Old Nov 14, 2013, 10:58 AM
Altitude is my friend...
Depronicus's Avatar
Southern California
Joined May 2009
Talon 90 ESC users: Your opinions, please.
I searched the Power Systems forum, but I thought I should inquire here, as well:
How do you Talon 90 speed control users like your units? It appears to be a heckuva deal: Ninety bucks for a big ESC with an on-board 20-amp BEC, 6V or 8V output, and full programability with the Castle Link and its software (which I already have).
Any user experience input you might have would be appreciated.
Depronicus is offline Find More Posts by Depronicus
Old Nov 14, 2013, 07:46 PM
Addicted to 3DHS and EF
3Daddict's Avatar
United States, OH, Bristolville
Joined Oct 2010
actually they are only $70-75. I just bought one, I have not been able to use it yet though. I am assuming it will be a good esc as it is made by Castle Creations. hopefully other people who haved put a lote of time on it will chime in.
3Daddict is online now Find More Posts by 3Daddict
Old Nov 14, 2013, 08:37 PM
wedoitall's Avatar
United States, WV, Clay
Joined Sep 2012
had one on a motrolfly 3615 and thought it was really good. wouldn't hesitate to use it again. I did have the align version
wedoitall is offline Find More Posts by wedoitall
Old Nov 14, 2013, 08:50 PM
3Daddict's Avatar
Joined Oct 2010
what is the Align version?
Old Nov 14, 2013, 09:05 PM
FoamyFactory.com
Tim H.'s Avatar
USA, TX, Fort Worth
Joined Nov 2001
I have 2 and they are great. One in a Trex and one in my Beast 60e. However DO NOT use it on a 28 pole motor (Bigger Hackers). Anything else and they are great!
Tim H. is online now Find More Posts by Tim H.
Old Nov 14, 2013, 09:13 PM
United States, NC, Ellerbe
Joined May 2012
I've got one in a 60" EF edge running HV servos and I love it.
snotrag is offline Find More Posts by snotrag
Old Nov 14, 2013, 10:07 PM
Barefoot Birkinsomething
rcbirk21's Avatar
United States, CA, Hayward
Joined Aug 2004
i have one, works fine. definitely does not have the same amount of programmability that the ice/edge series has, but still works well
rcbirk21 is offline Find More Posts by rcbirk21
Latest blog entry: Joe's Battery Contraption
Old Nov 15, 2013, 08:37 AM
wedoitall's Avatar
Joined Sep 2012
4mm bullets and supposedly better solder tabs.
Old Nov 15, 2013, 11:24 AM
A man with too many toys
United States
Joined Feb 2001
The main problem is that the motor connectors are large and soldered direct to the circuit board. Align connectors are smaller resulting in a better solder joint. There is no strain relief Ė if you have some vibration (like a helicopter or airplane with a high RPM motor) the connectors come off the circuit board. Sometimes itís a solder joint failure and sometimes the copper comes off the circuit board. Some remove the connectors and solder on flexible wires to reduce circuit board stress. I have not heard of any failures after that mod.
A 3D aircraft has a relatively slow turning prop and low vibration so the Talon 90 would probably not have a problem.
The other problem is mainly a helicopter problem. Helicopters have a very high servo load and trying to pump 20 amps through a standard RC connector can cause problems. At least you loose voltage; at worst the connector melts. Again I donít think that would be a problem on 3D airplanes.
RC Man is offline Find More Posts by RC Man
Old Nov 16, 2013, 09:30 PM
John
jk6672's Avatar
United States, CA, Heber
Joined Sep 2012
I have one on my H9 Sbach .60 and no problems. This is the only ESC I don't use an external BEC.
jk6672 is offline Find More Posts by jk6672
Old Nov 17, 2013, 06:03 AM
United States
Joined Feb 2001
Did you do the dual BEC connector mod or are you just running the single BEC connector?
Old Nov 17, 2013, 08:03 AM
John
jk6672's Avatar
Joined Sep 2012
dual
Old Nov 17, 2013, 09:18 AM
United States
Joined Feb 2001
dual
I have often wondered why they did not make it that way from the factory? I hate to get a new product and have to mod it because the manufacture did not do a good design.
Old Nov 17, 2013, 09:39 AM
John
jk6672's Avatar
Joined Sep 2012
Yeah it would make sence to just use a larger gauge wire from the get go, instead of balancing the load with two. Maybe there is something I don't get, but I go get I'm having to use an extra channel.
Old Nov 17, 2013, 12:58 PM
JUNK RADIO
Flazo's Avatar
USA, NY, Queens
Joined Dec 2006
110% great and with build in 20amps BEC
fred
Flazo is online now Find More Posts by Flazo
Discussion Castle Talon 90 controller converted to "Talon 90 Lite" sneu High Performance 37 Dec 12, 2014 04:24 PM
Discussion Talon 90 ESC questions topgearuk Castle Creations 4 Mar 19, 2013 02:59 PM
Sold Castle Creations Talon 90 ESC NEW! $70 shipped HD Hucker Aircraft - Electric - Power Systems (FS/W) 1 Feb 21, 2013 10:35 AM
Sold NEW Castle Talon 90 ESC ricka1 Aircraft - Electric - Helis (FS/W) 1 Feb 19, 2013 10:24 PM
Sold NIB castle creations Talon 90 ESC connor126 Aircraft - Electric - Helis (FS/W) 0 Jan 12, 2013 06:14 PM
