Keecat Electric Conversion
Amazing I cant seem to find a thread on the Richmodel Keecat-65 discussing an electric conversion. I did find one on an EDF conversion but I was looking at using an outrunner, 3 blade prop.
Anybody know of a thread and or have any info on this topic ? I have a motor and prop I want to use but dont think I'll have enough watts and was wondering if the AUW changed using an electric motor ILO of gas etc. http://www.avia-richmodel.com/Produc...In-Stock).html |
converted a bobcat(45-50) to electric.
rimfire .51 using a 13x8(can go up to 13x10) apc 100a esc 6cells 4000-5000mah and electric retracts. should power yours fine. just need to spin the prop fast(high kv) to keep the prop from getting to big.
Thanks everyone. I think Im going to use this Power Up 60 motor
![]() The Power Up 60 Sport is a 14 ounce, 500KV, 1400 watt outrunner brushless motor that is roughly equivalent in power to .60 size two stroke glow engines. It works well with 4, 5 and 6 cell Lipo This motor mount ![]() 6s 5000 lipo maybe a 12x8x3 prop. We'll see about that once I get it mounted and check for clearance etc. Im hoping to get by with a HET 75 amp ESC. We'll see.. |
You came in hot for your landings. Did you have to or you think it would glide more than you let it ? Did you add that canopy latch ? Do you know what your AUW was |
those were early flights.
canopy had a front tongue and rear thumb screw. it will accually take off from grass and belly land if needed. and a power 60 out runner will ned almos a 14-15" prop. i have had a lot of power 60 types convered. i just converted a twin widgeon that had OS FP 60s. those were replaced by tacon power 46 and spins the 11x7 props faster than the fp's did.. |
Looks like im going to have trouble with ground clearance using a 13x8 prop and probably even a 12x8. Not sure if a 11x8 or 11x9 will provide enough thrust.
I didnt use the motor mount mentioned above as the X mount mounted to the firewall just fine. I might have to manufacture a Z shaped bracket and bring the motor up an inch or 2. |
Joined Aug 2012
Ok after searching around and finding that pusher props are available I have made the decision that I am going with glow power on this one. The engine will be a super tiger .90. I did this mainly for budget reasons. I already had the engine but do not have the power system for a plane this size.
I will be interested in knowing how your maiden goes. |
| Thread Tools | |
| Wanted Keecat 65, NIB | davecee | Aircraft - Electric - Airplanes (FS/W) | 1 | Jan 27, 2013 05:04 PM |
| Wanted Keecat 65, NIB | davecee | Aircraft - Fuel - Airplanes (FS/W) | 0 | Jan 27, 2013 04:33 PM |
| Discussion Keecat Electric Conversion - Spec help please | 3d3dman | Pusher Prop Jet Models | 1 | Feb 15, 2012 09:53 AM |
| Blade convering question | cat5 | Micro Helis | 9 | Oct 21, 2005 11:52 AM |
| Convering for beginners | khaoz | Beginner Training Area (Aircraft-Electric) | 8 | Oct 03, 2005 04:25 PM |
