Old Jun 16, 2001, 08:51 AM
JensJakob is offline
Find More Posts by JensJakob
Frederiksberg, Denmark
Joined May 2001
Speed control and diode ?
Hi
I just got my new Ripmax xtra-22 speed control for usage on my Wingo.
And I guess that the best thingis to disable the brake, so I wont have the propeller dragging, but am able to let it freewheel.
There is a big diode together with the control, but no mentioning of it in the instructions.
Should I solder this into the positive wire form the speed control to the motor ?
What does it do ?
Can I hurt the speedcontrol if I dont solder the diode inti the positive wire, and the motor freewheels and acts like a dynamo ?
JJ
JensJakob is offline Find More Posts by JensJakob
Old Jun 16, 2001, 10:07 AM
Fred Marks is offline
Find More Posts by Fred Marks
Ijamsville, MD, U.S.A.
Joined Mar 2001
Jens; You must be certain that the banded end of the diode points to the + output from the ESC. If you reverse it, you will ruin the ESC. Please look at www.fmadirect.com ; click on FAQ; and read the section re electrical noise. Having the diode in the circuit does two things: 1) Cuts electrical noise because it rectifies noise from the motor brushes and 2) absorbs inductive kick as the motor field collapses and converts it to DC(Which improves effficiency)
Fred Marks is offline Find More Posts by Fred Marks
Old Jun 16, 2001, 10:08 AM
radix2 is offline
Find More Posts by radix2
Radix malorum est cupiditas
radix2's Avatar
Joined Jul 2000
Jens,
solder the diode across the motor terminals, make sure that the positive lead from the speed control goes to the banded end of the diode. The diode provides a path for the inductive currents generated by the switching of the ESC.
There really should be some directions with your speed control (with diagrams) to show how to install the diode.
The diode will not have any effect on the braking function of the esc.
With a plane like the Wingo, and most slow flyers, you will be keeping a little throttle on during landing typically.
radix2 is offline Find More Posts by radix2
Old Jun 16, 2001, 01:45 PM
steve lewin is offline
Find More Posts by steve lewin
N. Staffs, UK
Joined Jan 1997
And you don't want to disable the brake. A freewheeling prop has a lot more drag than a stopped one. The brake is a good thing.
Steve
steve lewin is offline Find More Posts by steve lewin
Old Jun 16, 2001, 02:38 PM
Mike C is offline
Find More Posts by Mike C
Mike C's Avatar
Roxboro, NC U.S.A.
Joined Sep 2000
Be sure to check and double check which end you solder the stripe on the diode to. I just trashed a new speed control by doing this backwards. Bad, very bad!!!! Battery got hot and smoke commenced to rising from the speed control. Tried to repair this myself and caused more damage but the folks at FMA gave me a discount on a new one. What they call the crash and burn policy!!
Fitting title. I can bet that I NEVER make that mistake again.
Mike C is offline Find More Posts by Mike C
Old Jun 16, 2001, 02:43 PM
lymon is offline
Find More Posts by lymon
Senior Member
Houston
Joined May 2001
why does a freewheeling prop have more drag?
lymon is offline Find More Posts by lymon
Old Jun 16, 2001, 04:23 PM
Joined May 2001
Thank you very much everyone for the info.
1. A diode soldered with the band going to the negative cable, is indeed a very bad thing. Anyone able to say shortcut ? I should have thought of that myself.
2. Well I had thought of inserting the diode into the positive weire, as a protection against current running back into the ESC. But I can also understand the idea of placing it going from the negative to the positive wire, as a sort of "rectifier".
3. A braked propeller gives less drag than a freewheeling one ? I can partly understand this, but I would like to read some background info, to help me understand it better.
Happy flying
JJ http://www.zorck.dk/rc - Now with Wingo building
Old Jun 16, 2001, 10:23 PM
Joined Mar 2001
Jens; A freewheeling prop presents a "flat-plate" area to the air equivalent to the rotation speed and blade area. The Rolls Roysce Dart engines (And others) with turboprops used flat pitch rather than prop reversing for braking during landing. The blades were brought to flat pitch and accelerated to make the flat plate area maximum. Helicopter performance is calculated on the basis of "solidity", i.e., the blade area X RPM is hthe measure. Same thing.
ZAGI speed control R/Cbeginner Electric Plane Talk 11 Jul 13, 2001 10:34 AM
Jeti speed control repair 6 amp? Eddy Electric Plane Talk 5 Jul 01, 2001 09:36 PM
Kontronik speed control question Eddy Electric Plane Talk 12 Jul 01, 2001 12:25 AM
Is there a speed control that will give me 3 servos with a speed 400 & 10 cells martin johnson Electric Plane Talk 4 Jun 04, 2001 12:47 AM
Tech MC-Air 60 speed control Theuns Electric Plane Talk 0 May 29, 2001 02:28 PM
