good idea Nick. One thing on the stummels im sure of that is very important is the angle of the stummel's bottom in relation to the hull bottom , they have to be the same ( red lines ) . If the bottom of the stummels is airfoil shaped ( green line on drawing ) it will create suction and then the model will be hard to get out of the water.
Cant wait to put this to the test . . . of to the hobbyshop for some wood . . .
Cheers,
Bart
Old Aug 31, 2013, 07:14 AM
Parkcityflier
Park City, UT, USA
Joined Aug 2001
I used the exact same shape as what was shown on my 3-view drawings and had no problems. Getting the correct angle of incidence for the sponsons is important, too.
Old Aug 31, 2013, 07:49 AM
Bart83's Avatar
Joined Jun 2009
Your right there my friend , your wal handles very well on the water. On your Wal the sponsoons are placed a bit higher than on Nicks wal i think.
Have you flown your wal of mirror flat water Jim , i would like to know how that went. Usually a flat rimple free water surface is the biggest challenge for any flying boat.
Cheers,
Bart
Old Aug 31, 2013, 01:00 PM
Bart83's Avatar
Joined Jun 2009
Todays progress :
Went to the local hobby-store to but some wood. When i arrived home i got started right away
First thing to do was cutting the 5x5 balsa beams from the 5mm sheet. I used the balsa stripper shown and made the cuts in 3 steps to prevent the blade tracking the wood grain and so messing up the beams.
Description:
Then i cut the boxframe side from the plan , fixed it to the building board and covered it with some waxed paper ( on long term loan from the kitchen )
Description:
Then i cut the balsa beams for the boxframe to size using a fine razor saw. After that the beams where fixed to the board with some building pins. When the frame was aligned with the plan i glued it with CA and placed some diagonal spars.
Description: Name: Wal (12).jpg
Description: Name: Wal (13).jpg
Description: Name: Wal (17).jpg
Description:
Description: Name: Wal (15).jpg
Description: Name: Wal (16).jpg
Description:
I had to make 2 frames and sanded them to be the exact same size
Description: Name: Wal (19).jpg
Description:
Cut al the cross beams to side and made preperations to join the sides.
Description:
Af first i fixed the sides and cross beams for the centre section , this section is a box so when this is build straight it will be hard to mesh up the rest of the boxframe. ( at least i hope )
Description: Name: Wal (23).jpg
Description: Name: Wal (24).jpg
Description:
After a break i thought it would more logical to fix the frame upside down to the board as the top of the boxframe is flat . . .ppff why didt i see this earlier ( nightshifts make my brain less effective i guess )
Description:
Joining the sides goes without any trouble for the aft section
Description:
To make the bend in the balsa at the front part of the hull i had to soften the balsa otherwise it would break. I used a small injection needle pump to wet the balsa ( and not the rest of the room ) i used soapy water for this.
Description:
After a while the balsa was soft enought and i carfully could make the bend and fix it in place with some weights.
Description:
Not bad for one day :
Description: Name: Wal (30).jpg
Description:
More to come soon . . . .
Cheers,
Bart
Old Aug 31, 2013, 01:38 PM
Parkcityflier
Park City, UT, USA
Joined Aug 2001
Bart, my Wal flys fine off of mirror flat water. In fact, I always try for those conditions on all my waterplanes. Looking at your new build. Sometimes it's nice to take a break from a high intensity project (the DO 24) and just do some building. Have fun.
Jim
Build Log The 2nd Dornier Wal Prototype THE GROENLAND WAL classicaero Scale Kit/Scratch Built 53 May 28, 2014 07:09 AM
Contest Contest - Build Off II - Dornier Wal nickchud Scale Kit/Scratch Built 202 Jun 22, 2008 02:00 AM
Discussion Dornier Super Wal Plans or Drawings Farm Flyer Waterplanes 5 Jan 09, 2008 08:52 AM
Discussion Dornier Wal electric scale flying boat nickchud Scale Kit/Scratch Built 29 Jan 08, 2008 06:29 AM
Need help with Dornier Wal flailing Scale Kit/Scratch Built 6 Jun 06, 2002 02:40 AM
