Old Feb 15, 2014, 06:52 PM
Electric Airplane Junkie
bhchan's Avatar
United States, CA, San Mateo
Joined Jun 2000
Question
Longer rear mount prop adaptor?
Does Hacker has a rear mount prop adaptor for the A50 motor?
The one I have is 30mm long (tip to the base surface where the prop sits). The propeller I am using is a 18X8, with the hub thickness of 20mm, with the spinner back plate about 2.5mm, and a prop washer, there is not much of the threaded shaft to put a prop nut on, about 6mm, not even 1 diameter of thread.
Brian, an EAJ
bhchan is offline Find More Posts by bhchan
Last edited by bhchan; Feb 16, 2014 at 01:27 AM. Reason: wrong model, A not B motor....
Old Feb 17, 2014, 10:49 AM
United States, AZ, Tempe
Joined May 2009
Hello Brian,
The A50 prop adapter is only available in that size. It sounds as though you are using a wood prop, which have very thick prop hubs. The Hacker Prop adapter is designed with composite props in mind such as APC.
aeromodel is offline Find More Posts by aeromodel
Site Sponsor
Old Feb 17, 2014, 06:38 PM
bhchan's Avatar
Joined Jun 2000
Ok, I am using a Mejzlik carbon 18X8 prop. I think Hacker needs to supply a longer prop adaptor for the big motors! Or I need to find a Mejzlik e carbon prop! The other option is to make a special prop nut with a shoulder. It is working so far but not sure I can really tighten it.
Brian, an EAJ
Sold Exceed rocket 1950kv with prop adaptor and 6x4 prop Johnnymeg Aircraft - Electric - Power Systems (FS/W) 1 Sep 29, 2013 11:39 AM
Sold NTM prop drive 2826 1350kv motor with prop adaptor and 8 inch prop Johnnymeg Aircraft - Electric - Power Systems (FS/W) 0 Sep 28, 2013 05:39 PM
Sold AXI 2808-24 W/mount&prop adaptor AirNerd Aircraft - Electric - Power Systems (FS/W) 2 Nov 17, 2006 03:44 PM
For Sale Nippy Black 0803/199 (Motor+ESC+Mount+Prop Adaptor) NIB smrosko Aircraft - Electric - Power Systems (FS/W) 2 Aug 12, 2006 09:15 PM
Discussion How do I mount a GWS prop on a Park 370 prop adaptor? feet wet Parkflyers 3 Feb 14, 2006 06:38 PM
