Old Oct 14, 2011, 07:35 AM
Life begins at transition
Australia, VIC, Sale
Joined May 2007
Strike, the guy next to me at work reckons he's going to put my F16's power system into the Stinger! Should go alright
At the moment, he's got the stock fan, I rewound the motor, running on 4s...
Odysis is offline Find More Posts by Odysis
Old Oct 14, 2011, 08:05 AM
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
the BH F-16???
if it's the TV one it will do juuust fine.. believe me
pavcon is offline Find More Posts by pavcon
Old Oct 14, 2011, 03:34 PM
unbreakable ? give it to me !
kinghelichopter's Avatar
United Kingdom, Market Harborough
Joined Oct 2010
Originally Posted by pavcon View Post
lol.. have youflown that thing yet?
expect it to be FFFAAAAASSSSTTT
the only downside is that the exhaust of the fan will be a bit blocked by the narrower exhaust ducting of the plane
not flown yet , hope to test fly tomorrow if the weather holds up , i did have to remove some foam to get the fan in as its been said sandpaper works great on foam, im not really bothered about the extra speed , i wanted more power for vertical flight , the stock 3 cell fan/motor soon runs out of power if you point your stinger straight up , i have my fingers crossed that mine doesn't stop now
that's why im asking what size batteries and c rating others are using , as there must become a time when power to weight runs out and flight times start to drop from carrying to much weight ?
cheers dave
kinghelichopter is offline Find More Posts by kinghelichopter
Old Oct 14, 2011, 03:37 PM
Joined Oct 2010
Originally Posted by Strike3 View Post
Not obvious at all...
Hey I fly with Nitrocharged, things never remain stock... speed is addictive!
Will try to get some video of my Stinger on 4 cell... hopefully the weather improves a bit for us here!
May need to set up flaperons on it to be able to get it down safer!
if you do set up flaperons please post details
dave
Old Oct 14, 2011, 06:12 PM
I don't want to land yet!
Joined Jan 2010
Flaperons are easy Dave, as long as you have a separate channel for each aileron and set your tx to flaperons... Then it's just a case of mixing. Dial in a certain amount for each stage... You can add elevator for each setting as well.
I am using a Spektrum dx7.
Strike3 is offline Find More Posts by Strike3
Old Oct 14, 2011, 06:16 PM
Joined Jan 2010
even a dx6i is possible..
Old Oct 15, 2011, 02:21 AM
Joined Jan 2010
arf back in stock..already ordered the replacement. Cant wait to put her back in the sky
Old Oct 15, 2011, 07:40 AM
Joined Dec 2007
I did thought of having flapperons but for a heavy 4S setup, you might need spoilerons setup instead. I have a feeling that Flaperons will cause it to flip forward due to it being nose heavy.
Perhaps a very small amount of flapperon would work.
pavcon, quite a wait there mate. lol I'm glad you finally got it ordered.
FusionTiger is offline Find More Posts by FusionTiger
Old Oct 15, 2011, 08:09 AM
Austria
Joined Jan 2004
I thought spolerons and flapperons are the same thing for these little bird.
The trick is to have a switch for put down both the ailerons,while put up a bit the elevator for compensate ... this will increase the lift at a cost of the additional drag ... so is nor nose nor tail heavy if properly set up. just perfect for slow down before landing.
I put almost on all my birds dual ailerons servos for achieve this result. The tricky part is to trim it properly .... I almost stuck in the air my big Yak 54 3D while trying this mixing
Predict how much elevator is needed for compensate the ailerons down is tricky, it is quite unique for each bird
Tchuss
e_lm_70
e_lm_70 is offline Find More Posts by e_lm_70
Old Oct 15, 2011, 09:07 AM
Joined Jan 2010
Mine is setup with flaperons and mixed elevator into it.. Works perfectly!
Oops... The hawk is set up like that but need to do the same with my Stinger
Old Oct 15, 2011, 11:00 AM
Joined Jan 2010
yeah fusiontiger. If i had the money i woukd have ordered 2 kits because im afraid all this wait will be there everytime its out of stock.
Anw.. Ofcourse i dont plan to nose it again
Old Oct 15, 2011, 12:08 PM
Joined Dec 2007
Ooo!!! Ok, I'll try flapperons with elevator mix! I was getting worried about the landing speed for a 4S setup on my already-overweight Stinger.
Old Oct 15, 2011, 03:00 PM
sickwitit's Avatar
Lewisville, TX
Joined Sep 2010
What do you guys recommend for painting this EPO foam? I have a bottle of acrylic paint that I brushed onto my Z-foam planes. Will this work good on EPO also?
sickwitit is offline Find More Posts by sickwitit
Old Oct 15, 2011, 03:13 PM
Joined Oct 2010
thanks for the reply there strike , i think i get the basics , i also use a DX7, do you mean a separate servo for each aileron ? rather than a separate channel ?
also with mixing in the elevator would it go up or down ?
i had my first flights on 4cell today , its only 2200mAh batteries that im using at the moment , landing wasn't a problem with theses sized batteries , but my flight times have dropped down to just 3 minutes , was getting 4 on the same sized 3cell packs , so it looks like bigger batteries are going to be required at some point , what sized batteries is everyone else using ? and whats your flight times please
pavcon , hope you dont have to wait to long for delivery , are you staying stock or going 4s ?
cheers dave
ha , just reread e_lm_70's post and the elevator go's up a little !
Old Oct 15, 2011, 03:20 PM
FLY IY, BREAK IT, FIX IT,
Hampshire, United Kingdom
Joined Jun 2005
Both. you need 2 servos on separate channels for flaperon/spoileron. Cant answer the other q's, sorry
Impailer is offline Find More Posts by Impailer
New Product New HobbyKing Viper Jet 70mm Fibreglass Jet Jagzilla Electric Ducted Fan Jet Talk 1405 Today 12:31 PM
Discussion Stinger F3B/F3F Vaclavs new weapon! SpeedMaster Multi Task F3X 124 Aug 08, 2013 10:00 PM
For Sale Nib sr71 64 mm ducted fan jet yf22raptor Aircraft - Electric - Jets (FS/W) 6 Mar 26, 2011 03:28 PM
Discussion HobbyKing EDF 64 Identification liam2317 Electric Ducted Fan Jet Talk 11 Dec 20, 2009 08:52 AM
