Old Jul 13, 2012, 01:50 PM
Ireland
Joined Jun 2011
Help with charger choice
Here are my options
G.T. Power A606 charger
http://www.giantshark.co.uk/power-a6...-p-404612.html
GT Power A606 Dual Charger
http://www.giantshark.co.uk/power-a6...-p-405325.html
GT Power C6 Charger Li-po NI-MH Battery
http://www.giantshark.co.uk/power-ch...-p-406637.html
GT Power P4 Professional Lipo Charger with Parallel Charging Sys
http://www.giantshark.co.uk/power-pr...-p-407555.html
GT Power B606 balance Charger Li-po NI-MH Battery
http://www.giantshark.co.uk/power-b6...-p-406285.html
B6AC 80W Balance Nicad/NIMH, Lipoly Charger
http://www.giantshark.co.uk/b6ac-bal...r-p-406695.hml
i charge anything up to 3s normally
would like to know which is best and any additional advice
Jamie
jamiek123 is offline Find More Posts by jamiek123
Last edited by jamiek123; Jul 13, 2012 at 04:01 PM. Reason: forgot B6AC 80W Balance Nicad/NIMH, Lipoly Charger
Old Jul 13, 2012, 03:22 PM
United States, MN
Joined Feb 2011
Well none of those are fantastic chargers by any means as they are all low power. If they are adequate will depend on your needs. You said up to 3s. But what capacity? How many do you want to charge at once? How fast do you want to be able to recharge them?
grimbeaver is offline Find More Posts by grimbeaver
Old Jul 13, 2012, 03:39 PM
Ireland
Joined Jun 2011
i would be charging up to 2200mah would only charge 1 at time would like whichever is the fastest for the price, out of them all which would you say are best 3
and the best also wold they be on par with the imax b6 and accucel 6.
Thanks very much
jamie
Old Jul 13, 2012, 04:02 PM
Ireland
Joined Jun 2011
also this charger looks good
http://www.giantshark.co.uk/b6ac-bal...-p-406695.html
Old Jul 13, 2012, 04:08 PM
United States, MN
Joined Feb 2011
Well they are all 50W chargers. At 50W you'll max out at about 3.9A charge rate on 3S which would be about 1.7C on a 2200mah. So you'll be looking at about 35min to charge a depleted battery depending on how long balancing takes. If I had to pick I would probably get the A606 (non-dual), B606 or C6. I don't see what the difference is between them. The A606 dual has a built in power supply, personally I would rather have an external power supply. The P4 is extremely limited in use and it's going to be a slow charge.
If I were wanting to buy from this site and not spend too much I would get this one:
http://www.giantshark.co.uk/a610-200...-p-404525.html
It's got 4x the watts of the ones you are looking at. You can charge a 3S at up to 10A on that. Which for a 2200mah would be 4.5C (if the battery can take that much) which means you're looking at about 13min to charge a battery.
Old Jul 13, 2012, 04:28 PM
Ireland
Joined Jun 2011
what do you mean by a built in power supply
Old Jul 13, 2012, 06:03 PM
United States, MN
Joined Feb 2011
Meaning you can plug it into ac power. Most chargers are dc only and if you want to use them on ac you need a power supply.
Old Jul 13, 2012, 10:50 PM
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
To use the charger grimbeaver recommended you will need a DC power supply. This one would be a good choice.
http://www.giantshark.co.uk/power-12...-p-407558.html
Glen
ggcrandall1 is online now Find More Posts by ggcrandall1
Old Jul 14, 2012, 12:41 PM
That's a funny word
NE Ohio
Joined Apr 2003
If ac power is important to you then the 80 watt AC/DC seems to be the best deal. I just bought a HK version and it's exactly like all the other ones. It looks exactly like the one in your pic and I have 2 complaints:
It runs a bit hot at full power (on ac power) inmop AND it has a 5 amp limit when using "fast" charge.
gulio is offline Find More Posts by gulio
Old Jul 14, 2012, 05:24 PM
Ireland
Joined Jun 2011
think i might get this as it is in my country what do people think of this
titan b6
http://radiocontrolledshop.ie/used-r...0054-used.html
thanks
jamie
Old Jul 14, 2012, 06:06 PM
United States, MN
Joined Feb 2011
It's exactly like all the others you posted. Probably made in the same factory in China.
Old Jul 14, 2012, 06:18 PM
Ireland
Joined Jun 2011
do you think they would be as accurate as the accucel 6 for charging?... i would order from the international hobbying warehouse but i know if charger doesnt work i wont get refund or will have to pay for sending it back
Discussion Help with FPV Platform choice - Noob to FPV MrMum Australia 3 Jun 28, 2012 08:17 AM
Help! Help with plane choice JRAllen 3D / Fun Fly Fuel Planes 2 May 17, 2012 07:30 PM
Discussion help with RES electric choice 3m or bigger raggedraider Electric Sailplanes 21 Mar 25, 2012 11:02 PM
Discussion Help with Charger Choice race58 Batteries and Chargers 18 Jan 16, 2009 03:24 PM
Need Help With Charger choice (yea another post like this) For Zagi FiXX. Draconious Batteries and Chargers 8 Jan 20, 2003 12:06 PM
