Old Jul 15, 2013, 06:17 PM
FlyVA is offline
Find More Posts by FlyVA
"Flying is my life!"
FlyVA's Avatar
United States, VA, Salem
Joined Oct 2002
Above and below tails
Usually the bottom of a vertical stabilizer starts in the fuselage and extends upward. Mostly seen on DLGs, vertical stabilizers are equally 50% above and 50% below the fuselage so as to minimize the boom twist leverage generated when discus launched.
Here is an example of an “above and below” vertical stabilizer on a larger (actually 208”) sailplane which is this years AMA Nats XC winner “Frankenstein” by Peter Baumeler. What a beautiful sailplane.
Are there any aerodynamic disadvantages to an “above and below” vertical stabilizer?
FlyVA is offline Find More Posts by FlyVA
Old Jul 15, 2013, 06:41 PM
rrcdoug is offline
Find More Posts by rrcdoug
rrcdoug's Avatar
Canada, BC, Kelowna
Joined Aug 2010
With the very slender tailboom on this model, I can see the need to reduce torsional loads, hence the "balanced" vertical stabilizer.
As to aerodynamic advantages, a larger AR becomes possible but the fin/rudder is usually generating little lift compared to a wing (lifting surface) so I doubt a high aspect fin would make much difference.
rrcdoug is offline Find More Posts by rrcdoug
Discussion Stab Above Or Below The Boom? steelhead Hand Launch 22 Jul 24, 2008 11:52 PM
Discussion Slow Stick motor. Above or below?! twoshadetod Electric Plane Talk 7 Jan 27, 2008 07:02 PM
Discussion No hell below us, above us only sky. Michael in Toronto Life, The Universe, and Politics 10 Dec 08, 2006 09:24 AM
Discussion Gearbox/outrunner: above or below fuse? geekdom Beginner Training Area (Aircraft-Electric) 2 Jan 18, 2006 11:06 AM
Coast Guard c-130 pictures from above and below needed. Michael Heer GWS (Grand Wing Servo) 2 Nov 07, 2004 06:21 PM
