Old Dec 03, 2012, 12:22 AM
12Deathcon is offline
Find More Posts by 12Deathcon
Australia, QLD, Brisbane
Joined Dec 2012
Help!
Eclipse 7 no throw using rudder stick
Hey,
I have been using an eclipse 7 for a few years now and i love the radio...... I recently did the Eclipse 7 2.4 GHz conversion and since then i have had no throw from the rudder channel.... i tested the reciever with my Aurora and it works fine, i also tested the module with one of my mates Eclipse 7 and it worked fine as well.... I was wondering if anyone has any idea of what could be wrong.... I have been told it could be the rudder sticks potentiometer... any ideas...
12Deathcon is offline Find More Posts by 12Deathcon
Old Dec 03, 2012, 12:36 PM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
Originally Posted by 12Deathcon View Post
Hey, I have been using an eclipse 7 for a few years now and i love the radio......
Please enter your country of domicile into your profile as answers can differ accordingly.
What happens when
1. Different model number is used? better yet a new model number that has
had a "reset" (manual page 12) to delete any residual data?
This in case EPA settings or Dual rate settings may have zeroed throw.
2. Original module re-inserted and used with the PPM/QPCM receiver?
3. EPA is extended to max - any sign of movement?
If rudder still does not work correctly, then please contact your service centre:
Hitec Warranty & Service - homepage.
Note: Hitec USA only services North/South America and Canada.
"Hitec USA customer service department is available Monday through Friday*
from 7am- 4:30 pm Pacific time. Reach us at 858.748.8440 or
service@hitecrcd.com any time you have a question"
If you are from a country that is outside North and South America, please contact the
Hitec distributor in your country for service.
. Hitec Eclipse 7 & 7 Pro FAQ - Quick Setup and Additional Programming
Alan T.
Alan's Hobby, Model & RC FAQ Web Links (quick search = Ctrl+F)
A.T. is offline Find More Posts by A.T.
Old Dec 04, 2012, 05:48 AM
Joined Dec 2012
Hey,
Thanks.
The radio has had different models programed into it. These programed models have been reset a couple of times with little success. I did reinstall the original module that was in the radio and had the same poroblem. I replaced the original battery in the radio with another new hitec battery.
I did contact the hitec service centre and was told to get in contact with a radio repairman, to save the $150 for the service charge which i was willing to spend. If i cant get it fixed i will delv into it myself which i do with the televisions i repair.
Thanks for the help.
Discussion Flash 5x setup: Left stick - Throttle, Right stick - Rudder/Elevator ?? John Baughman Beginner Training Area (Aircraft-Electric) 4 Jun 11, 2012 12:21 PM
Help! Rudder servo limited throw in one direction shezza Beginner Training Area (Heli-Electric) 0 May 21, 2012 02:30 AM
Help! HItec Eclips 7 switching aeleron to left stick??? Eakilroy4 Radios 15 Jun 03, 2006 08:46 AM
What stick to use for rudder on a rudder-only plane? tww1fa Beginner Training Area (Aircraft-Electric) 8 Mar 16, 2004 05:28 PM
Rudder throws on litestik use 1 1/4 russ6421 Parkflyers 2 Jul 05, 2001 12:36 AM
