Old Jun 02, 2012, 07:30 PM
Nate95's Avatar
Joined Jan 2012
Help!
Airfield F16 Broken fan unit
I was flying my airfield 70mm f16 edf today and the flight was going perfect and landed it safely. on the ground, the fan unit sucked up something from the ground and it broke the fan unit. i think the motor is ok. i need help fixing this. i have no idea how to access the fan unit. please help!
Nate95 is offline Find More Posts by Nate95
Old Jun 03, 2012, 12:46 PM
denver colorado
Joined Jan 2004
There is a foam hatch on the bottom if it,s like my airfield f4. there is two foam plugs that pull out. Under them is two screws. Remove the screws and the hatch will pull out. The fan is not glued in, it will come right out
topher is online now Find More Posts by topher
Old Jun 03, 2012, 01:24 PM
Nate95's Avatar
Joined Jan 2012
Thank you so much
Old Jun 03, 2012, 01:38 PM
Nate95's Avatar
Joined Jan 2012
do you know how to remove the fan unit from the motor?
Old Jun 03, 2012, 02:09 PM
Nate95's Avatar
Joined Jan 2012
Nevermind. I figured it out and ordered a new fan. What did you use to put the fan back in. i was thinking about hot glue
Old Jun 03, 2012, 07:38 PM
denver colorado
Joined Jan 2004
If your using a stock fan you shouldn,t need to glue it. The hatch holds it in place. I used the eflite deltav 15 wich has mounting ears on the side. So i just glued in two balsa "rails" and screwed it to those so i can remove it if needed
Old Jun 04, 2012, 08:22 AM
Effumall
kelberts's Avatar
Joined Nov 2005
Double sided carpet tape really holds well, if you're concerned about the fan shifting
kelberts is offline Find More Posts by kelberts
Old Jun 04, 2012, 02:42 PM
Nate95's Avatar
Joined Jan 2012
thanks guys
For Sale Byron F16 w/ XPS/ DYNAMAX FAN UNIT "Price Drop" Wildblue Aircraft - Electric - Jets (FS/W) 10 Mar 03, 2014 10:21 PM
For Sale Byron F16 w/ XPS/ DYNAMAX FAN UNIT "Price Drop" Wildblue Aircraft - Electric - Jets (FS/W) 3 Feb 14, 2012 05:10 PM
Sold Stock 64mm fan unit and 4100KV motor from Airfield JGuilty13 Aircraft - Electric - Jets (FS/W) 2 Jan 18, 2012 04:42 PM
For Sale Byron F16 w/ XPS/ DYNAMAX FAN UNIT "Price Drop" Wildblue Aircraft - Electric - Jets (FS/W) 0 Dec 08, 2011 05:19 PM
Discussion Replacement Fan Unit For F16 malcolxl Foamy EDFs 0 Sep 07, 2008 04:12 PM
