Old Nov 28, 2012, 08:17 PM
Joined Nov 2012
What is Hacker motor c-50-14XL Max Temp?
What is Hacker motor c-50-14XL Max Temp? Any advise would be very much appreciated. Thank you.
nhuii is offline Find More Posts by nhuii
Old Nov 29, 2012, 08:11 AM
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
As with any motor, 60C/140F at the windings is as much as I'd recommend.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Nov 29, 2012, 02:06 PM
JustFlying
rebell's Avatar
Joined Dec 2005
The better motors like Hacker, Axi and a few others use magnets with temperature ratings of 150 deg.C and winding rated for temperatures even higher than that.
If any motor, irrespective of what the temperature rating is, reach temperature higher than what you can comfortably touch and hold for extended time, that is higher than about 60 deg.C, there is something wrong with your setup and you should address it.
rebell is offline Find More Posts by rebell
Found Hacker C50 13XL or 14XL ACRO w/ 6.7:1 akonaman00 Aircraft - Electric - Power Systems (FS/W) 2 Aug 31, 2012 08:10 PM
Found Hacker C-50 12XL lpjamb Aircraft - Electric - Power Systems (FS/W) 0 Apr 15, 2012 09:12 PM
Sold Hacker C-50 14Xl Acro 6.7:1 Dave Grife Aircraft - Electric - Power Systems (FS/W) 1 Dec 26, 2010 09:45 PM
What NEU Motor = Hacker C 50 16 XL gigawatt Power Systems 0 Sep 11, 2005 02:24 PM
Need motor info - Hacker C50-14XL Doug Cronkhite Power Systems 25 Feb 25, 2004 11:19 PM
