Old Nov 02, 2014, 07:20 PM
Joined Aug 2014
Debonair diheral
I am going to build a Debonair which calls for 5" dihedral.
If I reduce this to 3.5" will the plane still have trainer like handling?
Has anyone done this and if so what kind of results did they have?
Calcustom is offline Find More Posts by Calcustom
Old Nov 03, 2014, 12:36 PM
draftman1's Avatar
central CA
Joined Aug 2002
I did about 3 inches of diheadral, it worked fine
were you at Cal?
draftman1 is offline Find More Posts by draftman1
Old Nov 03, 2014, 04:38 PM
Joined Aug 2014
I'm over here in Manteca.
This will be my 1st SPAD.
I went ahead and put the spars together.
I used Loctite Gel Control and the results look good.
Im going to test it on some coro and see how it works out.
Old Nov 03, 2014, 04:51 PM
draftman1's Avatar
central CA
Joined Aug 2002
awesome! im a lot farther south, between fresno and bakersfield, I dont know of any spadders in your area, have you been on spadworld.net? thats were the spadders hang out
Old Nov 04, 2014, 05:44 PM
Joined Aug 2014
I will check them out.
Thanks for the heads up!
Old Nov 20, 2014, 07:18 PM
Joined Sep 2006
When I built my Debonair, I had zero (0) diehedral. Flew fine and was easier to build the wing that way.
Tom Nied is offline Find More Posts by Tom Nied
Sold LPU-Houston Sig Bonanza Debonair kingwoodbarney Aircraft - Fuel - Airplanes (FS/W) 5 Jul 26, 2014 08:11 PM
My Debonair (In progress) NewbtoRC SPAD - Simple Plastic Airplane Designs 2 Jan 22, 2005 12:25 AM
Debonair / FMS 7.0 or 8.5 Which is more realistic? KyFBCGuy Simulators 0 Jan 21, 2005 04:28 AM
Diheral on GWS Pico Stick? vkmaynard Parkflyers 1 Oct 21, 2002 11:03 PM
