Old Apr 25, 2008, 12:33 AM
john_auberry is offline
Find More Posts by john_auberry
Joined May 2006
Build Log
Well, I started tinkering with it and so I guess I need a build thread.
I started playing with it and now I farther along on it then my other projects. I got my Fairwind running to take to the beach but I would like to have this schooner finished. It want fit in my car but my father in law said he would take it in his motor home. Dont know where Im going to store it though?
It started at a freebie. I bought a Fairwind and got this old EC12 hull.
The decks was rotten and it looked about 20 years past its prime. I wondered what I was going to do with it. I was in the process of building a schooner so I figured Id throw it under the back porch and one day make a static model out of it. After my ballest system didnt work out on the schooner I was building the old hull started calling me. I dug it out from under the back porch and sat on the ground beside it looking at its graceful lines. I realized it would make a beautiful schooner with a little cutting and glassing. So I made a plan.
I would reshape the stern and add about a inch and a half to the gunrails.
john_auberry is offline Find More Posts by john_auberry
Old Apr 25, 2008, 12:36 AM
Joined May 2006
I started by ripping out the old rotten deck and cutting the stern off. I then built a new one out of fiberglass.
I then started add the gun rails.
Old Apr 25, 2008, 12:40 AM
Joined May 2006
I was blowing time waiting on glue to dry and started making two anchors out of black acyclic.
Then I carved them with a dremal tool.
Old Apr 25, 2008, 12:42 AM
Joined May 2006
I might halve to make two more this look a little big
Old Apr 25, 2008, 12:43 AM
Joined May 2006
I also stared on the new rudder
Old Apr 25, 2008, 12:44 AM
SloopProvidence is offline
Find More Posts by SloopProvidence
SloopProvidence's Avatar
San Diego, CA
Joined Jul 2007
That must be some time you need to kill. I had better keep you away from my time... I slaughter enough of my own, I don't need any help in that dept!
I think the wooden cross arms of the anchor should be a bit higher on the shaft of the "iron" part. Otherwise it looks great.
Are you going to leave the bulwark thin (fiberglass)? If so, are you also going to leave the caprail out and fabricate it in wood and stain it? Also are you going to put a full new wood deck on her? Fellow Capts. want to know!
Jason
SloopProvidence is offline Find More Posts by SloopProvidence
Old Apr 25, 2008, 12:53 AM
Joined May 2006
what colors do you like?
Old Apr 25, 2008, 12:55 AM
Joined May 2006
or
or
Im feeling the black gray, or the black and red
Old Apr 25, 2008, 01:01 AM
Joined May 2006
No the rail will be several layers built up to the same thinkness ass the rest of the hull........Point taken on the anchors I just google it and your right. As for the deck, it will be a layer of balsa with a thin coat of glass then planked with oak or aspen. The cap rail will be a stained oak as well as a rub rail (I think thats what its called) that will run the lenth of the ship about 2 inchs below to cap rail.
Jason
Old Apr 25, 2008, 01:10 AM
DarthDude is offline
Find More Posts by DarthDude
Landlubber
Kuala Lumpur, Malaysia
Joined Jul 2007
Wow......
And here I am carping about how to lay a balsa/teak/beech veneer on my ready-built Fairwind...... geez man- you really make me look bad!
Ok..... so now I've been shamed into getting going on that Fairwind again... and then onto my own Harpy and then.... and then.... I STILL can't see me building a schooner like this.
Anyhoo.... this one is my favourite colour scheme (just in case you're taking votes):-
DarthDude is offline Find More Posts by DarthDude
Old Apr 25, 2008, 01:27 AM
San Diego, CA
Joined Jul 2007
"Rub rail"='Wale' is the usual term for it. On my Providence it's black and about 2-3 ft high. I've not seen that many boats with varnished wales... but the caprails definitely!
Depending on how large you quarterdeck step is you may also wish to raise the quarterdeck bulwark too, or at least the rail. Give yourself the chance to do some scrollwork like on the Providence, but only a single layer!
Looking good!
Jason
Old Apr 25, 2008, 01:32 AM
San Diego, CA
Joined Jul 2007
John,
Yes, Black above the waterline and Red "lead" below. The "Classic" colors for a working schooner! I think red is the right color for anything below the waterline on anything composite or metal hulled. Copper was a good choice back in the late 1700-1850s, and before that the off-white "tallow" color (like on my Providence).
That's my vote... but after all it is your boat!
Jason
Old Apr 25, 2008, 01:49 AM
Joined May 2006
we are completely on the same page. There will be a fancy rail close to what yours have.. I have been looking for the lighting on the schooners and cant find any pics.. I know older style ships had fancy lanterns on the back. but I have never seen any on schooners. I have a led kit Im dying to use.
Looking good!
Jason
Old Apr 25, 2008, 01:53 AM
Joined May 2006
Carved the wood crosses on the anchors and added same fake rust to them but it turded white on the acrylic???? A little sanding to remover the burs and they are ready.
Old Apr 25, 2008, 01:55 AM
Joined May 2006
Oh Jason, thanks for the correction on the wales. Im trying to learn my terms.
GWS Spitfire Build thread (with glassing tutorial) David Winter GWS (Grand Wing Servo) 156 Sep 14, 2009 05:42 AM
My Girlfriend's GWS Beaver Build Thread (With Pics) nitroaddict Parkflyers 84 Aug 11, 2007 10:51 AM
looking for build thread with upclose photos HIGHFLYER99 Foamies (Kits) 13 May 21, 2005 08:54 PM
22.5 inch Sirocco With CD ROM build thread power 3D Flying 119 Feb 13, 2005 02:56 PM
Need A10 Build Help - What's with this small battery bay? mrebman Parkflyers 17 Apr 06, 2003 02:39 PM
