Old Mar 07, 2013, 03:45 PM
Djreversal is offline
Find More Posts by Djreversal
Joined Feb 2013
Electricians Help ?!?! 24v 1800w Dell poweredge 6650 Setup
Hey guys.. So i am about to start hacking away and building a power supply / charging station. Most of my parts are in but i ran into 1 problem that i would like to try and get some help on. I purchased some power cords from cables.com and they are not the proper setup..
Power Supply has a C19 recepticle, which is the cable i have, but the opposite end on my power cord is a C20, not a typical wall outlet plug. Now i am going to be using this Charging Station hooked up to my 10000w Generac Generator which features (4) 120V 5-20R GFCI ... So they are 20 amp breakered outlets. I would like to know can i just buy a 5-20 Plug and cut the 1 end off this and wire them up. Its only 3 wires. Should basically follow the same lay out i would think..
2nd - Can i make a "Y" from my 2 plugs to 1 cord. It would just go for ex. Pos and Pos tied together to the 1 pos, then neg and neg tied together to the 1 neg, and then the 2 grounds to the ground correct?!
My power supply is 24v 1800 watts so 1 20 amp breaker should supply that amount correct?!?! If not i will just make 2 seperate power cables but it looks like i could get away having 1. Any feed back would help a bunch!
Another question... the plugs i have say 20a 250v ... Does this just mean its capable of that, like can i run 120v threw this with no issues?
Power Supply Pic -- http://www.stuartconnections.com/640...pply-86GNR.jpg
Current Cable i have - http://ecx.images-amazon.com/images/...YL._SX300_.jpg
5-20 Plug - http://www.bhphotovideo.com/bnh/cont...G&A=details&Q=
Mark
Djreversal is offline Find More Posts by Djreversal
Old Mar 07, 2013, 06:53 PM
mono is offline
Find More Posts by mono
mono's Avatar
Joined Aug 2008
hello Mark
you may find the following threads of interest although not specifically the unit you have...
http://www.rcgroups.com/forums/showthread.php?t=1404536
http://www.rcgroups.com/forums/showthread.php?t=1292514
Regarding your questions...
Yes, but if it's to feed 2 power supplies, you need to watch the loading.
A 20A breaker at 120V is good for 2400W, disregarding power factor and other variables.
The 20A/250V is the maximum advisable rating for the plug, so it's fine.
mono is offline Find More Posts by mono
Old Mar 07, 2013, 07:07 PM
Joined Feb 2013
Great mono ... Thanks for the help. These 2 c19 plugs i have now are 12awg .. im going to Y them together and then get some 10/3 power cord and tie that into a 5-20 Plug for my generator... Looks like it should all work out fine... Max load on my PL-6 is only 1000 watts.. so this baby should barely working at that draw.
Help! Converting Dell Poweredge 4300 PS Choisan Batteries and Chargers 6 Feb 28, 2013 09:08 AM
Discussion Dell poweredge 6650 server PSU connecting in series help. Eddie500 Batteries and Chargers 5 Nov 10, 2012 08:17 PM
Sold 2 Dell Poweredge 6650 12v 900 Watt Power Supplies newheliguy81 Aircraft - Electric - Batteries & Chargers (FS/W) 3 May 13, 2012 10:00 PM
Discussion Dell Poweredge 6650 for RC use heli21 Batteries and Chargers 0 Feb 24, 2012 04:59 PM
Discussion Poweredge 6650 Dimensions? pctomlin Batteries and Chargers 3 May 28, 2011 08:43 PM
