Old Mar 01, 2013, 06:10 PM
Tampa,Fl
Dale 813's Avatar
United States, FL, Tampa
Joined Jan 2007
Help!
Wing bolt holes lineup question.
Viper Q 500 making the change from stock wing bolts to 1/4-20 nylon. Problem is how to drill the holes out keeping the same angle to the saddle threads ? It seems mine is a little off line and the bolt binds up because its not going in straight. Was going to drill all the way through wing an saddle at the same time. I just wanted hear how some others do it.
Dale 813 is offline Find More Posts by Dale 813
Old Mar 02, 2013, 12:35 AM
Joined Jun 2008
After I have popped out the metric blind nuts, I have found that no drilling is required - I simply run a 1/4x20 tap through the existing holes (with the wing on) and then hit the threads with CA. I did have to add plywood underneath on a few to add more threads.
Kurt
kbozarth is offline Find More Posts by kbozarth
Old Mar 02, 2013, 07:43 AM
Tampa,Fl
Dale 813's Avatar
Joined Jan 2007
Got it all taken care of. Not sure why I started this thread. Common sense would have told me to tap the holes one at a time like mentioned in a 2005 thread. Thanks Kbo and Barry. Duh
Old Mar 03, 2013, 07:29 AM
I Marauderer's Avatar
Powder Springs, GA
Joined Oct 2008
We have all been there. Glad we could help
I Marauderer is offline Find More Posts by I Marauderer
Old Mar 03, 2013, 08:42 AM
Gary James
gsjames's Avatar
Weatherford, TX
Joined Feb 2006
RE-tap a second time after the thin CA has cured. It will make the bolts go in and out easier but still hold well.
gsjames is offline Find More Posts by gsjames
Old Mar 03, 2013, 01:30 PM
Tampa,Fl
Dale 813's Avatar
Joined Jan 2007
It's a night and day difference from what it was. I have 1/4-20 nylon in the front and going to leave the back alone but using nylon 8/32 bolts instead of the metal stock ones. If y'all really think its needed, I'll do the back 1/4-20 too.
Old Mar 05, 2013, 10:23 PM
Joined Jun 2008
Dale,
Your set up is the same as what Bruce Dechastel (www.bigbruceracing) does with his composite Q500 Shotguns and Slingshots, and he probably knows what he is doing by now.
Kurt
Old Mar 05, 2013, 10:49 PM
Tampa,Fl
Dale 813's Avatar
Joined Jan 2007
Originally Posted by kbozarth View Post
Dale,
Kurt
Thank you Zarth. That definitely is a sign of reassurance.
Discussion Wing Bolt holes re-inforcement mrdoodah Hand Launch 4 Oct 26, 2011 03:53 AM
Question WOT4 wing bolt holes drilled wrong jimmyhorns Fuel Plane Talk 1 Jan 04, 2011 05:22 PM
Question Wing bolt holes jmole49037 Beginner Training Area (Aircraft-Electric) 0 Sep 22, 2009 10:15 AM
Ion wing strength around bolt holes EricSoar High Performance 13 Aug 16, 2005 03:41 PM
Question about Multiplex Teddy (Wing Bolt) mrebman Foamies (Kits) 6 Jun 03, 2001 11:24 AM
