Old Mar 28, 2015, 03:57 PM
Joshua Wesley is offline
Find More Posts by Joshua Wesley
Faster!
Joshua Wesley's Avatar
United States, NV, Sparks
Build Log
Republic-Ford JB-2 Loon, 90mm by Phil Wesley
Here is the latest out of my Dad's shop; Republic-Ford JB-2 Loon. Its now in my shop for completion and to make the takeoff dolly. Hope to have it flying in the next couple weeks. We are both convinced this little beast will have a short life.
Span: 46"
Area: 437 sq"
Length: 63"
Fan: 90mm Schubeler DS-51 DIA HDT
Motor: ARC 36-75-1 1680kv
ESC: Ice 100
8S 3700 to 5800 batteries
-Joshua
Joshua Wesley is offline Find More Posts by Joshua Wesley
Old Mar 28, 2015, 04:50 PM
turbonut is offline
Find More Posts by turbonut
Pro Horder
turbonut's Avatar
upland CA
Joined Dec 2004
Nice work! it should fly well just be ready for the thrust to pitch it nose down at WOT...I have a K&A V1....Don't go full throttle if you are low and slow . Bring up the power slowly.
Old Mar 29, 2015, 10:16 AM
Faster!
Thanks! Pitching down under power is what we expected, and we put a considerable amount on up thrust (I guess that's what you'd call it) to help compensate. I have a couple aircraft that pitch hard one way or or the other slow and WOT, that's what makes them a challenge. If everything flew like RVs and Cherokees, I would be bored out of my mind.
It would be neat to develope an airspeed and throttle to elevator trim mix. Didn't Piper work on something like that for the Piper Jet?
First step will be rigging the HS-125MGs in the wings. Pictures to follow...
Old Mar 29, 2015, 10:23 AM
Faster!
Color Scheme
Incase some of you are questioning our color scheme, here is a photo of an LTV-N-2 Loon at the New England Air Museum.
Old Mar 31, 2015, 05:54 PM
Quorneng is offline
Find More Posts by Quorneng
Joined Feb 2007
Snap!
My JB-2 Loon
Description:
A bit smaller at 40" span and I expect rather lighter at just 20oz all up with an 1800mAh 3s but at that weight it allows the use of a small 55mm EDF in a true scale duct.
The basic Fieseler Fi103 was aerodynamically pretty efficient so I would expect yours to fly well although likely a great deal faster than mine does!
I look forward to a video.
Quorneng is offline Find More Posts by Quorneng
Old Apr 01, 2015, 03:00 PM
Larry Dudeck is offline
Find More Posts by Larry Dudeck
Larry Dudeck's Avatar
Williamsville, NY, USA
Joined Sep 2000
Extend an imaginary thrust line from the center of the fan exhaust through the balance point by raising the discharge end of the nacelle. That way there will be no pitch change as a function of throttle position.
Larry Dudeck is offline Find More Posts by Larry Dudeck
Old Apr 01, 2015, 05:34 PM
turbonut is offline
Pro Horder
turbonut's Avatar
upland CA
Joined Dec 2004
That would make for a funny looking V1 i think..ask how I know..Lol
The last time i flew i was looking into a deflector in the tail pipe to angle the thust up. But havent done much with it yet
Old Apr 03, 2015, 04:07 PM
Faster!
Yes, that would cancel pitch changes with throttle but it would make for not only a funny looking V1 like turbonut points out, but would induce all sorts of other issues. Just like everything else in aviation its a series of compromises.
My brother-in-law tells me that the 737 he flies pitches up with throttle. To compensate with thrust angle would mean pointing the engines exhaust straight down. I doubt it would fly, or even taxi!
Its just going to take some piloting skills, i'm sure I can do it.
Old Apr 03, 2015, 05:43 PM
turbonut is offline
Pro Horder
turbonut's Avatar
upland CA
Joined Dec 2004
Yea Just go for it.. I have been flying mine with no mods to thrust other than a bit of nose down trim at full throttle. And I flew it for a long time with out that.
Here is my old thread. its long but there is some vid of it flying
http://www.rcgroups.com/forums/showthread.php?t=581508
Build Log Wittman Tailwind, a Phil Wesley Design Joshua Wesley Scale Kit/Scratch Built 4 Feb 03, 2014 07:53 AM
Discussion Spatha 70mm EDF Scratch Build by Phil Wesley Joshua Wesley Electric Ducted Fan Jet Talk 23 Jun 15, 2009 11:11 AM
Cool Sport Twin by Phil Wesley VIDEOS ADDED Joshua Wesley Sport Planes 34 Jan 21, 2009 08:16 PM
Cool CRASHED Javelin Sport Jet Scratch Build by Phil Wesley DELTA EXPERT NEEDED Joshua Wesley Electric Ducted Fan Jet Talk 35 Dec 25, 2008 04:59 AM
Discussion Harmon Rocket III by Phil Wesley NEW LOOK!! Joshua Wesley Electric Plane Talk 19 May 03, 2008 08:57 AM
