Old Jul 16, 2014, 05:25 PM
Scott J.
United States, NC, Wake Forest
Joined Jan 2013
Build Log
TM Elite
I going to start a basic build log on the Top Model Elite. This plane is an all balsa D-Box wing, which is different from many of the other TM planes commonly available here in the US. I was interested in an all balsa wing specifically for several reasons. First, I owned an Avia, and a Prelude and loved how both planes have flown. They are sweet fliers. However, I have had wing failures on them both from flying them in more wind than prudence would dictate (apparently). I am hoping the D-Box construction is strong (er). I know the wing will be easily repairable. I also hope the 3 panel wing offers flight characteristics as good as or better than my other 3 panel sailplanes.
The Elite is a 3 panel wing with a large center section - I am going to call it polyhedrial for now but once together may edit.
So here are the part weights
Rudder: 13g
L Elevator: 19g
R Elevator: 20g
C. Panel: 330g
R Wing: 170g
L Wing: 171g
Fuse w/Canopy: 294g
Parts w/bag: 151g
Total 1167g
S.
zephirus is offline Find More Posts by zephirus
Old Jul 16, 2014, 05:50 PM
Scott J.
Joined Jan 2013
1st Construction Challenge
When I opened the box to examine the plane, I was a bit surprised to see that the ailerons on each wing were split into to sections to accommodate dihedrial. Hummn, how am I going to join that so it lasts more than 5 flights?? TM has cleverly provided a pin to attach the 2 ailerons, but into soft wood? I am not too OK with that. So after consulting with my builder Sensei, he suggested gluing the pin in the larger servo driven aileron, and putting the pin in a brass tube/sleeve on the smaller aileron. To get a reasonable fit however (my brass tube choices were limited), I got some wire that fit the tube. I am sure I could have used the supplied pin if better LHS selection was available ... But one is metric sized the new pieces are SAE ...
Old Jul 16, 2014, 07:22 PM
Scott J.
Joined Jan 2013
Brass tube insert
Brass tube inserted into the smaller "slave" aileron - Amazing, I know !
Old Jul 18, 2014, 06:03 PM
Scott J.
Joined Jan 2013
Servo's
I went with the servos suggested by TM. They recommend HS82 for the flaps, and HS85 for everything else. I went with digital servos for the elevator and rudder controls. The servos are a bit big for the wing servo bays. I am thinking I should have just gone with MKS450 servos ... at least they would fit and are lighter. So I have ordered servo frames instead of using the supplied blocks. I hope this make the install easier. There has been a fair amount of posting about TM's use of the wood washer for the bell crank to pivot in. If you look in the latest Albatross thread or toward the end of the Prelude thread you can follow comment and build alterations. This builder supplied method is not met with warm regards. TM needs to step this up ... I will just grease the bell crank before final install.
Old Jul 20, 2014, 08:50 PM
Scott J.
Joined Jan 2013
Tail Controls - other
TM provides hardware for doing a pull-pull install for the rudder. After spending a longer than expected time contemplating the pro's and con's of pull-pull vs a rod install I went with a rod install. One factor in this again was the size of the servos. One major recommendation is to use smaller servos for all surfaces (not less powerful however). The 30x30x10 or 13mm size make it spaces tight or their are height issues. The servo in the fuse to control the rudder was so close to the brace for the wing it made me nervous on dry fitting. Also the size of the servo in the tail its-self took up alot of clearance space. I did not want to cut in the guide tubes only to find out there were clearance issues along the fuse exterior aft of the exit or find out the angle from the servo to the horn caused binding. So I opted for a Golden - rod install ... if you are a hater don't post !!
Additionally the platform for the servo in the fuse was not wide enough so I had to mod it a bit ... and sand.
Old Jul 21, 2014, 07:35 PM
Scott J.
Joined Jan 2013
Modified Servo Tray
Here is the modified servo tray for the push rod ... Once glued in place I can pull the rod and sleve at the tail exit to get it as taught as possible.
Old Yesterday, 06:55 PM
Scott J.
Joined Jan 2013
Servo frames
Due to the size of the servos, I could not use the otherwise fine TM servo blocks. I had to go to frames - now installed.
Sold Reduced!!! #20 Celectra Li-Po 4 Port Charger by Elite $ rjronrj Aircraft - Electric - Batteries & Chargers (FS/W) 3 Nov 02, 2013 09:10 PM
Sold Hobbico Accu-Cycle Elite Battery Charger/Cycler - $49 Shipped Sean C Aircraft - Electric - Batteries & Chargers (FS/W) 0 Oct 08, 2013 03:40 PM
For Sale vaporcone elite 2 gguzman767 Non R/C Items (FS/W) 0 Sep 24, 2013 06:16 PM
Discussion Elites’ strange plot to take over the world dll932 Life, The Universe, and Politics 2 Sep 23, 2013 04:31 AM
Sold Airboss 60 Elite ESC earp Aircraft - Electric - Power Systems (FS/W) 1 Sep 22, 2013 11:54 AM
