Old Sep 23, 2013, 05:01 AM
Plane crasher
seedo's Avatar
Joined Jun 2007
Question
where I can buy good landing gear for gliders?
Hi
I'v been swarming the Internet for glider style landing gear that I need to buy, I got lucky with only hobbyking.com which its not what am looking for, does anyone know where I can find landing gear glider style I want to use it on the x8 flying wing, before asking me why and how please help me with my search and I will answer your questions.
Regards
seedo is offline Find More Posts by seedo
Old Sep 23, 2013, 07:58 AM
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
The only 'glider' landing gear I have come across is the single retracting wheel type.
What exactly are you looking for your x8, a trike set up ?, tall enough for prop clearance and take-off ?.
I don't think you will find much if you look for 'glider' landing gear, what's wrong with just the conventional gear as used on power models ?
eflightray is online now Find More Posts by eflightray
Old Sep 23, 2013, 08:12 AM
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Just had a scan through the pictures in the X8 thread looking for U/C, (not a lot), but there were plenty of ramps/catapult systems shown, also a couple of launch dollies.
See if these individual posts help --
A dolly --
http://www.rcgroups.com/forums/showt...1#post21655586
Fixed U/C --
http://www.rcgroups.com/forums/showt...2#post22465590
Retracts --
http://www.rcgroups.com/forums/showt...6#post24486063
I assume you know about the New X8 WING thread -- http://www.rcgroups.com/forums/showthread.php?t=1555543
Old Sep 23, 2013, 08:25 AM
Plane crasher
seedo's Avatar
Joined Jun 2007
thanks a lot mate, as you said not much, well i want to use a robust glider landing gear for the X8 only for landing purposes, where i live there is no airfields for RC planes so we hand launch everything and strengthen the botom of the plane to protected from the hard ground, the ground we have is desert type though not the soft sandy type so we cant take-off from ground unless the landing gear wheels are BIG! its very effective to use the glider style landing gear i also tried it before on EDF jets and larg gliders and it worked nice, my first test was using the fox glider gears after i strengthen it with heavy fiber glass, i though about glassing the bottom of the X8 but the plane is too heavy so this method will not help.
Regards
Old Sep 23, 2013, 08:28 AM
Plane crasher
seedo's Avatar
Joined Jun 2007
oh sorry i didn't mention if i use a normal method of retracted landing gear then the gear will be ripped off and even brake the base of it.
Old Sep 23, 2013, 10:04 AM
Plane crasher
seedo's Avatar
Joined Jun 2007
WOW finally i found it
RC lander has it
http://www.rclander.com/default.aspx...e-d7f4dad07ddf
Old Sep 24, 2013, 02:36 PM
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
In case you want to see others, here's a Google Images search on "RC glider retract"
https://www.google.com/search?q=RC+g...tract&tbm=isch
Old Oct 02, 2013, 03:03 PM
DFC~ We Do Flyin' Right
bsbauman's Avatar
USA, GA, Atlanta
Joined Nov 2008
http://www.windrider.com.hk
They have a nice pod that straps to a wing with LG attached.
bsbauman is online now Find More Posts by bsbauman
Discussion Where can I buy a battery for JR XP652? cloud_9 Radios 5 Sep 18, 2013 12:26 PM
Where can I buy gear sets for Futaba S9650 servo for my logo 10 UAVProducts Electric Heli Talk 2 Mar 24, 2005 06:51 PM
Where can I find 3/32" sheet aluminum for landing gear? Sal C Electric Plane Talk 3 Aug 28, 2004 10:30 PM
Where to buy landing gear for Slow Stick rickyblaze Parkflyers 6 Mar 15, 2004 03:48 AM
Where's a good source for buying glider video's? blivsey Slope 8 Feb 19, 2004 06:15 PM
