Old Dec 18, 2014, 02:24 AM
Have fun
airpower's Avatar
Joined May 2007
But it's exactly what I use.... I used it today to max out my Beasts aileron gain. Many people on this forum would gladly buy the remaining programmer off you.
airpower is offline Find More Posts by airpower
Old Dec 22, 2014, 06:32 PM
United States, WA, Jefferson County
Can anyone tell me the difference between the boards installed in the UMX Radian and UMX ASK? I'd like to motorize my ASK but unsure whether a brake is available in the ASK esc. Without the brake it becomes a ''why bother'' project.
uncookedlentil is offline Find More Posts by uncookedlentil
Old Dec 22, 2014, 07:15 PM
CorvetteC5's Avatar
Kokomo, Indiana
Joined Jun 2008
The Ask-21 brick does not include the ESC brake feature of the Radian. I added a motor and folding prop to my Ask-21, before the UM Radian was introduced, and it will not stop free wheeling in a glide. Eventually I may add a brake to this ESC of my own design. Even as it is, the Ask-21 is a nice backyard flier with UM Citabria wings.
CorvetteC5 is offline Find More Posts by CorvetteC5
Old Dec 23, 2014, 07:48 AM
United States, MA, Belmont
Joined Mar 2004
Air power I stand corrected - I bought one and it does have that extension with it and it's the perfect length too.
It's on my model now and works fine.
Thank you!
mgdon is online now Find More Posts by mgdon
Old Jan 20, 2015, 09:54 AM
Joined Jan 2007
Gents, I'm going to copy a post I made in another thread in hopes of spreading my noise to get some help. :-)
I pulled the AS board out of my UMX SBACH and I'm trying to get the gyros turned off so I can run regular elevon mixing in my TX. Sounds easy...
I have my PC recognizing the programmer and the software correctly picks up the COM port (we all know now it flashing the number isn't a problem.) But I cannot for the life of me get the brick to activate the XPORT. I verified CH5 is still active using a servo (thanks for the hint BTW)
My Tx is an old Futaba 8U running a real Spektrum DM8 module. The setup has worked well for years. Just recall that Futaba has to reverse channel 3 to work with electric models. I did reset the data for the model slot and even tried running CH3 not reversed. All rates are at 100% and trims reset.
-I plug the programmer into the XPORT but the USB end is not in the PC.
-Power on the TX in full throttle, right rudder held by a rubber band.
-Power on the Rx board.
---The LED turns on briefly, turns off for 4-5 seconds and then blinks rapidly as if it has lost bind. However after powering everything off, and powering on in the right way, the Rx is still bound to the Tx and runs CH5 as normal.
---On another attempt following the same procedure but changing the CH5 switch on the Tx, the light turned on briefly, off briefly and then stayed on steady.
How in the doodles do I get XPORT active!?!?
Team_Monkey is online now Find More Posts by Team_Monkey
Old Jan 20, 2015, 08:28 PM
Joined Jan 2007
The programming problem was resolved by using a transmitter from my RTF Night Vapor, instead of the converted Futaba to do the programming.
http://www.rcgroups.com/forums/showp...&postcount=169
New Product UMX Hyper Taxi, UMX Beast 3D, and mSR X boredom.is.me Scratchbuilt Indoor and Micro Models 37 Oct 23, 2011 10:22 PM
Sold New in Box UMX Beast PatternFlyer Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Dec 22, 2010 10:55 AM
Sold UMX Beast BRAND SPANKIN NEW with extras Kev71H Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 5 Dec 19, 2010 10:49 PM
Sold UMX Beast Brand New never flown H&H Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 4 Dec 19, 2010 08:33 PM
For Sale UMX Beast Brand New never flown H&H Aircraft - Electric - Airplanes (FS/W) 1 Dec 19, 2010 01:24 PM
