Old Oct 24, 2013, 08:37 AM
SOCIAL CLUB MEMBER
chidago's Avatar
United States, IL, Chicago
Joined Dec 2009
Oops..
chidago is offline Find More Posts by chidago
Old Oct 28, 2013, 01:26 PM
United States, TX, Leander
Joined Jun 2005
My Mini is back together with the new servo and everything cleaned up.
Water-tested in bathtub for 30mins, no water intrusion.
Self-righting test.....it wasn't 100% righting reliably so I added another 1/4oz on the outside tip and that proved 100% reliable. Again, no water intrusion over this testing.
Some quick function checking in the tub water with the motor, and there was some minor water intrusion when I opened it up. Only thing I see is that perhaps some water was coming up the drive shaft. Will have to keep an eye on that once I get her out on the open water again.
AustinWolv is offline Find More Posts by AustinWolv
Old Oct 29, 2013, 05:59 AM
Joined Jul 2007
I have a friend. After end of the race he removes 0.2-0.3 lts water from the boat.
If inside his boat has no water it is something wrong with him.
We put toilet paper on the bottom in case any water enter to not free splash
ivaylo goranov is offline Find More Posts by ivaylo goranov
Old Nov 04, 2013, 05:45 PM
Joined Jun 2005
Ran mine again for a couple or so packs over last weekend, getting a feel for what it is doing. Lots of flipping, plenty of subbing on turns......some of it due to some rough water, some of it not. The nice thing is that self-righting is working great, as is the hull being sealed up. Very, very little water inside despite plenty of trips underwater and upside down.
Definitely a quick little boat and ran really well in spots, heard some of the up/down RPM sounds that chidago discussed earlier in the thread, so appears to definitely need some work to smooth out the hull. Not dialed in. I'll try to get video up later.
Sigh.........due to an unfortunate incident with an accidental drop by my youngest *trying* to be helpful.........anyone know where a spare rudder could be procured?
Old Nov 05, 2013, 01:28 AM
Joined Jul 2007
Aus
We do the mechanical parts (shaft rudders couplings…..) ourselves.
Our rudders rod have angle so we can not use the original made by Tenshock
The boat is Ok if you use like a toy on small speed
Any time you setup it over 8-9 m/s, you need to have it stable on the water. Banging or flip –flops are generating stresses, overloads ………
Also as I said before it is a huge difference if you have your boat running alone or in group with other on triangle.
Old Nov 05, 2013, 09:07 AM
SOCIAL CLUB MEMBER
chidago's Avatar
Joined Dec 2009
Aus, pm me I think I gotta extra 1..
Old Nov 06, 2013, 01:23 PM
ECO nut
United States, PA, Cumberland
Joined Jun 2013
I know I'll get a lot of different answers. What rudder servo does everyone use for Mini ECO, and why?
rbsmith6 is offline Find More Posts by rbsmith6
Old Nov 06, 2013, 04:11 PM
Joined Jun 2005
No expert here, but using Hitec HS65MG now. It was available easily.
Old Nov 06, 2013, 11:55 PM
Joined Jun 2005
Quick video after getting mine all put back together
Mini-Eco RC boat on 3S (1 min 3 sec)
Old Nov 07, 2013, 11:20 AM
SOCIAL CLUB MEMBER
chidago's Avatar
Joined Dec 2009
Looks good, D..
Old Nov 07, 2013, 06:02 PM
Joined Jul 2007
I use MKS-ds95MG
As i said before the rudder is not for steering gear only but for control the drift and stabilize the boat in the turns
Old Dec 12, 2013, 03:44 PM
SOCIAL CLUB MEMBER
chidago's Avatar
Joined Dec 2009
Wow..sure dead here..everybody get grounded and have to stay home??
Old Dec 13, 2013, 12:03 AM
Joined Jul 2007
it is a time for assembling new boats.
It is also unfortunate situation that the racers are waiting the rules changes.
Old Dec 13, 2013, 10:20 AM
Joined Jun 2005
Waiting on a couple props to arrive from hydromarine and then try.
Tried one prop and the boat was much more stable since it wasn't a lifter like the stock prop, so I was impressed with the handling and stability now. But it isn't sized right as the boat was significantly slower.
Old Dec 14, 2013, 11:37 AM
SOCIAL CLUB MEMBER
chidago's Avatar
Joined Dec 2009
Here is what we gotta do now..
WHAT water (1 min 32 sec)
Discussion New Eco Power 4 port charger with bad banana plugs? shahram72 Batteries and Chargers 1 Feb 12, 2013 03:53 PM
Question Hobbyking Eco 8 charger voltage display CzechSix Batteries and Chargers 2 Jan 20, 2013 04:51 PM
For Sale Gens ace eco 1300mah 7.4v koa377 Aircraft - Electric - Batteries & Chargers (FS/W) 1 Jan 19, 2013 11:01 PM
Sold 4 port ECO Power Charger 4x50 watt New in the box HD Hucker Aircraft - Electric - Batteries & Chargers (FS/W) 0 Jan 06, 2013 05:37 PM
Wanted Velocity Mono, Velocity Cat, Mini-Eco Mini Cat Racing by Tenshock sloppydogdrool Boats (FS/W) 0 Apr 20, 2012 03:57 PM
