Closed Thread
Old Dec 11, 2012, 08:46 AM
jabram's Avatar
Australia, NSW, Kendall
Joined Jul 2012
Originally Posted by oddcopter View Post
My understanding is there is no way to capture and calibrate my mag from a log with this board.
Also, I don't have telemetry or a USB cable long enough to do the dance.
So, I calibrated my mag by setting the parameter "COMPASS_LEARN" to 1, then flew around a while, then set it back to 0. This seems to work.
Could someone could verify that this is a good approach?
Never tried that way, you need a 3DRadio, makes life a lot easier when tuning PID using CH6 and calibrating magnetometer PLUS Mission Planner can LOG your entire flight to your PC or laptop that has the Ground 3DRadio connected..
jabram is offline Find More Posts by jabram
Old Dec 11, 2012, 09:16 AM
Quadcopter Addict
Joined Nov 2011
Thanks! Is it possible to use bluetooth instead? I just happen to have one of those.
oddcopter is offline Find More Posts by oddcopter
Old Dec 11, 2012, 09:34 AM
Joined Feb 2007
Originally Posted by JNJO View Post
Yes and no.
You can use a BT module to communicate wireless with the mission planner and do everything, except flash the firmware.
The thread you linked to is for an android app. and there is no working app for mavlink 1.0 as far as I know.
The closest to that is an app called Copter GCS, but it looks like we'll have to wait for mavlink 1.0 support.
Project home for CopterGCS -> http://code.google.com/p/copter-gcs/
/J
Edit: Somebody claims to have a working clone of CopterGCS -> https://code.google.com/r/xcl0100-copter-gcs/
I'll try it this weekend and report back.
So I can use BT module to connect to controller from my laptop, right?
It's just another way of serial communication as i understand.
my_vision is offline Find More Posts by my_vision
Old Dec 11, 2012, 09:39 AM
jabram's Avatar
Joined Jul 2012
Yes, I have tried Bluetooth, works fine shorter range.
Old Dec 11, 2012, 10:20 AM
Austria
Joined Jan 2004
@e_lm_70
The paper sticker is to protect the thin deposited top layer of the GPS patch antenna during shipping.
Test GPS outdoors with a clear view of the sky all around.
That means that this sticker should be removed right ?
About testing it ... yes, I know I should do it outdoor ... but I did read somebody did success with indoor ... actually in the past (using different GPS modules) indoor did work, as long I get GPS lock coming from outdoor
e_lm_70 is online now Find More Posts by e_lm_70
Old Dec 11, 2012, 11:28 AM
Joined Jun 2006
It will be a miracle if the default PIDs are correct for your frame and motors. SO you will have to perform PID tuning.
You are absolutely right, it flies like crap with default values. Thought it would sort of fly as good out of the box as the 14 Dollar board from HK I used before this.
Quite a different world, I will check out the links you posted. Just changing some PID numbers randomly and to look what the outcome is does not sound very promising
JimJones is offline Find More Posts by JimJones
Old Dec 11, 2012, 11:50 AM
jabram's Avatar
Joined Jul 2012
Yep, follow the tuning guide and it will fly beautifully.
Don't forget to tell us your wife's reaction when she sees you tie up your quad and put on gloves and a crash helmet, oh and don't forget her crash helmet in case it manages to escape
Old Dec 11, 2012, 11:53 AM
Joined Jun 2006
don't forget to tell us your wife's reaction when she sees you tie up your quad and put on gloves and a crash helmet, oh and don't forget her crash helmet in case it manages to escape :d
hehe
Old Dec 11, 2012, 12:37 PM
Austria
Joined Jan 2004
Interesting , my multiwii board the se2.0 from HK fly perfectly out of box with default PID
I hope to be more lucky then you with same board and same firmware ... my quad has simonk flashed esc ... so was mega stable with old kk cheap board
Old Dec 11, 2012, 01:21 PM
It's Just a Hobby!
Sudsy's Avatar
Joined May 2012
An Analogy
It came to me last night that with these control boards (both this KK2 and the MultiWiiPro) you get a cute little frog out of the box that works just fine. It seems that everyone wants to make a lizard out of it. But one slip up and that cute little lizard turns into an alligator and bites you in the ass!
I have managed to get myself so confused trying to flash the KK2s and reprogram the MultiWiiPros that I am having to take a break before I cook the alligator for dinner.
Sudsy
Sudsy is offline Find More Posts by Sudsy
Old Dec 11, 2012, 02:44 PM
Joined Dec 2012
Complete Noob here,
Where is the led that is supposed to blink for the GPS? When I connect with MultiWiiConf I don't see any GPS info and the only leds that are blinking are 1 and 2. I followed the instructions to load the MultiWii dev 1240 but don't think my GPS is doing anything other than displaying a very dimly lit led.
Thanks!
--Doug
chestnut75 is offline Find More Posts by chestnut75
Old Dec 11, 2012, 03:00 PM
United States, CA, Auburn
Joined Jan 2009
talking about multiwii dev1240..how do you flash this board w/ it ..i was succesful doing multiwii 2.1 using arduino but can seem to get the dev 1240 to get opened up..a tutorial video would be much appreciate d..thanks jabram
pinoydad is offline Find More Posts by pinoydad
Old Dec 11, 2012, 03:57 PM
fpv-tor's Avatar
norway
Joined Oct 2009
just did a new test flight and the yaw issue is gone. Perfect hover but needed a little trim. but now it suddenly flipped over and broke another motor arm. where am i going wrong?
fpv-tor is offline Find More Posts by fpv-tor
Old Dec 11, 2012, 05:28 PM
Australia, NSW
Joined Sep 2006
What error message do you get when opening:
"MultiWii_dev_r1240/MultiWii/MultiWii.ino" ?
It's a long shot but i've heard large I values for PID tuning can cause this. Although that was for flips on takeoff in ArduCopter not MultiWii.
LegendLength is offline Find More Posts by LegendLength
Old Dec 11, 2012, 06:04 PM
fpv-tor's Avatar
norway
Joined Oct 2009
I read that as well somewhere. Im flying with the default settings. Its like it tried to do a 360 when i rolled. what PID`s are you guys flying with in level flight?
Closed Thread
Discussion [UNOFFICIAL] New HobbyKing MultiWii PRO Flight Controller w/MTK GPS Module benybee UAV - Unmanned Aerial Vehicles 391 Nov 17, 2014 02:21 AM
Help! PROBLEM on Crius AIO Pro Y6 With MegaPirate NG 2.7 R4. RQuad Multirotor Electronics 3 Jan 22, 2013 01:13 AM
Found MultiWii PRO Flight Controller w/MTK GPS Module Koo Aircraft - Electric - Multirotor (FS/W) 4 Oct 11, 2012 12:47 AM
Yippee! New AirStudio universal Flight Controller for Mega Pirate NG and MultiWii AirCopter Multirotor Electronics 44 Sep 10, 2012 05:56 AM
