Old Aug 24, 2013, 08:09 PM
Joined Aug 2013
parts
Hi ...where did you purchase the parts for the blue core build
hunter 1 is offline Find More Posts by hunter 1
Old Aug 28, 2013, 05:40 PM
Build, crash, repeat...
lee292a's Avatar
USA, VA, Cedar bluff
Joined Dec 2002
Many of the blue core wings are made from 1/4" fanfold foam insulation. The blue stuff is made by Dow but it's somewhat hard to find now. I bought a bundle of Owens-Corning (which is pink) but I haven't made anything out of it yet. You can also use the foam core poster board if you wet and peel the paper off. The motors, servos, batteries, and props can be found from several vendors. My two personal favorites are Hobby King and HeadsUpRC.
lee292a is offline Find More Posts by lee292a
Old Sep 08, 2013, 02:27 PM
Joined Sep 2012
Could you make this from 6mm depron and leaving the motor off slope it?
Diwrnach is offline Find More Posts by Diwrnach
Old Sep 09, 2013, 09:42 AM
lee292a's Avatar
Joined Dec 2002
If it flies with a motor, it'll fly as a glider, providing the CG is the same.
Old Sep 18, 2013, 03:36 PM
gilford, new hampshire, usa
Joined Nov 2003
Try Model Plane Foam! New stuff, sounds real good.
nebuchadnezzar is offline Find More Posts by nebuchadnezzar
Old Sep 19, 2013, 09:20 AM
Once you taste flight...
skydvejam's Avatar
United States, ME, Bangor
Joined Dec 2011
I have a ton of FFF sitting around, and some other gear, thinking 9g servo's and a .10 super tiger with a 8x8 and 30 amp ESC, gives good performance speed wise on some of my profile park jets, bet it will make a wing just howl. 285 watts on one of these should be a white knuckle blast, but still easier than my pylons in the wind.
skydvejam is online now Find More Posts by skydvejam
Old Oct 27, 2013, 02:44 AM
Chino Renegade oh-gee, yo
Wrench66's Avatar
United States, CA, Chino
Joined Feb 2008
Tail less pusher jet FFF wing build
I am involved in a scratchbuild contest over on WF......so I am using the 40in wing I've built here before but with a jet type fuse and single vert stab in place of the wing tip plates.
Same wing, but used differently than before
--Ray
Wrench66 is offline Find More Posts by Wrench66
Old Oct 27, 2013, 10:50 AM
carr52's Avatar
United States, SC, Irmo
Joined Mar 2012
I like it. I want to build a large wing for fpv. Not sure how that'll work out but its worth a shot.
Tom
carr52 is offline Find More Posts by carr52
Old Nov 07, 2013, 11:56 PM
Wrench66's Avatar
Joined Feb 2008
Successful combination!
So the experiment is a success.....the Bluecor wing with fuse attached is a very good flyer.
--Ray
Tail less RC pusher prop jet maiden flight (5 min 26 sec)
QueenBee: 100" EPP wing build & fly thread Pjotrrr Foamies (Kits) 186 Jul 29, 2012 04:21 AM
Bluecor "Arado Projekt" Build Thread jimsky Foamies (Kits) 82 Sep 12, 2009 09:43 PM
ST Model Wing build thread scotta Flying Wings 20 Nov 14, 2005 06:01 PM
"Thunder" experimental wing build thread Ryan Archer Flying Wings 8 Jan 22, 2005 05:06 PM
Overlord Build Thread - My first wing. Bernoulli~Bros Flying Wings 79 Aug 15, 2004 06:50 PM
