Old Jul 05, 2007, 09:15 PM
AmateurE is offline
Find More Posts by AmateurE
AmateurE's Avatar
Joined Feb 2003
McCoy .049 Glow Head Replacement
I recently rediscovered an older McCoy that I pulled from an old Stuntman 23 that didn't win a battle with some falling plaster during a remodeling job. I purchased new fuel, modified a battery clip to use my 1 cell glow starter, bolted the McCoy to a test stand and it actually fired up and ran.
Tried it a few days later only to find the 1 cell glow starter wasn't at full charge. No problem, I connected my field box's glow start plug, and promptly fried the glow wire as the adjustable setting was at max.
It is my understanding is that McCoy glow heads are unobtainable. I found the Mecoa glow plug adapters that utilize standard glow plugs. It seems I had read (somewhere) that these adapters while they appear to be a quick solution make running the engines problematic (something about too much metal mass or the compression being changed). Anyone have any real life expierience with glow head adapters? Or should I place the McCoy on a display shelf?
AmateurE is offline Find More Posts by AmateurE
Old Jul 07, 2007, 03:54 PM
burtcs is offline
Find More Posts by burtcs
Corvallis, Or.
Joined Jun 2007
AmateurE:
I can't comment on the McCoy but Mecoa's unit for the cub is dismal (too little compression I think). That said they will work but not well. If you could find someone to make you a head that uses the Nelson glow plug, that would work. I use the Galbreath head and Nellson plug on Cox's and Norvels and they work really well. The McCoy's are cute but it may be that time...
regards - Steve B.
burtcs is offline Find More Posts by burtcs
Old Jul 08, 2007, 07:22 AM
gzkpez is offline
Find More Posts by gzkpez
Joined Jan 2006
Does not the cox/norvel/wasp fit? I think when I had one, when they were newer, I ran cox heads on them. I remember them looking kind of funny with the wrong head on.
gzkpez is offline Find More Posts by gzkpez
Old Jul 08, 2007, 09:27 AM
coosbaylumber is offline
Find More Posts by coosbaylumber
Joined Jul 2005
The McCoy brothers often go to the Whittier Narrows auto circle now. I think the little McCoy was one of the first engines to be dropped once Testor's got into gear.
Problem with MECOA forum is that I do not think there is enough problems with glow engines, so folks do not read it as often. You thus get fewer opinions. But did find there a fellow who repairs older glow plugs. I have K&B Sky Fury engines. They suffer from the low compression malady you described, when switching to modern adapted glow plugs. This fellow who used to be in Ohio would weld a new glow wire into your old core. Thus you then obtain original performance, not just acceptable (low) performance. I haven't sent any heads east for couple years now, and no longer have his address. But was referred to him via a paragraph in MECCA.
Wm.
coosbaylumber is offline Find More Posts by coosbaylumber
Old Jul 08, 2007, 08:24 PM
AmateurE is offline
AmateurE's Avatar
Joined Feb 2003
Thanks for all the replies/options. I guess the quickest solution would be to try the Cox head. The Galbreath/Nelson head certainly makes style points in that it keeps to the original look. We'll see what the future holds for this old engine.
Bob
Old Jul 09, 2007, 10:55 AM
madsci_guy is offline
Find More Posts by madsci_guy
Figure Nine Champ
madsci_guy's Avatar
North Texas
Joined Nov 2002
Uh, A Cox head won't fit a Testors/McCoy cylinder. At least not mine (late 60's vintage, off of a Skyraider). Different diameters at the screw thread.
madsci_guy is offline Find More Posts by madsci_guy
Old Jul 20, 2007, 08:57 PM
Balsabird is offline
Find More Posts by Balsabird
Balsadustus Producerus
Escondido, CA USA
Joined Jan 2001
If you can access a 1/4-32 tap (Graingers, etc?), you could try to modify the existing head to take a common glow plug. These were available for the Cox engines from .049 to .15 some years back, from Kustom Kraftsmanship, now out of business. They did work, but as noted above were not as good as the real Cox heads. But it might keep the engine in the air.
Balsabird is offline Find More Posts by Balsabird
Old Jul 29, 2007, 11:20 AM
bob_v5 is offline
Find More Posts by bob_v5
electronics gremlins hate me..
middlesbrough, uk
Joined May 2007
I had that idea of modifying the old head, does anybody know why it would not be as good as the unmodified one?
bob_v5 is offline Find More Posts by bob_v5
Old Jul 29, 2007, 11:32 AM
pmackenzie is online now
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
There are a few theories about why changing from a stock head to one modified for a standard glow plug doesn't run as well.
IMO the main thing seems to be that the area around the plug is never quite as smooth.
You would be better off switching to a Nelson or "Turbo" type plug. Both of these seal at the bottom of the plug.
Some DIY details for the Turbo plugs are online:
http://www.rcuniverse.com/forum/m_45..._1/key_/tm.htm
http://www.clstunt.com/htdocs/dc/dcb...mesg_id=272831
You could also post on Stuka Stunt (second link) to see if anyone has any stock heads available. Lots of motor guys on that site.
Pat MacKenzie
pmackenzie is online now Find More Posts by pmackenzie
Old May 20, 2009, 08:06 AM
vendo is offline
Find More Posts by vendo
vendo's Avatar
Joined May 2009
old engines
I have a bunch of vintage engines,if i provide a list can you tell me how much they are worth?
vendo is offline Find More Posts by vendo
Old May 20, 2009, 08:56 AM
Figure Nine Champ
madsci_guy's Avatar
North Texas
Joined Nov 2002
You'd probably get a good idea just by looking at E-Bay or looking through this board. http://www.rcgroups.com/aircraft-fue...ries-fs-w-362/ You can search through the threads for your brand and see how much they got for it.
Old May 20, 2009, 09:07 AM
unattainium is offline
Find More Posts by unattainium
Chicago
Joined Jan 2009
As others have pointed out the long term solution is either a new head with a Nelson plug or your burnt head modified to fit a Nelson. Then you have high quality plugs for about $4.50 and most likely better performance than stock.
unattainium is offline Find More Posts by unattainium
Wanted .049 Glow Head Starter Clips ronmeister Aircraft - Fuel - Engines and Accessories (FS/W) 4 Jul 16, 2007 09:45 PM
For Sale Cox .049 Glow plug head $10 jimx5000 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jan 10, 2007 11:56 PM
Off Site Cox .049 .051 High Compression Glow Head NIB lightflyguy Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jan 02, 2007 09:01 PM
Wanted Cox .049 throttle sleeve, and glow head. ronmeister Aircraft - Fuel - Engines and Accessories (FS/W) 0 Sep 05, 2006 03:51 PM
What speed motor is equal to an .049 glow engine? -EZ-Bee Electric conversion attempt try2fly Power Systems 12 Mar 19, 2004 10:12 AM
