Old Mar 19, 2006, 10:01 AM
Flyinphil is offline
Find More Posts by Flyinphil
Strathroy Ontario Canada
Flyinphil's Avatar
Joined Jun 2004
CP2 Backwards servo!! Help!
Hi,
I burnt out a servo on my Honeybee CP2 and replaced it with another.
The hobbyshop sold me a blue HS55 Hitec servo. They said to just shave the tang off the connector and it would fit my 4in1. It works but the throw is backwards. Check this out
http://media.putfile.com/Backwards-servo
Is there anyway to reverse the throw? If i use the servo reverse switch on the esky transmitter it reverses both aileron servos.
Help me please.
Flyinphil
Flyinphil is offline Find More Posts by Flyinphil
Old Mar 19, 2006, 10:16 AM
DanT is offline
Find More Posts by DanT
DanT's Avatar
United States, TX
Joined Feb 2006
Your going to have to open up the servo and change the wining on the motor...
DanT is offline Find More Posts by DanT
Old Mar 19, 2006, 10:19 AM
pmackenzie is offline
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
If you decide to try this, change the wiring on the pot as well.
Pat MacKenzie
pmackenzie is offline Find More Posts by pmackenzie
Old Mar 19, 2006, 10:20 AM
SMaric is offline
Find More Posts by SMaric
Poole, Dorset, UK
Joined Mar 2004
Can't you remove the servo arm and re-fit 180degrees
It will then be on the other side of the circle and will move in the other direction
You'd need to check that the linkage would still be ok
SMaric is offline Find More Posts by SMaric
Old Mar 19, 2006, 10:34 AM
Gary Hoorn is online now
Find More Posts by Gary Hoorn
Chesapeake Bay RC Club
Gary Hoorn's Avatar
USA, MD, Annapolis
Joined Feb 2005
Take the 55 back and order an ESky servo from Helidirect. They cost about 9 dollars US.
Gary
Gary Hoorn is online now Find More Posts by Gary Hoorn
Old Mar 19, 2006, 11:09 AM
Flyinphil's Avatar
Joined Jun 2004
I could do this but why do I have to change the wiring on the pot?
Old Mar 19, 2006, 11:29 AM
pmackenzie's Avatar
Joined Dec 2002
You have to reverse the wires to the motor so that it runs in the opposite direction.
In order to keep the feedback loop happy you have to reverse the two outside wires on the pot as well.
If you don't it will just run all the way to one end of it's travel when you power it up.
Pat MacKenzie
Old Mar 19, 2006, 11:35 AM
Crash549 is offline
Find More Posts by Crash549
RALEIGH, NC
Joined Feb 2006
I feel like you could correct this problem with servo reversing and your swash adjustments?
Crash549 is offline Find More Posts by Crash549
Old Mar 19, 2006, 11:44 AM
Flyinphil's Avatar
Joined Jun 2004
This is what I thought too. It would be the easiest way. But. The servo reversing switch changes the direction of both the rear (aileron) servos on the Honeybee. Also there is no room to put the servo arm on 180degrees out.
I may have to try opening it up to see if I can change the wiring.
I already replaced the voltage regulator on the 4in1 that friedas well when the servo jammed so I should be able to do this.
I also just placed an order with Helidirect (first order from them) for a couple esky servos and some carbon fiber blades
Flyinphil
Old Mar 19, 2006, 11:52 AM
Crash549 is offline
RALEIGH, NC
Joined Feb 2006
I think we work on our heli's more than fly
Old Mar 19, 2006, 12:07 PM
Mike abcd is offline
Find More Posts by Mike abcd
Newbie
Joined Nov 2005
The E-Flte Blade CP stock S75 servos rotate the same direction as the stock CP2 ones and mount up fine using the existing holes. You might be able to find one locally.
http://www.horizonhobby.com/Products...ProdID=EFLRS75
Mike abcd is offline Find More Posts by Mike abcd
Old Mar 19, 2006, 12:15 PM
pmackenzie's Avatar
Joined Dec 2002
My guess is that FlyinPhil is stuck indoors on a Sunday, with lousy weather, a hot soldering iron and a servo he has already modified (sanded the connector).
Go for it Phil! Nothing to lose!
Pat MacKenzie
Old Mar 19, 2006, 12:45 PM
Flyinphil's Avatar
Joined Jun 2004
Pat MacKenzie
Hey you're right Pat!
Old Mar 19, 2006, 03:44 PM
dacaur is offline
Find More Posts by dacaur
Heli's rule!
dacaur's Avatar
Midvale, Utah, USA
Joined Mar 2005
just get another hs55 for the other aileron servo.... actualy your best bet would be to get 2 more hs55's.... with eccpm you always want to have matched servos, because if the speed of one servo is slightly different than the other 2, its going to throw things off and it wont fly as well...
dacaur is offline Find More Posts by dacaur
Old Mar 19, 2006, 04:03 PM
uabass is offline
Find More Posts by uabass
Joined Mar 2004
Nope, that won't work either. The Blade and CP2's stock TX's servo reverse switches are limited in function and mix. You will need a computer TX if you want to use Hitech or GWS servos.
uabass is offline Find More Posts by uabass
Hitec Servo.. Help me make it work!!! genovia Electric Plane Talk 5 Aug 20, 2002 01:38 PM
V-tail servo help mumblety-peg Electric Sailplanes 6 Apr 28, 2002 08:38 AM
Logo servo help needed, again mniadna Electric Heli Talk 9 Feb 07, 2002 08:55 AM
Sand In Servo - Help JohnO Parkflyers 3 Jun 15, 2001 08:07 PM
