Old Dec 09, 2012, 12:30 PM
mybad is offline
Find More Posts by mybad
Sure, I can fly after sunset!?
United States, MI, Novi
Joined Jan 2011
Bench Testing
Sorry for the obvious question, but how do you use a wattmeter to bench test an electrical setup? I ran across related posts BEFORE I bought a wattmeter, but now I cannot find them!
I picked up an offbrand motor (EMP) and wattmeter at a swap meet, and want to test it before putting it on a plane.
I seem to remember something about limiting how long you run the motor, because the prop pulls a lot more watts on the bench than it does in the air. Don't want to burn up my power system. I assume you connect the wattmeter between the battery and ESC.
Do you first test the system without a prop on the motor, or will this damage the motor?
mybad is offline Find More Posts by mybad
Old Dec 09, 2012, 01:50 PM
foamflyer is offline
Find More Posts by foamflyer
Trapped in California
foamflyer's Avatar
United States, CA, Arcadia
Joined Nov 2003
Meter goes between motor and ESC. Run motor with prop. It is true that prop will "unload" in the air.
foamflyer is offline Find More Posts by foamflyer
Old Dec 09, 2012, 02:51 PM
jonone is offline
Find More Posts by jonone
jonone's Avatar
United Kingdom, Whitby
Joined Jun 2012
Using a Watt Meter - FLITE TIP
Flite Test - Using a Watt Meter - FLITE TIP (10 min 9 sec)
wach this on utube. J.
jonone is offline Find More Posts by jonone
Old Dec 09, 2012, 03:05 PM
mybad is offline
Joined Jan 2011
My wattmeter has two wires, but my motor has three. How do I connect between the two...any two wires?
Old Dec 09, 2012, 03:34 PM
erikc641 is offline
Find More Posts by erikc641
United States, NM, Las Cruces
Joined Jul 2012
You leave the motor wires where they are. You plug the battery into the battery side of the meter and the esc lead (where you would normally plug the battery) into the other. So it goes battery-meter-esc. Just solder on the connectors that match power system to the meter (unless it already comes with the ones you need).
erikc641 is offline Find More Posts by erikc641
Old Dec 09, 2012, 04:28 PM
JetPlaneFlyer is online now
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
The three wires go to the motor. The two wires that come out the opposite side of the ESC go to the battery. As you correctly said in your first post.. the wattmeter goes between ESC and battery (two wires)
PS.. running the motor without a prop wont do any harm at all. But you also wont get any meaningful readings from the wattmeter because without a prop there will be hardly any power being puled through the system.
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Old Dec 09, 2012, 05:14 PM
mybad is offline
Joined Jan 2011
Thanks everyone.
Oh, and my other question: Is there a maximum time you should test the motor ... 30 seconds etc to prevent damage? Or does it matter as long as you're not exceeding the ESC and motor ratings?
Old Dec 09, 2012, 05:45 PM
arbfrank is offline
Find More Posts by arbfrank
United States, PA, Lansdale
Joined Feb 2012
Hi mybad,
The amount of time you can run is determined by how much heat the ESC is creating. Since you may not get the normal air flow during a static test, you should monitor the ESC and motor temperature with some kind of meter.(IR or probe) Not your fingirs!!! Hope this helps. Heat is the enemy of the electrical componentes.
Frank Arbaugh
arbfrank is offline Find More Posts by arbfrank
Old Dec 09, 2012, 06:18 PM
C₄H₁₀ is offline
Find More Posts by C₄H₁₀
Wake up, feel pulse, be happy!
C₄H₁₀'s Avatar
United States, AK, Fairbanks
Joined Aug 2009
You should only run the motor as long as it takes for the numbers to stabilize so you can get a decent reading. Five to ten seconds usually does it.
C₄H₁₀ is offline Find More Posts by C₄H₁₀
Old Dec 09, 2012, 07:42 PM
rick.benjamin is offline
Find More Posts by rick.benjamin
Reduce the drama...
rick.benjamin's Avatar
USA, OR, Damascus
Joined Apr 2004
I agree with C4H10 (mooseberries mccoy) If you run it for any length of time,
you will notice changes as the battery begins to discharge.
This is normal, and as it is already a known fact, it's not useful information .
You're looking for watts and amps. That way you know if your over-loading your motor.
Take your readings, shut the test off.
rick.benjamin is offline Find More Posts by rick.benjamin
Old Dec 10, 2012, 07:05 AM
mybad is offline
Joined Jan 2011
Thanks everyone!
Build Log SX-2 large custom built coaxial-bench test Krox Coaxial Helicopters 13 Jan 03, 2013 06:14 PM
Discussion Your bench Testing Setup ??? old_dude Electric Ducted Fan Jet Talk 28 Jul 09, 2012 01:36 PM
Discussion HFPro Bench Testing Question SGH Hoverfly Technologies 75 Jul 08, 2012 03:11 PM
Discussion Bench test BL motor & ESC Mykro Power Systems 3 Apr 21, 2012 09:36 PM
For Sale himaxx 2825 -2700 kv only bench tested ED3 Aircraft - Electric - Power Systems (FS/W) 4 Mar 07, 2012 06:59 PM
