Old Jan 23, 2013, 02:27 PM
signguy's Avatar
Swansea, Massachusetts
Joined Dec 2004
Adding a hitec 72 mhz module to a 9x.
I have a turnigy 9x that I use for FPV. I fly from inside my car ( its cold here ) and use an old usb cable to be able to place my module on the roof while I sit inside. This works great, but the stock module doesn't have much range. I have an old Hitec radio with a futaba type module. I tried making the same type of setup as my remote module, but it doesn't work. As soon as I turn on the radio, the servo centers, but thats it.......no movement. Is there a pulse width difference between the 9x and hitec? I am running er9x so I can change the pulse timing ( I think ). I did try a very short cable, thinking my 6' cable had too much loss for the hitec module...no go.
Any help is greatly appreciated. Wish I knew more about electronics...
BobD
signguy is offline Find More Posts by signguy
Old Jan 24, 2013, 07:57 AM
syberjunkie's Avatar
Lees summit, mo
Joined Dec 2004
you need one of these bad boys:
http://www.flytron.com/openlrs/123-f...e-adapter.html
I think the 9x (jr) and hitec/futaba ppm signal is inverted.
syberjunkie is offline Find More Posts by syberjunkie
Old Jan 24, 2013, 08:05 PM
signguy's Avatar
Joined Dec 2004
Thanks SYBERJUNKIE. I think I might be able to electronically invert the ppm signal.....if its the same as positive shift / negative shift ER9x does that ( I think )
thanks again
BobD
Old Jan 25, 2013, 02:40 PM
signguy's Avatar
Joined Dec 2004
Got it working!! Changed shift from positive to negative in the er9x software and it works great. Now I'll have some range for FPV using my turnigy 9X
Sold Futaba Tx FP-T8UAP PCM 1024 72 Mhz Module Rosster Aircraft - General - Radio Equipment (FS/W) 11 Feb 11, 2013 08:45 PM
Recievers - 72 mhz Berg/ JR/ Hitec/ GWS tele1974 Non R/C Items (FS/W) 0 Jan 13, 2013 10:50 AM
For Sale For sale: Futaba 9CHP MODULE 72 MHZ ( FP-TP-FM )+ DUAL CONV. CRYSTAL 72 Mhz CH 42 TAREK.SAADE Aircraft - General - Radio Equipment (FS/W) 0 Jan 22, 2008 07:38 PM
